Amazing Breakthrough following DIY Build
Originally Posted by Julian@MRC
Well I dont like running past 15 psi on pump gas with no additives. I take a more responsible approach to my tuning, focused on drivability and longevity over squeesing a few extra HP out of it....
INHO pump gas is wat to unpredictable to play games with someones expensive motor, so I can swing my cack around in a measuring contest.
Originally Posted by rrmedicx
Zoni went from 13psi and NO Meth (575rwhp) to 17psi w/Meth (648 rwhp).
I would love to know what 17 psi w/o Meth vs. 17 psi w/Meth would yield?
Darren
Originally Posted by INTENSEPOWER
Gains would be negligible at best. Meth = safer AFR's. The last car we built & tuned w/ ProEFI (built motor PowerLab GT35R) had meth injection. I can dig up both graphs and hp/tq #'s at the same psi w/ and w/out meth are almost identical, while the AFR's are better.
Darren
Darren
Darren
Darren
That 13 psi was without meth.
Sooo.... We already have numbers @ 13psi w/o Meth, so how about 13psi with meth?
Every car we tuned with meth made way better gains than negligible that for sure..We were able to run cleaner AFR's and a few degrees more timing for more power...
Originally Posted by 1ZweetZ
So are you saying on the graph you posted, that the only difference between the two curves is just the addition of methanol? No more boost, no more timing??
So an increase of 4psi and meth = 73whp
Originally Posted by SlideFox
Someone stated earlier.....
Makes sense! It looked like he was saying the gain was from meth alone.
It also cools the AIT and boost charge a bit more..
Basically I added about 2 degrees timing and a conservative AF ratio of about 11.8, and raised the boost to 17 psi, something i would never do on pump gas, cause the amount of timing i would have to pull in addition to "SAFELY" run 17 psi on pump would negate the gains alot..
Your gonna love METH and what it does..
We added almost 100whp on pump gas
Once again, meth does not make power by itself, it is not a "power adder"..Meth simply allows to run mre boost, more timing and a more agressive A/F mixture, a little bit safer on pump gas...
Darren
I think what people are saying is that your first post reads as if you made 100whp by just adding meth, that's all. Great tuning Julain -- everyone here knows you're top shelf.
Darren
Darren
I probably should have clarified my statements..
I should have said "we were able to make alost 100hp additional tunning on meth".
Previous numbers on the car were 555@15psi the year before...
here is the old dyno..
The addition of Meth definately makes a huge difference for how cheap it is compared to race gas!
I understand all of that, your original post was just misleading....that's all.
