Vortech 34 T Cog pulley
Old Nov 23, 2007 | 10:16 AM
jpc350z's Avatar
jpc350z
Default Vortech 34 T Cog pulley
Anyone installing the 34 T cogger run into a clearance problem with the connector right behind it?
Old Nov 23, 2007 | 10:26 AM
booger's Avatar
booger
I got mine by the cam sensor . It was hard as hell , but it went by . You probably should take off the jackshaft or loosen up the bracket to get it by .
Old Nov 23, 2007 | 11:58 AM
harogts's Avatar
harogts
yes, my revup kit comes with that cog pulley and when i installed it it was rubbing on the connector. so i just loosen the connectors and pried it off some, but even now its almost touching the nut.
Old Nov 23, 2007 | 01:07 PM
Hexxum001's Avatar
Hexxum001
It's very close no matter what. Mine is as close as possible without it touching but it doesn't touch.
Old Nov 23, 2007 | 04:29 PM
booger's Avatar
booger
are we all talking about the same thing here ? This the area where I had problems getting the cog pulley by . The dip stick is in the way though
Old Nov 24, 2007 | 03:47 AM
harogts's Avatar
harogts
were talking about how close the pulley is to the pipping. mine at one point, the nut was rubbing on the connector and burned a whole in it. thats when i loosen it and pried it away, but its still so close you could barely slide a sheet of paper between it.Vortech 34 T Cog pulley-car5ed.jpg
Old Nov 24, 2007 | 04:01 AM
booger's Avatar
booger
Ok ...I see . I was talking about installing the pulley . Its hard as hell on a 03 G35 to get it by the cam sensor I circled in yellow .
Old Nov 24, 2007 | 09:41 AM
xav_350z's Avatar
xav_350z
u have the T trim blower or the one that came with the base kit ?
Old Nov 24, 2007 | 10:04 AM
harogts's Avatar
harogts
i have the regular blower that comes with the kit (V-2 sc-trim)
Old Nov 26, 2007 | 05:05 AM
jpc350z's Avatar
jpc350z
I'm referring to the white plastic connector just below the Cam sensor in your pic..Looks like it may rub against it..I have room with both the cam sensor and the piping..
Old Nov 26, 2007 | 05:52 AM
jouvert00's Avatar
jouvert00
Did you get this issue squared away?
Old Nov 26, 2007 | 07:26 AM
jpc350z's Avatar
jpc350z
Not yet. It's still sitting in my garage.. Trying to see if any one had an interference with this connector...Looks very very tight clearance...
Old Nov 26, 2007 | 09:17 AM
Hexxum001's Avatar
Hexxum001
No interference here but yeah, there isn't much room.
Old Nov 26, 2007 | 09:26 AM
harogts's Avatar
harogts
its real close, but it doesn't touch its about a 1/4 inch away. have you put it all together to see if it hits it or not?
Old Nov 26, 2007 | 09:32 AM
jpc350z's Avatar
jpc350z
Not yet.. Don't wanna start until I engineered the hell out of it..
By the way what's the easyiest way to swap it out..A power tool needed to remove it. Assume blue loc tite would be advisable..
Old Nov 26, 2007 | 10:04 AM
harogts's Avatar
harogts
you can take it off with a closed end wrench, or ratchet, you have to hold the pulley somehow to keep it from turning.
Old Nov 26, 2007 | 10:10 AM
jpc350z's Avatar
jpc350z
Yeah, how do you keep it from turning?
Old Nov 26, 2007 | 12:59 PM
eez's Avatar
eez
lol I used an oil filter wrench and wrapped the pulley with rags. I used this on the supercharger pulley while it was out of the car.
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
