Advantages of Raising Rev Limiter on 5AT
Old Nov 26, 2007 | 12:23 AM
minus500's Avatar
minus500
Default Advantages of Raising Rev Limiter on 5AT
Are there any advantages to raising the rev limiter on a 5AT? I ask because I want to know whether the car will still shift wherever the TCM is programmed to shift or can this be bypassed in Tip mode? I don't think anyone has created a solution to reprogramming the TCM on these cars which stinks. It would be nice to increase line pressure and all other aspects of the trans.
Old Nov 26, 2007 | 04:31 AM
DanielW's Avatar
DanielW
if you raise the limiter iit will help keep you from hitting fuel cut/rev limiter
Old Nov 26, 2007 | 05:00 AM
coachk's Avatar
coachk
Mine is raised to 7200 and I shift at 7k in tip mode when racing
Old Nov 26, 2007 | 05:17 AM
helldorado's Avatar
helldorado
Even with a raise rev limiter, the stock shift points are unchanged. But, if you are boosted, it gives you a bit of a buffer between the time the ECU starts pulling timing and fuel if on a stock VB and it can't complete the shift before you would hit the stock redline vs having it raised.
In manumatic mode, you can take full advantage of the higher redline.
Old Nov 26, 2007 | 09:04 AM
Oleg's Avatar
Oleg
But doesn't the EMS that you have with your FI setup take care of the whole fuel/timing buisness anyway?
DanielW's Avatar
DanielW
yeah you can take advantage but I'm to scared to rev up to 7000 or even 7200 where my rev limiter is.
Old Nov 26, 2007 | 09:05 AM
DanielW's Avatar
DanielW
I think the utec can lower the rev limiter but not raise it if i'm not mistaken. could be wrong on that though. Most people do a reflash of the ecu to raise the rev limiter
Old Nov 26, 2007 | 12:17 PM
minus500's Avatar
minus500
You definitely can't raise the limiter with any aftermarket EMS except maybe a Motec or something crazy like that. You have to get the stock ECU flashed to do that.
Old Nov 26, 2007 | 12:25 PM
moog's Avatar
moog
UTEC can raise the rev limiter.
Old Nov 26, 2007 | 12:28 PM
Motormouth's Avatar
Motormouth
you have to use Manual mode otherwise it shifts at the stock points.
Old Nov 26, 2007 | 01:28 PM
DanielW's Avatar
DanielW
i don't think the utec can raise the rev limiter only set a lower one
Old Nov 26, 2007 | 01:38 PM
minus500's Avatar
minus500
That would make sense. The Fcon and Haltech can't so, I highly doubt that the Utec can. All the mentioned EMS's keep the factory computer in place.
So, if your in Manual Mode, you can shift at whatever you flash the redline at? Thats what i'm trying to determine. I really wish there was software to manipulate the tranny settings.
Old Nov 26, 2007 | 01:40 PM
moog's Avatar
moog
From the UTEC manual
Old Nov 26, 2007 | 01:44 PM
coachk's Avatar
coachk
Yes, on your question about redline...if your talking about being able to set your shift points, there is something out on the market to do this I just can't remember where I saw it. It was somewhere on this site, I think.
Old Nov 26, 2007 | 02:05 PM
rcdash's Avatar
rcdash
All of those EMS systems can raise or lower the rev limiter, depending on the year of the car. Fuel cut rev limiting can be overriden (pre-05), but the throttle closing is not managed by the EMS so a ECU reflash is required for that (for newer cars).
In other words, Nissan used a different form of rev limiting in the newer cars. Since none of the EMS systems today control the throttle, they do not have the capability to alter this.
Old Nov 26, 2007 | 02:14 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I will say one thing since i put in the fp valvebody(bought from zulater)when i took alberto out for a spin,i left it in full auto mode and it shifted hard as crap, and bert said he saw 7500 rpm.Well that scared the **** outta me cause i wasnt watching the tach and he was so i shift manual mode all the time when i get on it.I did not have the rev limiter changed either.
Old Nov 26, 2007 | 02:35 PM
coachk's Avatar
coachk
I think Bert had a couple too many beers that night ......You would of definitely felt the fuel cut off at 7500 rpm based on your stock rev limit.
IIRC in auto mode I have also had it shift after the stock rev limit setting so I figured it was because my rev limiter was raised.
Old Nov 26, 2007 | 03:27 PM
minus500's Avatar
minus500
Are you saying that there are 2 forms of limiters on the 350/G or is there a fuel cut for the pre Rev-Ups and a throttle cut for the Rev-Ups? I talked to several tuners and both said that the only way to go around the limiter is to have a flash and mine is not a Rev-Up motor. I also have the Fcon Vpro. I would have thought for that kind of money you could do whatever you want and was very dissappointed to learn you couldn't.
Old Nov 26, 2007 | 03:30 PM
minus500's Avatar
minus500
There was one company that made a tunable program for the 5AT but, this was for Nissan's with non external TCM's. There was also another company that had something that was fully programable but, again i'm not sure whether it was for our specific cars. They never emailed me back and I didn't pursue it any further.
Old Nov 26, 2007 | 06:21 PM
helldorado's Avatar
helldorado
Pre 04.5 is a hard limiter. You bounce off of it, but the engine maintains power for the most part. 04.5+ is a soft limiter where it cuts fuel and pulls timing. So the engine slows down before hitting redline and doesn't bounce.
