Si TRIM VORTECH.
Old Feb 4, 2008 | 06:17 PM
  #261
JET MECH's Avatar
JET MECH
my z is a GTM, i dropped it off today around one. i had a lenghty talk with Sam about my setup and what i expect. he is excited about this Si-trim and he said with my mods' he is shooting for 470 rwhp area. i am more interested in the tourqe numbers i will be pushing.
Old Feb 4, 2008 | 07:10 PM
  #262
Hexxum001's Avatar
Hexxum001
Cool deal. Sam and I actually spoke about your car not too long ago too. Your numbers will help guide what direction I take with my G. I'm excited to see your numbers!
Old Feb 4, 2008 | 07:37 PM
  #263
JET MECH's Avatar
JET MECH
during my drive to cali from vegas my newly painted v1 lip got the **** beat out of it from rocks. it needs to be repainted already. and my FMIC took a small rock through one of the fin sections. WTF!!!!!!!!!!!!!!!
Old Feb 4, 2008 | 08:08 PM
  #264
iStan's Avatar
iStan
ZR
You put the bumper on?!?!
You should see my new grille. I'll take some pics tomorrow for you. Looks alot cleaner and protects the FMIC
Old Feb 4, 2008 | 10:16 PM
  #265
9kFever's Avatar
9kFever
Can you PM me when this setup is dynoed?
Old Feb 5, 2008 | 07:49 AM
  #266
JET MECH's Avatar
JET MECH
no problem.
Old Feb 5, 2008 | 08:38 AM
  #267
str8dum1's Avatar
str8dum1
so you dont get on the dyno for a week or so??
Old Feb 5, 2008 | 11:35 AM
  #268
JET MECH's Avatar
JET MECH
my z is at GTM right now. they are doing some custom exhaust system upgrades as well as fixing my innovate A/F meter (installing a time delay relay). after that it is going onto the dyno. i told Sam to take his time and i will be back on friday.
Old Feb 5, 2008 | 11:39 AM
  #269
iStan's Avatar
iStan
ZR
Paul, you taking your truck back down? Other Mike needs a part picked up, go check our board.
Old Feb 5, 2008 | 12:55 PM
  #270
JET MECH's Avatar
JET MECH
unfortunetly i am not. i am going to fly back to cali to pick the z up. it is cheaper to fly than it would be to fuel my truck up for the round trip. i spent $120.00 in gas for the titan for the round trip. a ticket for a southwest flight is $49.00. thats a no brainer!!!!!!!!!
Old Feb 5, 2008 | 01:02 PM
  #271
iStan's Avatar
iStan
ZR
Definately. Jordan and I just did that for his G. Got to love Southwest.
Excited to see how this turns out.
Old Feb 5, 2008 | 05:57 PM
  #272
str8dum1's Avatar
str8dum1
time delay relay, whats that for?
exhaust mods, like a dual 3" exhaust? Someone else mentioned that the standard BPV that comes with the blower might not be big enough. It will be interesting to see what Sam thinks about that.
Old Feb 5, 2008 | 06:02 PM
  #273
Mr_pharmD's Avatar
Mr_pharmD
the stock BOV is fine... I'm running 16psi and it's holding just fine.
Old Feb 5, 2008 | 06:13 PM
  #274
booger's Avatar
booger
You'll be ok like mr-PharmD said . I was ok with the T-trim untill I went to the cog pulley system . The serp belt will slip if the back pressure gets to high and save the seals in the blower . With an all cog belt system there is no slippage and the back pressure can get to high if it doesnt release fast enough
Old Feb 5, 2008 | 08:14 PM
  #275
str8dum1's Avatar
str8dum1
not concerned with it holding. concerned about it dumping enough air when you let off the gas. Jet Mech should be much higher than 16 psi as well.
pharmd, you see 16 psi with what trim blower? if thats just the SC trim, thats gotta be about the highest boost seen.
Old Feb 5, 2008 | 09:23 PM
  #276
Mr_pharmD's Avatar
Mr_pharmD
I'm following in booger's footstep with the T trim making ~15.Xpsi at around 6500 rpm on the DD.
Old Feb 5, 2008 | 09:53 PM
  #277
9kFever's Avatar
9kFever
that and GTM is so close to Ontario Airport.
Old Feb 6, 2008 | 05:48 AM
  #278
JET MECH's Avatar
JET MECH
the time delay relay is for my A/F ratio meter, Sam said it corrects the inherent problem the innovate meter has on power up ( dashed lines on indicator ) during first power up of the day. exhaust mods will be removing the aps single large muffler due to all of the packing being blown out and installing two strup canisters. 2.5" inlets 4" outlets, they have a straight threw designe and installing a cross over pipe aft of the headers just where the two 2.5" pipes come close together. should have the appearance of a hks system when done and allow a little more flow. it will be a true 2.5" dual exhaust when done. and hopefully it will get rid of the rasp i have due to my 2.5" aps test pipes i installed a year ago. probably not though!
Old Feb 6, 2008 | 07:15 AM
  #279
iStan's Avatar
iStan
ZR
You don't have rasp. You have pissed off bumble bees following the big Nissan pissed off bumble bee.
Old Feb 6, 2008 | 07:42 AM
  #280
JET MECH's Avatar
JET MECH
sweet!!!!!!!!!! Hey Stan, on a scale of 1 to 10 how loud was my supercharger when i was cruising behind you out at red rock? was most of the sound the bypass air or could you hear the blower whine.
