Si TRIM VORTECH.
i know my SI is hot to the touch when i get home from a drive. Never really had the SC blower working, before the bearings went so i dont have much of a comparison.
I know its definetely working harder bc we are seeing boost levels at 5-5.5k rpms that SC owners are seeing at redline.
Oil cooler is on the short list of immediate mods. My meth kit i'm sure helps alot with AIT (and like was mentioned wouldnt be seem by the UTEC since the AIT probe is before my spray nozzle) , but it doesnt cool the oil that feeds the blower.
Jet, is Sam still tuning yours?
Originally Posted by jksstar
My blower did not seem to hot at all, it was warm but not bad at all. The AIT would stay low untill the upper RPMs (think it was around 5000 rpms) and then they jumped up.
Could you keep me updated with the AIT. I would like to know if its the S/C or something I did.
hehe dude your exhaust has to be bonkers loud
test pipes on a NA Z is loud as hell
supercharged would be like
especially if you reduced the big *** rear muffler
The H-pipe will probably bring a lot of the barking roar back into the sound. My APS exhaust sounded like *** before my X-pipe
yeah IMO you definitely want an H or X pipe - just something to connect the two sides. It'll end up being beneficial for the vortech
especially if you reduced the big *** rear mufflerThe H-pipe will probably bring a lot of the barking roar back into the sound. My APS exhaust sounded like *** before my X-pipe
Originally Posted by JET MECH
i will keep you posted. Sam should be making more pulls tonight after he installs my new belt. he mentioned he has to do the pulls after hours due to my exhaust being so loud. the techs in the shop would not deal with the noise. they are fabricating a "H" pipe into my exhaust to try and get the tone a little more melo and possibly add a little more tourqe.
thanks, hope it works out for you.
Originally Posted by Barzten1
Your NX kit....is it a intercooler sprayer? If so whats the review on it?
Originally Posted by sentry65
I think jksstar actually runs a nitrous shot on top of the vortech right?
If this does not work out i am going to throw in the towel and start my engine build and go TT'S for sure!!!!!!
you might want to get water/meth injection sooner rather than later though.
I am kinda starting to wonder if the REVUP maybe isn't as ideal with the belt layout as a modified non-REVUP's though when pushed to the absolute extreme. If you can get it to not slip, you should be good.
I think you'll get it working.
I'm starting to think the REVUP isn't as ideal with the belt layout as the non-REVUP's though, but if you're not slipping, you should be good. But then again if your front belt almost threw itself off in the first place, I don't know what all can be done with the REVUP belt layout to help that
I'm starting to think the REVUP maybe isn't as ideal with the belt layout as the non-REVUP's though when pushed to the absolute extreme if the cog belt has to be routed that way and if you almost already threw the front belt off. But if you can get it to not slip, you should be good.
car looks great! the way you pull off the yellow/black combo works really well in all the pics I've seen of your car.
Yeah I don't know where you can add a pulley on the REVUP from what I've seen near the jackshaft. That horizontal top stretch of belt doesn't have enough room for another pulley I don't think, but maybe it might somehow, or maybe the lower pulley can be moved lower and made smaller to make room for an upper small pulley to be added?
that last long vertical stretch and only getting 50% wrap on the crank pulley are the two other problem areas with the REVUP
maybe you could do a "TIMROD" setup to it like this?
so why no dyno #'s? sounds like it ran full bore.
I had very little slip with mine Sunday (up to 6500rpms) I just can't recall how much boost it was making (think it was around 15-16psi)
Yeah I don't know where you can add a pulley on the REVUP from what I've seen. Mainly that horizontal top stretch of belt doesn't have enough room for another pulley I don't think, but maybe it might
You guys are starting to run into your belt problems all of us do , including the ATI Procharger guys run into . And thats trying to turn a blower that gets harder and harder to turn as boost rises . and trying to turn that blower with a flat serp belt . Its only going to be able to grab that pulley for so long . When the boost gets to a certain point the blower is just to hard to turn and the belt slips . No matter what you do , as long as it is a serp belt , it will slip or try to jump off the pulleys . Even an all cog pulley system runs into belt problems when boost gets high .
