Si TRIM VORTECH.
Old Jan 9, 2008 | 01:52 PM
  #161
JET MECH's Avatar
JET MECH
Originally Posted by sentry65
doesn't florida have 93 octane gas at the pump?
race gas = insurance
and JET MECH will possibly be pushing beyond what Jeremy did
exactly!!!!!!!!! 100 octane=insurance. the z is not my DD and i only drive it maybe i once or twice a week. i am hitting 14lbs of boost a 6600 rpm on the stock block. my rev limiter hits at 7100. i have not even pushed it that high yet without the tune.i can speculate it may hit 16 lbs at 7100 rpm. also the 100 octane helps with detonation in the summer months out here in vegas, we will see temps of 125 plus out here in the desert at times. considering i have some pretty good breathing mod's besides cam's i would speculate that some people with the Si-trim may see even higher boost numbers. from the test run's i have been making i am not experianceing any belt slip yet. maybe it could be attributed to the better designe of the rev-up vortech kit belt routing. who know's maybe after the tune i may have the record for the highest HP rev-up vortech setup on the stock block.it looks like sentry65 has the none rev-up record so far on the stock block.
Old Jan 9, 2008 | 02:15 PM
  #162
JET MECH's Avatar
JET MECH
Originally Posted by istan
When is the extra 2PSI hitting though?
Also, our Pump is 91 here
i was referencing that when i installed my older CAI setup that when i drove the z after the reinstallation i lost 2lbs of boost at 6600 rpm. all run's previously were made without the air cleaner installed. i am glad i did that so i could get a solid base line of the boost potential of the Si-trim. i appears that it will need a larger aircleaner due to the s/c needing more air due to the Si-trim upgrade.
Old Jan 9, 2008 | 03:09 PM
  #163
Floridaboy1605's Avatar
Floridaboy1605
what pulley set-up u running now cause i have my new ttrim on the way???
Old Jan 9, 2008 | 03:39 PM
  #164
JET MECH's Avatar
JET MECH
Current setup
32 G/s Cog, 28 S/c Cog, 2.87 Serp on the rev-up setup.
Stock was
34 G/s Cog, 32 S/c Cog, 3.12 Serp
Old Jan 9, 2008 | 04:23 PM
  #165
str8dum1's Avatar
str8dum1
we are all excited to see how ti does on the dyno. MY car limits at 6600 rpms being a non-revup. YOu still have another 500 rpms. 16 psi should be attainable. mad powa!
Old Jan 9, 2008 | 04:35 PM
  #166
G35asian's Avatar
G35asian
I see that you have a UTEC right? Just bump up the rev limit to 7200 and you'll be seeing close to 11 psi at redline. At least that is what I'm doing
Old Jan 9, 2008 | 07:29 PM
  #167
str8dum1's Avatar
str8dum1
i am seeing 11psi at 6k rpms with my 2.87. Plus, 6400 rpms is already overspinning the normal SQ trim blower. The SI will allow me to rev to redline and not overspin the blower. hopefully with the boost leak taken care of and the SI trim blower i'll see a nice improvement over my previous dyno.
Old Jan 9, 2008 | 09:03 PM
  #168
Floridaboy1605
At what rpms would a ttrim over spin with this pulley set-up 28tooth charger pulley 32 tooth jackshaft pulley and a 2.87 serp pulley
Old Jan 10, 2008 | 02:46 AM
  #169
str8dum1's Avatar
str8dum1
6600 rpms
Old Jan 10, 2008 | 05:48 AM
  #170
Floridaboy1605
any idea of how many pounds that would be making???
Old Jan 25, 2008 | 05:16 AM
  #171
james12345pt's Avatar
james12345pt
Default SI trim
Any updates??? What PSI do you think the si trim would produce on the stock pulley setup for the the revup engine?? I'm am having Performance Factory install a vortech in March and was thinking about running this setup.
Old Jan 25, 2008 | 06:30 AM
  #172
JET MECH's Avatar
JET MECH
the z is going to GTM on 4th of this comming month for tuning and some custom exhaust work. i will keep you guys posted!!!!!!!!! i could only speculate what the psi level would be on a stock revup pulley set up.it appears alot of people here are having the upgraded Si-trim done as well, so we can wait and see.
Old Jan 25, 2008 | 06:53 AM
  #173
james12345pt
Default SI Trim
I would guest ~11-13 psi with the stock pullies. How much power would this produce? Also, how much louder is the SI trim compared to the stock impeller? Maybe the guys from performance factory could give their 2 cents.
Old Jan 25, 2008 | 06:57 AM
  #174
Floridaboy1605
I'm going to get my si-trim tuned on Tuesday with the 2.87 on it so I will let you all know the number Tuesday night
Old Jan 25, 2008 | 07:08 AM
  #175
james12345pt
Default SI Trim
I have the 2.87 with the other stock pulleys but I think a 3.12 will bring it closer to 11 or 12 psi. I don't want alot much topend boost, I was hoping for more MID around 3500-4000rpms.
Old Jan 25, 2008 | 08:28 AM
  #176
str8dum1's Avatar
str8dum1
ya let us know. I am not pushing ,mine til i get my fuel pressure gauge in. over 12psi might really pushing it with stock internals.
But of course I want you to drop the hammer and get some nice WOT psi numbers
Old Jan 25, 2008 | 09:53 AM
  #177
JET MECH's Avatar
JET MECH
remember! a 2.87 serp pulley on a stock revup vortech kit is equal to a 3.12 serp pulley on a non revup vortech kit. that is why i re-cogged my revup kit to a non revup cog configuration.
  #178
jouvert00's Avatar
jouvert00
I have a non rev up motor (stock block) dynoed last week on a dyno jet, it made 436.68whp & 369.51wtq it was pretty cold out that day which prolly accounted the 14psi we saw @ 7100.
Old Jan 25, 2008 | 09:58 AM
  #179
JET MECH's Avatar
JET MECH
from having my Si-trim installed and driving it around easy till i get it tuned at GTM on the 4th of feb i will tell you it is quite a bit louder than the SC-trim. i can hear the supercharger well over my exhaust. it sound like a old V-1 vortech s/c head unit. i know because i had one on my old 93 LX mustang back in the day.
Old Jan 25, 2008 | 10:07 AM
  #180
jouvert00's Avatar
jouvert00
I haven't heard the V-1 is it more of a grinding sound or a loud whine?
What hp levels are you hoping for after the tune?
