mmmmm....Titanium valves!!!
Old Dec 5, 2007 | 12:44 AM
TheBlackPearlZ's Avatar
TheBlackPearlZ
carbon fiber engine block FTW...hahahahahaha
Old Dec 5, 2007 | 12:50 AM
TheBlackPearlZ
https://my350z.com/forum/showthread....itanium+engine
poor guy hasnt been on since...
Old Dec 5, 2007 | 12:59 AM
JAM3Z's Avatar
JAM3Z
Phenom
lol, and don't forget the flux capacitor
Old Dec 5, 2007 | 04:55 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
Originally Posted by sentry65
12 exhaust valves with 18 grams savings each = .48 lbs worth of weight saved
...I'd rather go with a tried and true SS valve
thats a crazy amount off of valve weight, could use stock springs and probably rev to 8000 with no issues at all.
very nice find!!
Old Dec 5, 2007 | 08:37 AM
Quamen's Avatar
Quamen
The titanium valves are a very nice find OP. I would think that as long as you are using them with the correct guides/seats and the proper coating they should work just fine. They may be a bit more likely to fail from improper EGT's then say an inconel valve but when you tune a boosted car things such as EGT should be monitored anyways.
With that in mind, as long as you tune your car good and have the entire valve train designed to work together nicely you shouldn't have any problems I would think.
OP-It is nice to see that you did some research on valve material before you went out and bought "exotic" valves. Most people hear the word "titanium" and forget that with titanium things such as mating surface material selection and coatings are extremely crucial things to take into consideration. Otherwise longevity can be kicked right out the door. I would hate to see/hear what a galled valve seat/stem is like from an improper setup.
Old Dec 5, 2007 | 09:29 AM
Kwame's Avatar
Kwame
AFAIK these were to be used only with the NISMO Competition Heads.
What heads do you plan to run?
Old Dec 5, 2007 | 12:15 PM
QuadCam's Avatar
QuadCam
What does "AFAIK" mean?
the nismo intake valves valves use a smaller diameter head than the stock VQ35 intake valves. these are the exhaust valves.
Old Dec 5, 2007 | 12:26 PM
iStan's Avatar
iStan
ZR
As far as I know
Old Dec 5, 2007 | 12:31 PM
QuadCam's Avatar
QuadCam
Originally Posted by istan
As far as I know
thank you.......I remember wondering what the hell "FTW" meant for the longest time. when I found out.........I realized that there must be alot of closet Hollywood Squares fans.
Old Dec 5, 2007 | 12:39 PM
iStan's Avatar
iStan
ZR
Unfortunately, that's the only thing I can contribute to this thread.
Rev_Night
Nov 7, 2020 06:00 PM
allmycarsdie
May 13, 2016 04:38 PM
May 12, 2016 07:42 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
