Injected Performance Cosworth Inlet Manifold REVIEW
Originally Posted by Robert_K
I'm gonna go out on a limb and say the Nyquil is effecting you're lack of judgement on a joke.
Com'on Andrew! You know me better than that.
And if you ready the post again, you notice that I'm basically saying a "baller" makes dumb purchases.
Originally Posted by Hydrazine
Hal,
Any observations on butt dyno results? Throttle responsiveness?
Next week I should be able to test it on a car with our built motor and built head package.
Originally Posted by TurboTim
I dont think you would grind on those stacks but a full polish would help
at this point the manifold is restricted by the throttle body.
Originally Posted by rb26ina240
no polish, you want the turbulence
at this point the manifold is restricted by the throttle body.No you dont.You want speed and velocity without turbulence.Turbulence is a bad thing.In the lower intake manifold,the casting is not so bad since it helps atomize the fuel.
at this point the manifold is restricted by the throttle body.people have made over 1000 whp on a stock throttle body..it's not limiting anything for 99.9% of people
Originally Posted by Z1 Performance
you don't want turbulence at all actually, slows down velocity by a significant amount
To the OP - I can't wait to see what kind of gains can be made on a high-boost built application. That's where this plenum will really shine.
-Acree
example
Originally Posted by MacGuffin
Essentially correct, but preferring laminar flow to turbulent flow does not mean that you necessarily want perfect surface smoothness. The right kind of surface roughness will actually allow for greater laminar flow velocity than will a very smooth, polished surface.
example
example
example
example
Originally Posted by sentry65
as long as all these dynos are fully tuned and not just throwing the manifold on expecting gains with no tuning
as soon as i get mine from Sharif ill test it at 25+psi on the intense/powerlab 76S turbo kit(or somethign else
)I cant wait
as soon as i get mine from sharif ill test it at 25+psi on the 76S turbo(or somethign else
) with the pro-efiI cant wait
you've got to be kidding me.
I know that in a NA situation you want some roughness to create the boundry layer along the sides of the runners/plenum/whatever so that the air can slip through faster as friction is lower between air/air then air/metal surface. In an FI application im not sure.
Originally Posted by meatbag
Who has made over 1000whp with the stock throttle body?
Originally Posted by kwame@z1
