supporting mods-turbonetics st
Old Dec 14, 2007 | 11:45 PM
NISMO_558's Avatar
NISMO_558
Default supporting mods-turbonetics st
I'll be acquiring a turbonetics st and have a few N/A mods that i'm curious if they are going mess it up or not. I'm planning on installing it as is, including the reflash from turbonetics. My main concern is the 5/16" spacer and MRev2, I'm not too worried about the crawford headers, i know the kit works with them, just a little work has to be done. Should it just be fine to leave the Mrev2 and take out the spacer, or put it back to stock?
Old Dec 14, 2007 | 11:53 PM
JAM3Z's Avatar
JAM3Z
Phenom
the spacer and the Mrev2 will be fine, you definitely need to get a tune though. The reflash is just the ticket for a blown motor
Old Dec 15, 2007 | 12:05 AM
NISMO_558's Avatar
NISMO_558
I've read in a few places where all they had was the turbonetics reflash, and were going "50,000" miles strong, but A greddy emanage ultimate or utec will be coming in the future. If a good tune is absolutely necassary, I'll most likely just get the emanage.
Old Dec 15, 2007 | 12:18 AM
JAM3Z's Avatar
JAM3Z
Phenom
if you're gonna go emanage, get the ultimate. the emanage blue is not to be trusted
Old Dec 15, 2007 | 02:43 AM
Zridder19's Avatar
Zridder19
Go for a UTEC.
Old Dec 15, 2007 | 02:56 AM
Devil Z's Avatar
Devil Z
+1 on UTEC. Hell, I even went as far as a F-Con VPro on stock block.
Old Dec 15, 2007 | 08:09 AM
taurran's Avatar
taurran
Ticket for a blown motor? Amazing I've seen blown motors on a lot of UTEC tuned cars as well. It's all in how you verify the reflashed tune, and if the kit was properly installed.
Actually the stock ECU is able to adapt within certain measures for minor changes in flow provided by these modifications. I ran for 2+ years at 9psi, a plenum spacer, and exhaust with no issues and 11.5:1 AFR all the way to redline. My motor failure wasn't related to the reflash in any way.
Avoid the headers and go with stock manifolds if possible. You will have to modify your downpipe and will still deal with exhaust leaks and vibration/rubbing as a biproduct.
Still, a custom tune is always better, so if you can afford it just grab a UTEC.
Old Dec 15, 2007 | 08:14 AM
alfonsohaskins's Avatar
alfonsohaskins
hey i thought the tn kit came with a unichip already programed thast how they was able to do the 1year warranty help me out cause i plan to get one also
Old Dec 15, 2007 | 08:17 AM
taurran's Avatar
taurran
Nope, it's a reflashed ECU. If you want to do a piggyback EMS and fuel system I'd suggest getting the tuner kit.
Old Dec 15, 2007 | 08:27 AM
JAM3Z's Avatar
JAM3Z
Phenom
i stand corrcted
Old Dec 15, 2007 | 08:28 AM
alfonsohaskins
i leave for germany in feb i need something thats drop in if i change the reflash for aftermarket ems would that void their warranty
Old Dec 15, 2007 | 08:34 AM
Zivman's Avatar
Zivman
warranty?? what do you think is being warrantied? they sure as heck aren't giving you a warranty on your motor. They are giving you a warranty on the parts. So when the welds crack or what not, they will send you replacements
To the OP, do not attempt the install with the crawford headers. You will get nothing out of it and will have a huge problem getting the piping to fit past them
Old Dec 15, 2007 | 08:52 AM
alfonsohaskins
thats what i want warrantied iam gonna be in a different country i dont need something thats gonna give me a headace while iam over there for 2 years at worst case i buy a new motor and put that tn kit back on the new one if i blow mine not worried about the motor just want to make sure the kit will hold up after all a used motor is cheaper than a brand new turbo kit
Old Dec 15, 2007 | 08:57 AM
Zivman's Avatar
Zivman
I'll catch all sorts of grief for this, but it seems a lot of stuff breaks on the TN kits. TN seems good about replacing it, but still a headache.
You definitely want a custom load based tune with capable EMS over the crappy reflash. Also, some sort of boost control would be recommended
Old Dec 15, 2007 | 09:03 AM
alfonsohaskins
looks like its gonna be more of a headace trying to get this done before feb 10 then i planned
Old Dec 15, 2007 | 09:07 AM
TayTaythatsme04's Avatar
TayTaythatsme04
do it right the first time and just get the Utec. I've got nothing but good things to say about my set up with it but a good tuner always helps too
T
Old Dec 15, 2007 | 09:24 AM
alfonsohaskins
wow ur in tq thats crazy about 2years ago i was over that way i was at cop in ramadi since then i realize i hate having to work on people i know so i got a hospital gig now
Old Dec 15, 2007 | 09:59 AM
one350zfan's Avatar
one350zfan
To the OP, If your exhaust is 3" I'd keep it, but if its smaller I'd sell it along with all your other bolt-ons.
Use that money toward a utec, 650 injectors and an open dump. Your kit will have so much more potential.
The only downside is your sig might shrink!
Old Dec 15, 2007 | 10:01 AM
RED HOT Z's Avatar
RED HOT Z
I have a UTEC and tuner pro fro sale! hit me up
Old Dec 15, 2007 | 11:11 AM
taurran's Avatar
taurran
Obviously your opinion isn't absolutely biased....
I've seen no higher % of "broken" parts than I have on the APS ST kit. (seeing as there are no more than 10 APS ST owners around)
