JWT TT owners w/ Oil spacer
With the JWT Oil spacer it says that now we can put in 6qt of oil. However i am afraid of getting the smoking issue with to much oil. Normally how much oil do you put in? Has anyone had the smoking issue with 6qts of oil? Looking at the dipstick, how do you judge what is full and what is consider low? Is the bottom of the hash mark on the dipstick, would that consider to be high?
Thanks!!
Thanks!!
Thanks!!
Thanks!!
No problem like that with pan spacers, as the extra capacity is below the stock dipstick level and when you fill to the stock "full" mark on the dip stick, you just have an extra qt. in the pan below the normal level. There shouldnt' be anything effected as the oil level remains the same as stock.
middle hash marks on the dipstick would be fine. even on the Low mark on th dipstick, you'll still have close to 5 quarts of oil. You'd have to drop way below the hash marks to run into any issues.
I was curious about the oil return line, but maybe that is only with the APS system and not the JWT TT oil spacer. I didn't imagine seeing an issue with putting 6qts in, but I was just curious if anymore experienced the smoking issue more then anything.
Thanks for all the replies.
Originally Posted by rookie
I think the smoking issue will have some relation to the oil return line, block or pan. I use 6 qts every time and have not had any smoking issues with test pipes.
So would the middle hash mark on the dipstick be the marker??
Originally Posted by Canadian
I have always put in 6 qts, no problems here at all, with test pipes as well.
Originally Posted by Robert_K
Good question here... So w/ the extra qt for the oil spacer how about w/ the Stillen oil cooler? How many qts total?
I have the AAM spacer. Has anyone actually checked to see if the JWT and AAM spacers truly add 1Qt more capacity. I had heard that it is not a full quart, but closer to around .6 or .75 Qts.
Originally Posted by superchargedg
That you will have to just add and check to see how much extra oil will be needed.
bcoffee20
Nov 19, 2015 06:39 PM
xirtam
Oct 3, 2015 02:06 PM
