Any FI guys running HFC's?
Old Feb 1, 2008 | 12:15 PM
Abishop's Avatar
Abishop
Default Any FI guys running HFC's?
I was wondering if any FI guys were running HFC instead of test pipes. Maybe its just me, but when I'm sitting at a stop light, since my car is tuned to the rich side for safety, there is a very noticeable smell and a very faint light smoke when the sun hits it just right. I know HFC's will fix my problem but has anyone ran into any problems using HFC with your FI other then power loss?
The High Flow Cats i would like to buy are the Berk Metallic HFC's with the wide band holes pre drilled. Any opinions on these are greatly appreciated.
Old Feb 1, 2008 | 12:23 PM
rcdash's Avatar
rcdash
Berk is too small for much over 400 whp. You will get a good drop in power. You have the EvoTT exhaust now? Built engine? If you really don't want more than 400, they should be fine.
I initially has FastIntentions HFC, 300 cell metallic. They were nice but power dropped off fast after 12 psi (420 whp on Sharif's DD dyno). So then I went with APS test pipes (3.5") and got a huge boost in power, but the fuel smell in enclosed spaces (like in my garage) became terrible (I run 14.5-14.7 at idle). So now I'm having ForgedPerformance insert (as in weld in) 200 cell metallic cats into the APS test pipes (custom made and fit). Not cheap and not easy, but it's what I decided I needed.
Old Feb 1, 2008 | 01:53 PM
Abishop's Avatar
Abishop
Well I don't really want over 400whp anyway. So maybe the berk if the way to go. I have the Intense.com resonated test pipes now.
Old Feb 1, 2008 | 05:31 PM
rcdash's Avatar
rcdash
I believe they have a 200 cell metallic version. The metal substrate is more suited for FI applications. Although only a 2.5" pipe, it should be fine for 400 whp.
Old Feb 1, 2008 | 06:58 PM
acg's Avatar
acg
Even with your custom cats from Sharif you are still expecting to drop a little power aren't you?
Old Feb 2, 2008 | 05:03 PM
rcdash's Avatar
rcdash
Well yes - kind of hard to beat a 3.5" test pipe for flow. Thing is my exhaust was a FastIntentions 2.5" true dual before. Now I'm switching to an EvoTT (2.75" true dual). I'm also modifying the air intake and/or manifold to hopefully increase efficiency there also. I'm hoping the gains will outweigh the loss. We'll see - my goals are reasonable.
Obadabot
Jun 18, 2023 11:31 PM
apex locator
Jul 23, 2021 02:27 AM
35reilly
Sep 28, 2015 07:42 AM
