Oil Cooler Installed... Now Coolant Leak??
Old Feb 29, 2008 | 08:32 PM
jining's Avatar
jining
Red face Oil Cooler Installed... Now Coolant Leak??
Hi, I just installed an oil cooler that I pieced together from Summit Racing (the one you might have seen on other posts). After turning on the car, there are no apparent oil leaks, but I noticed some coolant dripping down from somewhere above the oil filter. Could it be coming from the seal between the sandwich plate and the stock coolant oil cooler?
Any ideas? I didn't have any coolant leak before this...
Thanks,
Aaron
Old Feb 29, 2008 | 08:36 PM
Nic@CiNcity's Avatar
Nic@CiNcity
No luck trying to trace it huh?
Old Feb 29, 2008 | 08:46 PM
jining's Avatar
jining
Can't see very well in there, I don't think not having the sandwich plate on tight enough would cause a coolant leak now that I think about it, only oil. Maybe I bumped a hose or something.....
Old Feb 29, 2008 | 08:50 PM
jining's Avatar
jining
I think it must be coming from #7... not sure how I could have knocked it loose.
Old Feb 29, 2008 | 11:05 PM
kevinapex's Avatar
kevinapex
Did one of the in/out nipples on on the plate get tweeked and cracked?
I have one if you need it.
Kevin
Old Feb 29, 2008 | 11:58 PM
jining's Avatar
jining
You mean the in/out coolant nipples on the oil cooler? (Number 3)
Old Mar 1, 2008 | 12:45 AM
jining's Avatar
jining
Ok so... I'm under my car on my blackberry lol... Somehow the leak is gone!
Its been idling for 5 min and I haven't done anything but leave it alone for a few hours. When it was leaking there was only a thimble full or so that dripped down before I shut the car off..... This doesn't make sense... im sure its coolant... Where did that coolant come from? The car has been up on jacks for a few days.. very odd.
UPDATE: Still no leak after watching it idle for a long time.. so I put my bumper back on...i dont quite understand. I checked the coolant reservoir to see if it was overflowing but that isnt the case.
input is greatly appreciated.
Old Mar 1, 2008 | 03:35 AM
RBALDINELLII's Avatar
RBALDINELLII
Maybe part #8 that attaches to part #3 got loosened while attaching the sandwhich plate some how.Maybe it just needed to reseat.
Old Mar 1, 2008 | 03:39 AM
jining's Avatar
jining
Perhaps, I think maybe it was the part 7 somehow leaked coolant because it was coming from top of sandwich plate it seemed.
Old Mar 1, 2008 | 03:42 AM
jining's Avatar
jining
Should I be worried?.... I don't like not know why it was leaking..
Old Mar 1, 2008 | 06:40 AM
kevinapex's Avatar
kevinapex
If it isn't leaking, don't worry about it man.
apex locator
Jul 23, 2021 02:27 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
SharX59
Sep 27, 2015 09:23 AM
