Stock Motors w/ F.I.
Old Mar 17, 2008 | 04:18 AM
  #41
ChrisCJ99's Avatar
ChrisCJ99
Turbonetics kit on my 2005 Z.... 388 rwhp/ 355 lb tq on TN reflash. Installed on my car at 26,500 miles (on 3/13/08). Lovin it and hopes it STAYS problem free
Old Mar 17, 2008 | 08:19 AM
  #42
TegraRacer134's Avatar
TegraRacer134
STS Kit on my car for 22k tuned at Performance factory 400whp/392tq @ 10 psi.
Old Mar 18, 2008 | 10:21 AM
  #43
dosu350's Avatar
dosu350
So I guess most of the problems are stock blocks, is it worth getting a long block over just a short if im going to go FI soon?(550-600rwhp)
Old Mar 18, 2008 | 09:10 PM
  #44
AreYouAMac's Avatar
AreYouAMac
In my opinion.... it all depends on your tune and how much you are boosting... some people just drive the car too hard. If you look at the +12 psi's...most if not all of them blew there engine. Get a good tune...have a good engine.
Old Mar 18, 2008 | 09:39 PM
  #45
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Adding this link to the top 100 questions thread. If any noobs ask about FI on stock motor please refer them to the top 100 questions thread, thanks guys!
https://my350z.com/forum/2003-2009-nissan-350z/197329-the-top-100-common-questions.html
Old Mar 18, 2008 | 09:47 PM
  #46
saberphx's Avatar
saberphx
Wired ^^ can you also make this a sticky thread?
Very informative thread indeed.
Old Mar 18, 2008 | 09:58 PM
  #47
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
sticky threads generally without fail get ignored after a while. noobs don't even bother to look at stickies most of the time because they're not "bold". Just subscribe or tell people to check the top 100 questions thread, since the link is in there.
Old Mar 19, 2008 | 04:03 PM
  #48
1G''s Avatar
1G'
APS TT HKS BOV meth & water inject done by scotts performance dyno'ed 485 going strong and it's been 2.5 years
Old Mar 19, 2008 | 08:29 PM
  #49
jouvert00's Avatar
jouvert00
What's your tq #'s
Old Apr 24, 2008 | 01:42 AM
  #50
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Robert_K: JWT 700BB 6.5psi UTEC tuned by MAC Autosport, Cosworth Plenum, DW 600cc, APS/Stillen Exhaust, 398/338 Uncorrected
Old Apr 24, 2008 | 02:21 AM
  #51
halfass872's Avatar
halfass872
Halfass872: Stillen Blower, Stage 3 @ 7 PSI., 51,000 miles on stock block when installed. 4,200 hard miles on her in the past year since installed. No drama whatsoever!! Cheaped out and installed everything by myself.
Old Apr 25, 2008 | 12:41 PM
  #52
UMW350Z's Avatar
UMW350Z
Soon-to-be: stock motor with POWERLABS ST. I will post my experiences soon.
It might be interesting to see how supporting mods are figuring into 'stock motor longevity'. I am doing a Nismo therm and GReddy radiator, no oil cooler.
Old Apr 25, 2008 | 12:45 PM
  #53
Nexx's Avatar
Nexx
Votech, 2.87, 12psi, 380whp, Utec, 550cc, Walbro 255lhp, - Kaboom at the track. Do not let you tuner tell you that 12:1 AFR is acceptable, cause its not on a stock motor at 12psi.
Old Apr 25, 2008 | 12:55 PM
  #54
jining's Avatar
jining
APS Tuner Kit +APS Downpipes+APS 2.5" Exhaust, CJM Stage2, Walbro, 650cc Deatschworks, Meth/Water Injection.
Over 6k miles and running strong, survived 2 lapping days. Self installed on jackstands.
430hp/400tq (uncorrected) @ 8.5psi
Old Apr 25, 2008 | 01:07 PM
  #55
SC 350Z's Avatar
SC 350Z
ati procharger-brian crower 264 camshafts,titanium retainers and springs, headers, full exhaust, skunk2 plenumspacer, 9lbspulleys,made 383rwhp-364tourqe ran the **** out of it never had a problem tore everything down going turbo now ill post up when its all done.
Old Apr 25, 2008 | 01:13 PM
  #56
EVILZ33's Avatar
EVILZ33
APS TT UTEC 3.5" APS test pipes. 415hp 405tq put on at 30k miles now at 31k miles **3" aps comming soon**
Old Apr 25, 2008 | 01:59 PM
  #57
theaxe1149's Avatar
theaxe1149
is it my imagination or are there more failed motors with the same or greater torque than HP.(400hp/+400ftlbs).
Ferrari uses 750hp/+-350ftlbs could this be the reason they can rev so high and stay together?
Old Apr 25, 2008 | 02:43 PM
  #58
SC 350Z's Avatar
SC 350Z
^ kinda see gasoline engines are limited by the valves in the heads thats why you run more hp then tourqe not like i na diesal where you may have 450hp and 7or 800 fout pounds of tourqe they can do it becasue of there being no valves to push the air threw
i think this is bout half right correct me where im wrong
Old Apr 25, 2008 | 02:49 PM
  #59
superchargedg's Avatar
superchargedg
Damn Noobs
They still have valves but its the very high compression they run that helps with a desiel's power not to mine the stroke and such.
Old Apr 25, 2008 | 03:16 PM
  #60
diwun67's Avatar
diwun67
hp is a product of torque. A diesel is designed to produce a HUGE amount of torque at a VERY low rpm. I believe the formula is torque x rpm/5252 = hp. 5252 is an rpm at where hp and tq always cross on a dyno graph, so when a diesel makes 700wtq at 2200 rpms and redlines at 4k, well there you have it. Hope that helped somewhat...
