Vortech oil feed fitting
Old Mar 20, 2008 | 09:20 AM
fishclub's Avatar
fishclub
Default Vortech oil feed fitting
I broke two of the Brass oil feed fitting. I tried to tighten the the oil line because I had seen oil came out from the charger durning the dyno tuning after hard pull. So, I ordered a stainless steel one, should arrive today. My question is, should I put any liquid sealant on the thread and how tight should I tighten it? I had removed the stainless line a few times since I broke two of the fitting, will I damage the line?
Old Mar 20, 2008 | 09:35 AM
Drewer's Avatar
Drewer
Did you crack the sender housing? It's hard to break brass, but if you way over tightened it, you can easily crack the aluminum.
Old Mar 20, 2008 | 09:44 AM
fishclub's Avatar
fishclub
I don't think I did. The fitting just slap into 2 pcs. How can I tell if i crack the housing?
Old Mar 20, 2008 | 11:14 AM
booger's Avatar
booger
Did you break the oil squirter that goes into the back of the blower ?
Old Mar 20, 2008 | 02:50 PM
fishclub's Avatar
fishclub
Do you mean the pointy end with a laser cut tiny hole to feed oil to the blower? I cracked the whole fitting into 2 pcs. It cost me $55 for that little piece...... This is the link to that fitting........ Also, do I need any sealant to the thread to stop the leak?
http://www.vortechsuperchargers.com/...p=71&cat_key=7
Old Mar 20, 2008 | 03:00 PM
booger's Avatar
booger
Yes...I went with the steel one also . I would look for some sealant that can be used with oil or gas , and put that on the threads before putting it back on .
Old Mar 20, 2008 | 03:18 PM
sw150's Avatar
sw150
I did the same thing. Had an oil leak coming from that area and then broke it when I tried to tighten it. I also noticed that I have a small kink in in the oil return line where the line comes out to the supercharger. Could that cause the oil not to flow out as fast and then have it back up and leak out of the nozzle.
Old Mar 20, 2008 | 03:51 PM
JonnyC's Avatar
JonnyC
I went with the steel one also.
Here's a link to that one - http://www.superchargersonline.com/p...at2=oil_nozzle
Or the full kit -
http://www.superchargersonline.com/p...mber=H-4NZ-010
Old Mar 20, 2008 | 06:16 PM
str8dum1's Avatar
str8dum1
luckily i kept the one out of my 1st blower when i sent it back for warranty. So at least I have a spare. youu could just use some Ultra-Grey to seal it. Mine nevered leaked, but teflon tape or the sealant would work fine.
Old Mar 21, 2008 | 06:10 AM
fishclub's Avatar
fishclub
Thanks for all the help. But do you guys think I can install the fitting without removing the blower from the bracket?
Old Mar 21, 2008 | 06:45 AM
str8dum1's Avatar
str8dum1
sure, just pull the tire and the tire well. its all rigth there.
Old Mar 21, 2008 | 10:22 AM
booger's Avatar
booger
I take out the blower the same way ....through the wheel well
350z82
Oct 1, 2015 06:25 PM
