View Poll Results: Utec VS. Haltech, which one gets your vote?
Utec
18.52%
Haltech
44
81.48%
Voters: 54. You may not vote on this poll
Utec or Haltech EMS?
Old Oct 31, 2008 | 12:34 PM
  #101
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Originally Posted by SlideFox
Raising the dead threads are we....
+1
The OP got ProEFI.
Old Oct 31, 2008 | 10:29 PM
  #102
mrg1981's Avatar
mrg1981
Wow...forgot I even looked at the Utec and Haltech back then. It has been a long time since I started this build and it has been a difficult journey. I'm not at the end of the journey yet, but I'm very close to ending the last of the haunting issues.
I will post a full build thread when the car is finally completed and I get down the track at full boost on slicks. Currently, I have run 25 passes (roughly) at about 1/2 throttle at 12(or so)PSI on street tires and pump gas. I'm running consistent 12.4-12.5 with no traction and that is, I'll re-iterate at HALF throttle. I believe the Pro-EFI has some rough edges at this point, but it is running smoothly and the issues I have do not appear to be related to it. Also, I give credit at least in part to the Pro-EFI for the high performance I am getting out of it. At 1/2 throttle at low boost and at 100 degrees F, a 12.4 is quite respectable, IMHO.
Old Jun 15, 2011 | 10:54 AM
  #103
15lb.test's Avatar
15lb.test
Guys, Dont mean to thread jack, but upon my search this appeared to be a good spot to ask a question.
Went to get tuned yest. at rs motors in mpls. Ron was awesome, and answered any questions I had. He told me about a problem (that still exists) they had with the car even with the old owner.
Basically at totally sparatic times, the rpms will "jump".
when logging the rpms are rising but then it will mis-read..
example - 4125-4179-4210-2120-4250 etc.. it just happens once usually and just long enough to notice and throw things off.. The 3rd pull he made it actually caused the car to hit rev limit at only 5700 rpms.....
He is calling out the utec. He said he has had issues with it the whole time, and always tried to get the old owner to switch to a hydra ems...
I am wondering if anyone else has had this issue? if so, did you change the crankshaft position sensor? did this help? fix? or is this a common problem on the g35 running utec?
(if there is a better post to put this in let me know and I will delete and re-enter.. Thanks)
Last edited by 15lb.test; Jun 15, 2011 at 10:55 AM. Reason: mis spelling changing meaning
Old Jun 15, 2011 | 11:17 AM
  #104
Eno's Avatar
Eno
Talking
Standing corrected! My bad.
Old Jun 15, 2011 | 01:20 PM
  #105
Cass007's Avatar
Cass007
Thsi is as valid a revival as we can get... he even referenced that he knows he bumped something from the grave.
15lb Test, if you don't get any good advice in this thread, try sending a PM to djamps, he tunes his own utec and may be able to help you find the glitch in your software.
Old Jun 15, 2011 | 05:50 PM
  #106
ashtrojan2008's Avatar
ashtrojan2008
back when i had the utec, i had this problem. its an issue with the crank angle sensor, in my case it was mostly the JWT flywheel's trigger ring. try to clean the wheel (you can just pull the sensor out and clean it with a wire brush).
Also, as crazy as it sounds, when i was running out of options, i installed a grounding kit and the issues mostly went away (with the bad trigger wheel). Can't hurt, I'd give both of those a try.
ross
Old Jun 21, 2011 | 01:21 PM
  #107
15lb.test's Avatar
15lb.test
What type of grounding kit was it? battery to body, or regrounding the utec?
Does anyone feel that switching to a haltech will solve the issue? i am considering a switch to that, 1100 injectors, double pump and E85...
Old Jun 21, 2011 | 04:04 PM
  #108
str8dum1's Avatar
str8dum1
^do the simple stuff 1st. put back in your stock injectors and ems and see if the problem is still there.
you can see your rpms drop on your tach as well?
Old Jun 21, 2011 | 08:10 PM
  #109
15lb.test's Avatar
15lb.test
I purchase the car with the setup on it after purchasing I started noticing some issues long story short I just went to have it tuned and we found that the rp m's were jumping ... no tune completed .
have to fix the issue first . original ems is the current setup on it utech ... I do not have stock injectors .
out of curiosity, what would stock injectors back in accomplished?
Old Jun 21, 2011 | 08:12 PM
  #110
15lb.test's Avatar
15lb.test
as I had said in the original post you only notice the rp m's jump when you are logging. you cannot see anything on the tach... this is why I had originally thought that maybe it was a sensor of some sort
Old Jun 21, 2011 | 08:21 PM
  #111
str8dum1's Avatar
str8dum1
i assume you check over all the pins in the UTEC wiring harness? There's obviously nothing wrong with the car or any sensor since the car runs fine and its only a data acquisition error
Old Jun 21, 2011 | 09:09 PM
  #112
ashtrojan2008
battery to body.. including a ground to the bellhousing. It smoothed out the rpm's in my logs. If it's not your flywheel or crank sensor causing the issue, maybe its just a utec issue that some of us notice? Haltech has always been smooth..
ross
Old Jun 22, 2011 | 07:08 AM
  #113
15lb.test's Avatar
15lb.test
Thanks Ross, I will upgrade the body and bellhousing ground and see if that works.. E
2ndchanceZ
Oct 26, 2015 08:03 PM
