Overheating when AC on at low speeds, HELP!!!
Old Apr 13, 2008 | 06:15 PM
Mr_pharmD's Avatar
Mr_pharmD
Default Overheating when AC on at low speeds, HELP!!!
I recently swapped out the stock radiator with a Koyo rad and bc of the vortech piping, I wasnt able to put back the stock fan shrouds. At the time NAPA only had a 16" flex a lite fan so I put that on the koyo rad and then put a 10" fan on the front side (pusher fan) near the driverside. I had them wired up so they both stay on when the temps go up.
So today, it was extremely hot and the first time I turned on the AC since last yr. It seemed perfectly fine until 30 mins of stop and go driving and the water temps kept going up (almost 3/4 H). It will eventually go back to normal once I turn off the AC or if I drive on the freeway. I bled it out like 3-5 times but I couldnt see any air bubbles come out. At this pt I dont know what to do
To recap, car overheats when AC on at go n stop situations but it doesnt on freeway runs. Car also doesnt overheat when AC not on.
Old Apr 13, 2008 | 06:19 PM
taurran's Avatar
taurran
Did you bleed the coolant system to get rid of any air that might be in there?
Other than that, I dunno. You'd have to play around with your fan setup.
Old Apr 13, 2008 | 06:20 PM
westpak's Avatar
westpak
SFZCC
if you just have the fans on the rad with no shroud that is going to hurt as it doesn't cool the entire rad and result in the overheating
Old Apr 13, 2008 | 06:26 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Bro go buy a cheap $40 water temp gauge that plugs into the OBDII, the oem water gauge = FAIL!!!
Make sure the car is up to temp before you start purging. Also not to insult your intelligence but you need to rev the car pass 5K to get the bubbles out.
Also make sure your fans are actually working right (i.e they turn on and off when they are supposed to).
I am leaning on the side very hard that you still have bubbles, for example it took me almost an hour to purge my koyo when I installed it, and then a couple of more time later that day.
Keep purging and see what happens
Luie
Old Apr 13, 2008 | 06:47 PM
350Z400rwhp's Avatar
350Z400rwhp
I had an issue like this on my Acura CL last summer. My temp gauge would start moving up every time I was in stop and go traffic or if it idled for awhile. I replaced my thermostat and coolant and nothing seemed to fix it. It turned out that one of my two radiator fans was not connected. I was suprised that just one fan not working would cause this much trouble but once I plugged in the second fan everything was fine. I think you really need to get some sort of shroud around your fans as the air is not being properly ducted and pulled through the radiator.
Old Apr 13, 2008 | 06:52 PM
Mr_pharmD's Avatar
Mr_pharmD
It works great with no AC on and I also get hot air through the heater. And yes both fans are on and running.
Old Apr 13, 2008 | 06:57 PM
eagletanggreen
Got Track!!!!!
Just cuz you get hot air doesn't necessarily mean your car has no air.
Old Apr 14, 2008 | 07:08 PM
Mr_pharmD's Avatar
Mr_pharmD
I think its overheating bc the radiator isnt getting enough air flow. Anyone know what is the biggest dual fan setup I can put on it without a shroud? My guess would be 14"
Old Apr 14, 2008 | 08:06 PM
westpak's Avatar
westpak
SFZCC
not sure about fans, but you need to do something for a shroud otherwise you will always have sections not cooled by the fans, like the corners at least
Old Apr 14, 2008 | 08:18 PM
Mr_pharmD's Avatar
Mr_pharmD
This may sound stupid, but is there a way to tell if I set my fans correctly? My 16" fan (behind the rad) is suppose to be the puller and the 10" fan infront of the AC condensor (driver side) a pusher.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
