E85 ?'s
All you need is an aftermarket fuel system like the CJM stage 2, larger injectors, and a tune.
E85 is fantastic for power/cost ratio vs. race gas, but you will use 15-20% more fuel with it vs. normal 93.
Personally, I think meth injection is a better bet from a power/cost standpoint.
It is a lot more, not exactly sure on inejector size for Z's and G's but for evo's the inectors have to be at least 1,000cc's and a bigger fuel pump and most people do the lines as well. E85 is awesome though, it would be nice to see someone do it on their car. Search around on google, there are a bunch of e85 info.
The CJM system should handle E85... however, there are a few aluminum parts in the kit. Some of the fittings, and the rails of course. Some rails are anodized, some are not... anodizing is supposed to protect the aluminum supposedly. I have built some Vipers with bare aluminum rails that run E85... but that was just last year and we havent taken things apart to check on it.
The hoses in the CJM kit will handle it since they are teflon. Might want to see if the aeroquip AQP hose used in the gas tank for the return correction kit can take it or not. Probably, but who knows.
Originally Posted by BriGuyMax
Now I know that's not true....you don't need 100% more E85 to run at the same power level as 93 octane.
Originally Posted by NickRaine78
Thanx for the link?
