I FAWKING HATE Innovate WB sensors
Old Apr 17, 2008 | 12:18 PM
chris'smax's Avatar
chris'smax
Originally Posted by blasian
I'm just giving Chris a hard time guys, he'll eventually give me his brakes... for real
NEVER. Neither your black nor your asian tricks will work on me foo
Old Apr 28, 2008 | 11:03 AM
chris'smax's Avatar
chris'smax
well i figured i would update this thread since my guage just started magically working the other day after i installed my roll cage(the Z must like her present ). I must have a loose connection somewhere becuase this thing just started working out of the blue after being f'd up for 3 weeks.
Old Apr 28, 2008 | 03:02 PM
jumpin800agl's Avatar
jumpin800agl
8 to 11
Mine worked for the first 24 hours that I had it. We replaced it with an AEM unit which worked for a month and now that one has stopped working. Will be getting it replaced again soon when I get the time to drop the car off at Forged.
Old Apr 28, 2008 | 03:41 PM
coachk's Avatar
coachk
E8 is the sensor timing error.....another thing to look into is your a/f and if you're running too rich it could cause the error. I had the e8 code but just replaced the sensor.Any misfire codes happening..that could be another cause.
Old Apr 29, 2008 | 05:04 AM
chris'smax's Avatar
chris'smax
Yes it is a sensor timming error, but i read in the manual that it could be caused by a improper connection or ground. I have been running A TAD richer sometimes since the weather is warming up. My AF at idle dances in between 13.8-14.6. Most of the time it holds at 14.1-14.2.
Not sure about the misfire codes, but my idle is steady and i haven't seen any drastic changes in AF. From my experiences when the car is misfiring it generally runs like ****, but mine is still purring like a kitten
Old Apr 29, 2008 | 06:33 AM
coachk's Avatar
coachk
Either yours is too rich or mine is too lean...at idle mine would dance between 14.8-15.2.
Old Apr 29, 2008 | 07:23 AM
chris'smax's Avatar
chris'smax
Hmm. I thought 14.0 to 14.6 was common? I could be wrong though
Old Apr 29, 2008 | 11:30 AM
rcdash's Avatar
rcdash
It's just slightly off. What is your EMS? If it's the Haltech maybe your closed loop O2 control is disabled. Just turn it on and bingo - watch you AFR hit it's target
Old Apr 29, 2008 | 12:24 PM
chris'smax's Avatar
chris'smax
I wish i had the haltech . I am running a utech right now. Couldn't i drop my base fuel pressure a tad?
Old May 1, 2008 | 09:29 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Mine worked out pretty well even with leaded fuel.
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
