Vacuum @ idle?
Old Apr 25, 2008 | 11:31 PM
aguita's Avatar
aguita
Default Vacuum @ idle?
I have a Question.What should be my vacuum reading @ idle?
yes I did Search and dind't found any answer
Vacuum On a Vortech..
Old Apr 26, 2008 | 03:22 AM
coachk's Avatar
coachk
My vacuum is 20@ idle on a Defi gauge...I have TT
Forget to mention that it was on a stock block @ 20
Old Apr 26, 2008 | 05:37 AM
ToastZ's Avatar
ToastZ
@idle it should be around 20 on a stock block.
If you are built with lower compression pistons, then it will be lower, like around 17-18 at idle.
Old Apr 26, 2008 | 05:50 AM
401Rider's Avatar
401Rider
yea mines is around 20
Old Apr 26, 2008 | 07:09 AM
westpak's Avatar
westpak
SFZCC
if your gauge reads in boost while in vacuum mine read round 10 with stock block and around 8.5 on built block with 8.8 CR
Old Apr 26, 2008 | 06:10 PM
kevin8086's Avatar
kevin8086
it depends on where you live and your altitude. the higher up the lower the vaccume will read.
Old Apr 26, 2008 | 06:27 PM
rcdash's Avatar
rcdash
My gauge reads 14.7 on start up (std atmospheric pressure), and hovers around -5 to -6 at idle, built 9:1 compression. Haven't figured out yet how to get it to be a true boost gauge with zero offset instead of 14.7 (innovate auxbox map sensor).
Old Apr 26, 2008 | 07:15 PM
westpak's Avatar
westpak
SFZCC
well he is in Miami and he is asking what his gauge should read, so I think it would be safe for people to call out sea level readings.
Old Apr 26, 2008 | 07:25 PM
Hexxum001's Avatar
Hexxum001
Mine reads 20 on a Defi boost gauge at idle also.
Old Apr 26, 2008 | 09:24 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
stock blocks always have good strong vacuum. haha, wait till you hear it now
Old Apr 26, 2008 | 09:30 PM
aguita's Avatar
aguita
thanks for the response..my vacuum reading is @ 20 on a stock block..thanks for the helP!
Old Apr 27, 2008 | 03:27 AM
coachk's Avatar
coachk
You're killing me...After we talked last night I haven't been able to sleep. The MONSTER MOTOR has come to life. I can't wait to drive it !!!!!!
Old Apr 27, 2008 | 03:42 AM
3.6z's Avatar
3.6z
Stock block and reading -23. couldn't figured out why?
Old Aug 29, 2011 | 01:36 PM
zach711f's Avatar
zach711f
I'm in a higher altitude is south Dakota and my vacuum reads -22-23
liqalu04
Jan 2, 2022 12:58 PM
05UltraYellow
Sep 24, 2015 05:41 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Darkspy
Sep 7, 2015 09:09 PM
