My built block turbonetics setup -
Old Apr 30, 2008 | 08:29 AM
  #41
zmedic16's Avatar
zmedic16
this is great bro. im following your build. i just self installed a tn kit to my 06revup. PITA but it was done. looking foward to your results due to me following your footsteps.
Old Apr 30, 2008 | 10:23 AM
  #42
rrmedicx's Avatar
rrmedicx
Congrats to another successful DIY'er. I think its becoming an epidemic?
Old May 1, 2008 | 09:31 AM
  #43
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Dude leave your car like that, it looks scary! Kinda "Mad Max"!
Old May 1, 2008 | 09:57 AM
  #44
gothchick's Avatar
gothchick
+1
Congrats~ :-)
Old May 1, 2008 | 10:40 AM
  #45
taurran's Avatar
taurran
Car looks great man.
My prediction = 430whp~
Remember what we talked about in PM's.
Old May 1, 2008 | 11:45 AM
  #46
psheehan's Avatar
psheehan
doesnt that seem a little low for a built block? how many pounds will you be running when all said is done?
Old May 1, 2008 | 04:42 PM
  #47
SpoilsofWar's Avatar
SpoilsofWar
Yep, I will. If I can't make the power I'm looking for, I'm going to do what you suggested.
Old May 2, 2008 | 03:23 AM
  #48
taurran's Avatar
taurran
The motor isn't the bottleneck. Heads and cams will help a little to utilize what the turbo and piping currently flow, but in reality the piping is what is limiting power here.
Old May 3, 2008 | 08:23 AM
  #49
Jay'Z's Avatar
Jay'Z
Originally Posted by SpoilsofWar
Yeah that is what I figured. Has anyone tried to remove the cork gasket and use a different gasket material for boost purposes? Or maybe RTV.
I may try it for giggles, why not. If it fails, I'll go back to the oem upper plenum.
Bro.. lol U think i havent tried that.. I did it twice.. Two different RTV material too.. But maybe you know something i dont.. lol.. Try it.. If you get better success your the man!! Then let me know what in sweet baby jesus name you did to acheive the impossible..
Old May 3, 2008 | 08:27 AM
  #50
Zivman's Avatar
Zivman
What happens is the plastic flexes when you tighten the plenum down. The cork blows out between the bolts. Even with another type of gasket, you still have the warping/flexing of the plastic which causes leaks
Old May 12, 2008 | 04:33 PM
  #51
Jay'Z's Avatar
Jay'Z
Wat is the fix for this???
Old May 12, 2008 | 04:53 PM
  #52
SpoilsofWar
A different plenum?
My kinetix held multiple 8psi pulls on the dyno the other day... But we ran out of time so we couldn't get the high boost map started. So the most it saw was about 8.5lbs.
No leaks, although I am still probably going to replace it with something else. But I might leave it on for the high boost tune session, and just bring the new plenum, and if it blows then I will replace then.
Old May 12, 2008 | 08:45 PM
  #53
350Z400rwhp's Avatar
350Z400rwhp
I have been reading this thread and reading about your build over the past few months. You have done so much and have now been successful as a DIY'er, why put a weak link in there with a plastic manifold. IMO the risk clearly outweighs the reward (though I still haven't figured out what the reward is). If any of that plastic happens to get sucked in your motor if it were to blow your engine would be toast. Just do the powerlab spacer with a stock manifold for $200 and sell your kintex. You would probably break even. Great job on everything though and good luck!
Old May 14, 2008 | 05:17 PM
  #54
diwun67's Avatar
diwun67
I know what you guys are talking about When do you plan on getting some high boost numbers?
Old May 14, 2008 | 08:26 PM
  #55
zmedic16's Avatar
zmedic16
im lost here. what little secret are we talking about? wastegate relocation?? if i remember there was a gtm car with a stock turbonetics system making upwards of the 520whp??
Old May 15, 2008 | 07:34 AM
  #56
sam-z's Avatar
sam-z
I made 482hp 490tq on dyno dynamics with corrections tuned by mrc
Old May 15, 2008 | 07:37 AM
  #57
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
lookin' good!
Old May 15, 2008 | 07:38 AM
  #58
zmedic16's Avatar
zmedic16
^ i met your brother when i went over to mrc to get my car tuned. cool peoples.
Old May 15, 2008 | 07:42 AM
  #59
SpoilsofWar
I am in Georgia right now for an Army school... When I get back in a few weeks I will be making a few small changes to the car then getting it back on the dyno for a high boost map. Still debating adding meth injection, still thinking about doing a nitrous setup.
BTW, is anyone else running a TN setup on a low compression engine (Taurran not included, his kit is nowhere near normal) ? My pistons are 8.6:1 Arias', and with the thicker HKS head gaskets I am thinking the CR is even lower. The car is really begging for more boost.
Old May 15, 2008 | 07:49 AM
  #60
sam-z's Avatar
sam-z
yes my motor is fully built with 8:5:1 comp with aem meth
