JWT 530BB TT Power Increase Suggestions...
Old May 20, 2008 | 10:47 PM
DMK's Avatar
DMK
More boost = more stress on the engine. Higher chance of knock because of the increased heat which can lead to engine failure. 400whp @ 12psi is worse the 400whp @ 7psi.
Meth is guaranteed power increase at same boost level and will actually be safe if not safer for your engine at your current settings. I've seen gains of almost 100whp with just Meth injection.
Old May 20, 2008 | 10:58 PM
wannabuy350z's Avatar
wannabuy350z
I may just do that, on the hunt for a good ems
Old May 20, 2008 | 11:11 PM
heyitzalex's Avatar
heyitzalex
test pipes, motordyne spacer, and a better ems with a good tune should get you 400whp.
Old May 21, 2008 | 04:03 AM
Alberto's Avatar
Alberto
Cranky FI Owner
30whp @ this level wont feed the addiction. I wouldnt even spend the $$$$ for those gains on a stock motor.
Old May 21, 2008 | 08:09 AM
Mr350Z's Avatar
Mr350Z
I was in the same boat not to long ago. I too have a stock motor with a JWT 530 kit. I added test pipes and the plenum spacer along with retune and was able to bring it up to ~380 rwhp at 7 psi. A/F is in the low 10s, so it's conservative. But keep in mind that you're going to run out of injector at around the 400 rwhp. Easy and cheap solution is to add the VK56 410 injectors and bump the boost to 8-9 psi with a meth kit. That should net you about 420 rwhp. That's my plan anyway. Beyond that HP level....I would look to build the bottom end.
BTW, while on the subject, whats the most cost effective meth kit to buy?
Old May 21, 2008 | 08:15 AM
wannabuy350z
go on to summitracing.com and you should be able to find some. between 200-400
Old May 21, 2008 | 04:19 PM
c3 rolling's Avatar
c3 rolling
Test pipes, spacer, Utec, Meth injection and tune at GTM
Old May 21, 2008 | 04:26 PM
wannabuy350z
gathering extra cash right now from online sales and I will do it.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
codek
Sep 28, 2015 03:03 AM
