air bag light on with utec/turbonetics install
Old May 27, 2008 | 05:49 PM
twinstang's Avatar
twinstang
Default air bag light on with utec/turbonetics install
Has anyone had there air bag light come on after installing a Utec. I did the whole install myself and double checked the wire's behind the glove box and they seem to be ok, I also unplugged the battery over night and still unable to get the air bag light to go out. Could the utec be doing this ?
Old May 27, 2008 | 05:54 PM
hr2burn's Avatar
hr2burn
I dont have that....once in awhile I get the P1444 code. Something is not right....
Old May 27, 2008 | 06:05 PM
SpoilsofWar's Avatar
SpoilsofWar
Utec will not do it in and of itself... Chances are 9/10 that you somehow messed up the airbag wiring when you were installing the utec; pinched/cut/shorted... something.
Old May 27, 2008 | 06:06 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
most likely something got unplugged and the key was turned on while unpluged and left a code in it even if it was plugged back in. take it to the dealer.
Old May 27, 2008 | 06:07 PM
TSG-Z's Avatar
TSG-Z
Mine is on with the UTEC also.
Old May 27, 2008 | 06:59 PM
SC 350Z's Avatar
SC 350Z
blown fuse? uncommon but some times after having hte battery unplugged when you plug it back in the surge blows fuses some times
Old May 27, 2008 | 09:14 PM
anotheraznguy's Avatar
anotheraznguy
after i did the full tt kit install
my airbag light blinked.
just reset it and it should be ok
Old May 28, 2008 | 03:34 AM
twinstang's Avatar
twinstang
How do you reset it do I have to bring it to the dealer ? I tried doing the reset with the gas pedal and brake but know that the Utec is in the car Im unable to do the reset
Old May 28, 2008 | 06:24 PM
littlegbuddy's Avatar
littlegbuddy
That will not reset the air bag.
Here is how I have reset mine on my G35 coupe.
you will use the key and watch the airbag light. when you first turn on the ignition you will notice that the airbag light comes on solid for a few seconds, turns off briefly the comes on and stays on.
first turn on ignition to run position (not start)
watch the airbag light when it initially goes out, immediately shut off the ignition. count to about 5 then repeat this step 2 more times.
after the third time, shut off the ignition. if done correctly the next time you turn on the ignition the light should come on for a few second, go out and stay out.
If you dont get it the first time try again. It took me a few times to get it.
Hope this helps
David Clark
Sound Xpression
602-438-0352
www.soundxpression.com
Old May 29, 2008 | 09:03 AM
twinstang's Avatar
twinstang
Thumbs up
Thanks I think that is my problem, I hooked up the batt. to move the seat back with the air bag sensor unplugged.
Old Jul 4, 2008 | 07:24 AM
twinstang's Avatar
twinstang
Hope this helps
Thanks littlegbuddy I finaly got around to clearing the air bag light with your help worked great.
Old Jul 8, 2008 | 06:58 PM
littlegbuddy
You're welcome. This trick works on most late model nissan/infiniti cars trucks and SUVs. Glad I could be of some help!
David Clark
Sound Xpression
602-438-0352
Old Jul 9, 2008 | 02:00 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
I gotta try this Air Bag reset but does this work with an aftermarket steering wheel?
Old Jul 9, 2008 | 02:32 PM
TayTaythatsme04's Avatar
TayTaythatsme04
have the same problem as the OP, but Ive reset the light many times and it comes back after about 15mins
T
Old Sep 3, 2010 | 08:05 PM
Mr_pharmD's Avatar
Mr_pharmD
T
i have this issue now.
I reset it and it keeps coming back.
Will the air bag not work now?
Old Sep 3, 2010 | 08:59 PM
graffkid732's Avatar
graffkid732
https://my350z.com/forum/maintenance...-blinking.html
Check here, just search air bag reset. This thread has how to reset it, and I know there are more. I just looked into this a few days ago as well. Going to try it tomorrow.
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
samansharif
Sep 25, 2015 12:31 PM
