catch can question
Old Jun 16, 2008 | 10:53 PM
Mr_pharmD's Avatar
Mr_pharmD
Default catch can question
Okay, I need your input. Is a greddy catch can or any catch can going to catch all the oil if there was no baffle inside to collect the oil? Will it catch any oil or is it useless without the baffle?
Old Jun 17, 2008 | 08:31 AM
rcdash's Avatar
rcdash
I believe the amount of oil vapor filtered will vary depending on the amount of surface area that the oil has to condense upon. The more there is, the more oil will condense out.
Old Jun 17, 2008 | 08:58 AM
GTM's Avatar
GTM
Vendor - Former Vendor
If there is no baffle, then it is just a pretty can in your engine bay
Steel wool FTW!
-George
GTM
Old Jun 17, 2008 | 09:45 AM
SpoilsofWar's Avatar
SpoilsofWar
I'd have to disagree with you slightly, George.. I use the homemade air/water seperator catch can method from the DIY section, and there is no baffle in it. It certainly does catch oil.
Now others have put steel wool or other material for oil vapor to condense on and have reported marginally more oil caught then before, but regardless, the lack of a baffle does not make your catch can "just a pretty can in your engine bay". At least not with the homemade version. That being said, I will probably try it out with some steel wool soon, to see if it makes a noticible difference.
Old Jun 17, 2008 | 10:02 AM
Spork's Avatar
Spork
IMO, as long as there's a certain path that the air has to travel (not straight through), oil will be able to consense into the container.
Old Jun 17, 2008 | 10:34 AM
GTM's Avatar
GTM
I was referring to most of the catch cans on the market, the home-made version is far from pretty
Since the home made version is already a filter in itself, it will work better than the traditional after market can which is shinny aluminum with just 2 hoses going into it.
Hope that clears up what I meant
-George
Old Jun 17, 2008 | 11:24 AM
chromesilver6's Avatar
chromesilver6
I have the Greedy can and installed a small piece of foam on the inside to help catch the oil. Works great and i change it every so often.
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
