drill spot for extra vacuum line?
Old Jun 23, 2008 | 04:56 PM
frankie945's Avatar
frankie945
Default drill spot for extra vacuum line?
Does anyone have any pic's were they drilled there factory upper plenum for a extra vacuum line.Or were to drill ? I need a line to my map sensor and I already have to many coming from my factor fitting. Any help would be great have a appointment to get it tuned Wed.
Old Jun 23, 2008 | 05:07 PM
TinmansZ's Avatar
TinmansZ
Instead of tapping your plenum you might want to think about a throttle spacer. I did and it works great. http://z1auto.com/prodmore.asp?model...ne&prodid=2414
Old Jun 23, 2008 | 05:11 PM
350Z400rwhp's Avatar
350Z400rwhp
Default Here ya go, hope this helps.....
I would drill and tap for each line you run into your manifold, don't use T fittings and hook multiple lines to a single bung.
Old Jun 23, 2008 | 05:34 PM
MDeezy's Avatar
MDeezy
throttle spacer looks like a good choice, give you 3 extra lines, plug those that arent needed. Its a little costlier than buying a tap, but if you dont have a drill and drill bits, I think the throttle spacer would be the best option.
Old Jun 23, 2008 | 05:48 PM
wannabuy350z's Avatar
wannabuy350z
why are you asking the same question twice in the same section?
Old Jun 23, 2008 | 06:00 PM
frankie945's Avatar
frankie945
did not mean to double post!
Old Jun 23, 2008 | 06:01 PM
SpoilsofWar's Avatar
SpoilsofWar
Powerlab makes a really cool vacuum distribution block. I would have one of those, but I already had the AAM throttle body spacer w/ 3 ports.
Old Jun 23, 2008 | 06:02 PM
frankie945's Avatar
frankie945
Thanks for the pic I thought under the brake booster would be good just wanted to double check. I have a appointment wed for a tune and need to get it done asap. Went turbo sold procharger
Old Jun 23, 2008 | 06:06 PM
QuadCam's Avatar
QuadCam
here's my setup.
drilled and tapped the upper plenum and am running a dedicated -6AN line into a vacuum manifold.
Old Jun 23, 2008 | 06:11 PM
350Z400rwhp
Originally Posted by QuadCam
here's my setup.
Is that like an external manifold to provide multiple ports to tap off of?
Old Jun 24, 2008 | 02:37 AM
Quamen's Avatar
Quamen
here's my setup.
I did the same exact thing on my car (tapped location and manifold location) and it works great. I made my vacuum manifold out of some extruded -10 fuel rail though from Ross Maching Racing.
Old Jun 24, 2008 | 05:01 AM
QuadCam's Avatar
QuadCam
That's funny. My first vacuum manifold, I made from Fuel Rail stock, too.
I was running a manual boost controller at the time, and this manifold was for feeding the side ports of my wastegates. (I am running -4AN preassembled nitrous lines as my vacuum lines to the wastegates.)
Old Jun 24, 2008 | 05:59 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
we usually just tap the upper plenum on the back side of it. clean and effective.
Old Jun 24, 2008 | 06:18 AM
frankie945's Avatar
frankie945
drilled a hole last night under the brake booster line thanks for all the help.
Old Jun 25, 2008 | 08:33 AM
NETSHARK's Avatar
NETSHARK
I like Andrew`s setup alot !! its so clean and mean, i`ve ordered this Vacuum Manifold its so damn small !!
http://tunertoys.zoovy.com/c=1mm35oq...vic_turbo.html
it got two 1/4 NPT ports and five 1/8 NPT ports and its only for 29 bucks.
Old Jun 25, 2008 | 08:48 AM
Crom's Avatar
Crom
here's my setup.
Nice....
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
