WTF is up with my car! Weird electric issues!
Old Jun 27, 2008 | 08:44 AM
Blackbird CPV35's Avatar
Blackbird CPV35
Default WTF is up with my car! Weird electric issues!
I recently finished my engine build and was breaking it in on stock injectors and ECU and it worked perfectly fine for 500 miles. Then I installed the Haltech Platinum and RC 1000 CC injectors and trailered the car down to Hal at Injected Performance.
Now here is the issue, we got the car on the dyno and it would start up and Idle fine except for the occaisional misfire. However when we put any throttle into it the car would cut out completely and the RPM signal would drop to 0 for a split second on the data log. The occaisional misfire at idle was also the RPM Dropping to 0. Hal took an oscilliscope to the CAS wire and it was showing some pretty erratic voltage, so we changed the CAS 3 times and it didnt resolve ths issue. I ended up taking the car home and swapping the clutch and flywheel out with a stock flywheel bc I thought it was an issue with the crank trigger. The issue is still there with ths stock flywheel though!
here is everythign I have done so far with no resolution
Changed CAS 3 times
Changed the Haltech and the patch harness
checked all wiring
Swapped the clutch and flywheel out to stock
grinded down the CAS so it would sit closer to the flywheel
Absolutely nothing has worked and I am at the point where I am just going to give up and sell everything.
If anyone could chime in i would appreciate it
the build specs are:
03 G35 Coupe
RC 1000cc injectors
Forged Performance Short Block
+1mm oversized valves, GTM Cams, Ported heads
Haltech Platinum
APS Extreme TT
Greddy Evo TT Exhaust
GTM Exedy Triple Carbon Clutch
Thanks,
Jason
Old Jun 27, 2008 | 09:17 AM
350Z400rwhp's Avatar
350Z400rwhp
Don't know what to tell ya but hang in there man. I know how frustrating mystery problems can be! That $hit happens to me all the time with my toys. Someone on here will know the answer.
Old Jun 27, 2008 | 09:36 AM
moog's Avatar
moog
Have you tried contacting Haltech for support?
Old Jun 27, 2008 | 10:56 AM
Blackbird CPV35
when I was at Injected, the US rep for Haltech was also in house and he told me that Hal pretty much knew more about the 350z haltech than anyone else. Hal has been helping me out on it but so far we are stumped.
Old Jun 27, 2008 | 01:58 PM
rcdash's Avatar
rcdash
Ok, you changed to the Haltech and changed injectors and ran into issues. It's more than likely related. Hal is brilliant, so if he can't figure it out or didn't have time, you just have to use a process of elimination:
0. Go back to stock injectors and ECU and see if it starts working normally.
If it does:
1. Swap Haltech harness cables. (done already)
2. Swap Haltech units. (done already)
3. Swap injectors out (return to RC for QC).
If it doesn't start working with stock injectors and ECU, then post back up. I don't think it's the Haltech as that is a rock solid piece of equipment. I do not trust RC injectors though. Take that manifold off and swap them out!
The other thing to check is the wiring around the injectors. Possibly a connector is swapped (unlikely) or a harness is damaged? If the stock injectors give trouble, that would be the next thing to look for. I'd look at a FSM for where continuity should exist for the harness connectors and trace them back to the ignition circuitry. You could check all the ground wires very easily while you are swapping injectors... (I presume one of the leads is a ground wire that goes to each injector)
Old Jun 27, 2008 | 04:54 PM
Blackbird CPV35
If it does:
holy ****, you are a ****ing genius. I swapped out the injectors and that was it. I feel like such a retard right now for not doing that first.
If I ever meet you I am buying you dinner and a beer
now i gotta put the damn triple disc back in
Old Jun 27, 2008 | 06:33 PM
rcdash's Avatar
rcdash
Another RC injector quality control issue.
HKS injectors FTW! Glad it worked out for you.
Old Jun 27, 2008 | 07:25 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Wow. we went from no hope, to celebration in two posts.....not bad!
Old Jun 27, 2008 | 09:53 PM
overZealous1's Avatar
overZealous1
hahhaa, aren't cars fun!!!
Old Jun 27, 2008 | 09:58 PM
doug's Avatar
doug
damn.. a couple more posts and he was going to start selling everything for cheap.. damn you Raj
Old Jun 28, 2008 | 04:00 AM
Blackbird CPV35
i still have no clue why the injectors would be related to the weird voltage on the CAS though...
Old Jun 28, 2008 | 05:48 AM
MADScientist's Avatar
MADScientist
Well if the injectors are no firing properly on multiple cyls then you would be able to see that in the CAS with a erratic signal... At an idle I would think this would show up more than at high rpm since you don't have the faster momentum of the rotating assembly to keep the crank spinning.
Old Jun 28, 2008 | 06:42 AM
WhiskeyHotel's Avatar
WhiskeyHotel
To me, this was a trouble shooting no brainer. You change the injectors, they f the car up, you change 'em back and see if that was it.
Old Jun 28, 2008 | 07:35 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Wow!
That was a close one!
Last thing we need is more parts in the classifieds... Glad everything worked out for you. and your to young in your build to sell everything. Hang in there!
Old Jun 28, 2008 | 08:59 AM
Sharif@Forged
Forged Performance
LOL...you are evil!
Old Jun 28, 2008 | 09:12 AM
Blackbird CPV35
thats what i would have thought too, and I was actually going to do that first but I didn't see the connection between the CAS and injectors
aarrgghh
May 1, 2022 11:04 AM
hulkout
Tuning
Sep 18, 2015 05:42 AM
Katie93
Sep 15, 2015 05:57 PM
PureR3d
Sep 10, 2015 06:23 PM
Darkspy
Sep 7, 2015 09:09 PM
