Bell Housing Bolts, anyone know the size i need?
Old Jul 10, 2008 | 05:19 PM
jining's Avatar
jining
Default Bell Housing Bolts, anyone know the size i need?
Hey guys, trying to get a motor up on an engine stand, but I dont have the proper bolts that attach the bell housing to the motor.
Anyone know what size and pitch I need?
Thank you!!
Aaron
Old Jul 10, 2008 | 05:45 PM
chris'smax's Avatar
chris'smax
take the bolts that bolt the tranny to the motor to a bolt supply store and they should be able to match them up on the spot. Bolt supply stores are life savers
Old Jul 10, 2008 | 05:50 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
if your engine stand is like most the stock bolts wont be long enough you can use the bolts from the fake water pump out of the front of the motor. they are long enough and right thread pitch.
Old Jul 11, 2008 | 06:38 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
lol @ the fake water pump...
Old Jul 11, 2008 | 12:09 PM
MDeezy's Avatar
MDeezy
I'd suggest getting some from homedepot/hardware store. Dont want to bend the bolts from the engine.
I had my DE on the stand and when I finished working on it, and loaded it with accessories I saw it drooping a bit. After I lifted the motor I noticed the bolts were bent.
Old Jul 11, 2008 | 12:16 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Did you only use two bolts??? I used four and had all accessories on the motor plus turbos and manifolds and had no bent bolts to speak of.
Old Jul 11, 2008 | 12:17 PM
MDeezy's Avatar
MDeezy
All four. I was using Home depot bolts. Grade 8 thought. I had it on the stand for a little while. from when it was just the block, all the way up to the heads. I leaned on it a lot, torquing etc... maybe it was just me.
Old Jul 11, 2008 | 12:22 PM
h2kSPiG's Avatar
h2kSPiG
M12x1.75 x 80mm Grade 8
That is what I used.
