Did detonation cause this? UPDATED PICS Pg: 5
Old Oct 6, 2008 | 03:40 PM
  #81
Blackbird CPV35's Avatar
Blackbird CPV35
Originally Posted by thom000001
0 compression??? wow....hope for a hung up valve. Other wise you burned a hole in a piston (or at least burned part of it away)
Next go around no the limits of all your parts (internals, fuel, plugs, computer, etc), and remember
quick 1000 times is better than fast 1 time
Tom
I like this quote better
"If you can't afford to do it right the first time, how can you afford to do it a second time?"
or in this case a 3rd time
Old Oct 6, 2008 | 03:56 PM
  #82
RMichael's Avatar
RMichael
OP...sry for your loss....but reading the whole thread you seemed to be pretty cavalier without a properly tuned motor....I would have called something like this happening. GL nevertheless. Gonna be a fun winter.
Old Oct 6, 2008 | 05:21 PM
  #83
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
350Rookie.
Take the longblock apart, and send us the shortblock. Don't take the shortblock apart please, becuase we need to inspect a few things before teardown. We can rebuild it for you again. Hopefully it just needs one piston, fresh set of rings, and machining. It's not the end of the world.
I am not going to repeat with others have already said, but tuning and fuel is so critical. You are the first person to ever break one of our engines/pistons....so hope that makes you feel a little bit better....or maybe worse....
Well anyways, just send it back.
Old Oct 6, 2008 | 06:25 PM
  #84
350 Rookie's Avatar
350 Rookie
Originally Posted by Sharif@Forged
350Rookie.
well tomorow, im gonna inspect the head to make sure its not the valve thats stuck open or atleast damaged.
hopefully it is the valve.
as being the first person to break your blocks, im gonna call Guiness World Records and let them know.
Ill keep you updated
Old Oct 6, 2008 | 06:45 PM
  #85
Sharif@Forged
Forged Performance
OK...sounds good.
Old Oct 6, 2008 | 07:13 PM
  #86
edd2045's Avatar
edd2045
yo if you need any help let me know so i can get up tomorrow
Old Oct 6, 2008 | 07:25 PM
  #87
SpoilsofWar's Avatar
SpoilsofWar
I was just sipping a beer and thinking, maybe it wasn't the plug that disintegrated - maybe it was a chunk of piston or burnt valve that took out the electrode.
Old Oct 6, 2008 | 07:30 PM
  #88
edd2045's Avatar
edd2045
you might be on to something, i do the same while sitting back eating mac and cheese...lol
Old Oct 6, 2008 | 08:59 PM
  #89
SpoilsofWar
Also OP, did you pull the turbo and check the turbine side to make sure there is no damage, if indeed some debris did exit the exhaust valves?
Because I see that you have the kit up for sale in the marketplace, and I wouldn't want to see you sell someone a chewed up turbo - accidentally or not.
Old Oct 7, 2008 | 09:10 AM
  #90
350 Rookie's Avatar
350 Rookie
true. im takin the turbo out soon either way. ill make sure thats not damaged.
too bad i didnt get to try the oil reducer right. lol. dammit.
Old Oct 7, 2008 | 09:11 AM
  #91
350 Rookie's Avatar
350 Rookie
Or maybe the rod shot up and took out the plug
Old Oct 7, 2008 | 03:09 PM
  #92
350 Rookie's Avatar
350 Rookie
Alright guys, here are updates. Head is finished. Im not sure if it can be welded and redone.
The walls on CYL 3 do not seem that bad. It does look like its scored up bad but it does not even catch my finger nail. However the piston is kinda dinged up. Im gonna see what sharif says about this. I can feel a grand or 2 waitin to drop off my pockets. Dammit
Here are pics
Another thing i noticed, my crank pulley is cracked. So i also gotta replace that. might as well go with an aftermarket one. Any suggestions?
Old Oct 7, 2008 | 03:42 PM
  #93
Blackbird CPV35
did you have any strange noises coming from the engine as a result of that cracked pulley
Old Oct 7, 2008 | 03:45 PM
  #94
SpoilsofWar
Head is done, not worth the risk or hassle of trying to fix it when used heads are cheap and easy to find.
As for the bore, you might get away with just a rehone. Like you said, leaving it to Sharif's discretion is the best idea. Does that block have stock 95.5mm pistons or 96mm in it?
Old Oct 7, 2008 | 03:48 PM
  #95
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
damn!! can you believe what a bad tune can do? you would of saved $2000+ if you had a good tune.. thats no more than 500$ at MRC. Good luck! , hope you learned something out of this.
Old Oct 7, 2008 | 04:54 PM
  #96
DracoLancet04Z's Avatar
DracoLancet04Z
sucks bro
Old Oct 7, 2008 | 05:49 PM
  #97
thom000001's Avatar
thom000001
I wouldn't mess around with that head, start looking for a used head.
As for the piston and cyclinder walls...I dunno....leave that one to the pros to decide.
Check the turbo too, those pieces had to go somewhere.
Next time, tune tune tune tune
Old Oct 7, 2008 | 05:56 PM
  #98
Sharif@Forged
Forged Performance
I hate seeing pictures like this. Well, it looks like the S1 Shortblock held up fine....it was the valve that wasnt so lucky. Look at the bright side! You do all your own work, so you save a bundle!
By the looks of those pics, the cylinder walls can be lightly honed. Replace the cylinder head with another stock one...I have plenty on the shelf that we use as cores. And some new rings, and maybe one new piston.
Old Oct 7, 2008 | 06:07 PM
  #99
Jay'Z's Avatar
Jay'Z
Nice pics!! Bad situation..
Old Oct 7, 2008 | 07:23 PM
  #100
350 Rookie's Avatar
350 Rookie
well actually, ever since my turbokit went on the car, ive been hearing some very light knocking noises but i NEVER figured out what it was. mostly at idle. other than that, no
