My Build: The Good, The Bad & The Progress
Now that I am legal again, I'm down
, if it helps, your car looks faster.
My local mechanic found a couple of small issues during inspection today. The drivers side coupler on the intake near the intercooler is rubbing against a piece of the underbody, the AC line is sitting aginst the same pipe and may be prone to pre-mature failure unless wrapped a bit and the steering knuckle is catching on the drivers side turbo housing when the car is cold.
Other than that I got my exemption and tires put on today with a warning from the tech not to get into the throttle for at least a day and/or 50 miles so the tires will seat solidly. He was concerned that the rim may spin inside the tire with power the car has. I have also started the ball rolling on moving the title to FL so inspection and emissions are a thing of the past
, if it helps, your car looks faster.My local mechanic found a couple of small issues during inspection today. The drivers side coupler on the intake near the intercooler is rubbing against a piece of the underbody, the AC line is sitting aginst the same pipe and may be prone to pre-mature failure unless wrapped a bit and the steering knuckle is catching on the drivers side turbo housing when the car is cold.
not likely on the street.....especially if temp is cool/cold....tires will just spin away
tom
tom
inspection/emissions.........what is that??
.........J/K
Dyno pull, hopefully some street vids coming soon.
Coming soon... Streetfire FAIL
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid556.photobucket.com/albums/ss9/cassese007/Dyno1.flv">
I heard FL just adopted horrific CA regulations... Not sure if its true but you might want to check it out. Maybe Terry can give us the inside scoop if something is coming...
This may be fast upload... photoucket blows
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/NNHdVkBXZJs&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/NNHdVkBXZJs&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
Chris, if you want I can host your vids on my flickr (I have a pro account). It whoops the **** out of photobucket.
Maybe than it was just one of the vids of someone pulling the car out of the garage that sounding like the driver was pedaling the car to keep it alive. If that's not the case than I stand corrected.
I'm also thinking FL is looking like a good place for a 2nd residence!
