New car New Problems... eff my life!
with the TN setup, it takes the stars to align to make even 500... doubting you would be happy with the power that kit can make. Even if you put a larger turbo on it, you will basically have to redesign the kit to incorporate large enough piping to make the larger turbo worth it -> look at Tauran's build. Throwing 6-10 grand at a motor build for a TN kit is not worth it. The selling point, if there is one
, of the TN kit is its integration with a stock setup.
I noticed that after I made my post.... the kit didnt take that much to pull those numbers out. To me it looks like if you take the basics steps that everyone takes to make power i.e. cams meth boost built good tune that it make good power. and the low end torque is nice too!
I never expected to get this kit and just add boost and be magically 600whp...
if anyone has a turbo and wants to go for big numbers they almost always have to switch turbo setup's, fuel, cams, etc.... its pretty much a given at least from i have seen in the past and have experienced
what in my post made it seem so simple?
cheer up man! did you have a bad experience or something.
the car has a built motor not sleeved so its good to around 650 maybe a little less since this turbo make a considerable amount more torque than hp.
already got the meth kit in my trunk.. not planning to stay with this turbo either. the car has a utec with nine map selector so 100 even 110 is pretty easy for me to switch to especially since I got it like 10miles from my house.
And now:
No, just seen more than one thread like this before. A lot of dreamers out there
And now:
If I were a betting man, I would say that motor is junk, and may even go so far as saying that it is junk for even a core. IMHO you will be looking at a full rebuild or at least a replacement stock motor. Again, good luck, you will need it
this isnt going to be my daily driver...
the car I was talking about is for sale loooke for "red hot Z"
No one has still said why the kit cannot make high numbers? I get that the kit doesnt come with the fuel required nor the prefferable turbo to do it.
Glad you clarified.
Second, the limitations of the Turbonetics kit have been discussed several times in prior threads if you do some searching. You are not the first person who has tried to push the limits of the Turbonetics kit beyond it's design specifications and it's intended power capabilities. Taurran's build thread was the most convincing at showing the restrictions of the relatively small diameter piping of the kit. JT at Performance Factory had to replace nearly all the original piping with larger diameter pipes. They tried to troubleshoot and did it one section at a time. They discovered restriction after restriction that necessitated larger piping to facilitate flow and efficiency.
How and why do you think the PowerLab kit was created? Because there was demand from unsatisfied Turbonetics and APS single turbo customers for a single turbo kit with higher power potential. There wasn't another single turbo kit available on the market at the time that was more capable. Hence, why you saw a lot of guys switching from Turbonetics kits to twin kits like Greddy, APS, and JWT.
PowerLab did their research and dissected the Turbonetics kit. The conclusion was that much of the piping was too small in diameter. Therefore, the PowerLab kit utilizes 3" diameter piping including a true 3" outlet at the turbo compressor with a true 3" downpipe, as well as 3" piping all the way to and from the intercooler. The result is a kit that has such tight fitment that it requires a tube of KY, some slow jams, and a competent installer to get it all to fit just right.
I still think the PowerLab kit makes more sense for your stated power goals on a single turbo. Past experience from other members has shown that the Turbonetics kit is a royal PITA to try and get big numbers out of, even with significant modifications and $$$.
Good luck to you if you decide to continue with your stated plans.
THANK YOU!!!!!
geez i knew someone would come through!
much appreciation.
ok so now i know where I stand and should decide pretty soon. I think low2mid 5's isnt too far off my original goal so I could settle for that. that is if the motor isnt too effed up
much appreciation.
Last edited by forced_04; Dec 16, 2008 at 05:58 AM. Reason: ninja grammatical error...
SpartanZ32
Oct 22, 2015 09:36 AM
