Car Wont Start
Old Dec 27, 2008 | 04:51 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Default Car Wont Start
Ok So Monday, I drove the car up the street and back put it away with nothing particularly wrong just the typical cel light and engine lights that had been on since I boosted it.
-The car
JWT 530
Haltech
600 Dwerks
The temp was 35 degrees two days ago and 73 today, and now the car just turns over but nothing happens.
Old Dec 27, 2008 | 05:00 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
try another key.
Old Dec 27, 2008 | 05:04 PM
JETPILOT's Avatar
JETPILOT
Pull codes!
Old Dec 27, 2008 | 05:06 PM
doug's Avatar
doug
yup codes.. it could be Crankshaft POS Sensor ... it could be Fuel ... It could be the Imobilizer in the Key
the thing about being FI and having codes is you ignore the light because you had codes prior.. but sometimes other codes come and you don't know because you been igonring them.. thats what happened when i had Camshaft POS Sensor go on me.. i kept ignoring the codes till my VDC and SLIP lights came on
Old Dec 27, 2008 | 11:00 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Hey, give me a ring on my cell tomorrow if you are still having trouble. I pm'd you the number in case you did not have it.
Old Dec 28, 2008 | 05:55 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
Codes:
P1281 Fuel Air Metering
P0021 Cam Sensor Camshaft position actuator bank 1 timing over advanced
Old Dec 28, 2008 | 07:52 AM
KPierson's Avatar
KPierson
Neither of those should keep it from starting (at least on a stock ECU).
Can you hear the fuel pump prime when you turn the ignition on?
Any possible chance you could have blown an ignition fuse?
I believe I read with the Haltech it will start up and run without a programmed key since the Haltech controls fuel and spark directly so I doubt the issue is with the immobilizer.
Is it possible to remove the Haltech and go back to the OEM ECU for troubleshooting?
Old Dec 28, 2008 | 11:38 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
need a little more to work with. With the key in the on position, is the CEL on?
Old Dec 28, 2008 | 12:05 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
KPierson: Fuel Pump does prime, My tech tom shows ignition of 6 to 9 degrees. I am incapable of pulling haltech for fear of damaging something.
Not sure what you mean Sharif
I have tried both keys, but haven't tried the valet. Come to think about it i unlocked the car with the valet one night but never started it. I doubt this would have an effect.
All my fuses have been checked and rechecked, all fluids have been checked as well.
I am thinking moisture in the air from the extreme temp change may have fowled my Crankshaft sensor or something odd but am not sure. I hope there is an easy fix and I am just over thinking it.
Old Dec 28, 2008 | 02:15 PM
JETPILOT's Avatar
JETPILOT
1281 Bank 2 Drivers side: Air fuel ratio (A/F) sensor 1 circuit no activity detected.
0021 Bank 2 Divers side: Intake Valve Timing Control. There is a gap between angle of target and phase-control angle degree. ECM enters failsafe mode.
Old Dec 28, 2008 | 02:35 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
thanks jet but i doubt that either of these will kill the car it threw thos codes same day it was tuned been driving it mos after.
Old Dec 28, 2008 | 03:10 PM
Sharif@Forged
Forged Performance
Those are codes are simply the result of having the Haltech control Cam angles...that isn't the problem.
What I was asking you, is to goto your car, and turn the key to the ON position...don't start the car, but turn the key on. Now, is your check engine light illuminated??
Old Dec 28, 2008 | 05:21 PM
KPierson's Avatar
KPierson
Is there a particular reason you don't want to bypass the Haltech? With most systems it is OK to bypass them as long as you don't actually drive the car.
It is much easier to troubleshoot engine managment issues when you can eliminate as many variables as possible - that's why I brought it up. But, I'm not familiar with the Haltech so I don't know for sure if it would be safe to do that. Maybe Hal can comment?
Old Dec 30, 2008 | 01:20 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
I did not want to bypass the haltech mainly because I am not smart enough then to fix something with that if it were to go wrong.
However, i was able to get the car running through good old magic!
I called Hal and he yelled at the car and it started for me.
Old Dec 30, 2008 | 04:42 PM
KPierson's Avatar
KPierson
haha
Old Dec 31, 2008 | 05:35 AM
Reality350's Avatar
Reality350
LoL!
aarrgghh
May 1, 2022 11:04 AM
Ronso
Oct 30, 2015 12:39 PM
OdesiTT
Sep 30, 2015 10:47 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
