My winter project...turbo fabrication
Old Jan 3, 2009 | 07:14 PM
  #61
BoostedProbe's Avatar
BoostedProbe
Originally Posted by JonnyC
Since I have nothing better to do on a Saturday night...
Sorry for the bad pic, best I could get with my car being put away for storage.
I believe that is 2" pipe there though. Watch out for the sway bar though when the suspension decompresses, as I think the earlier kits had some rubbing issues.
Thank you very much for the picture. Apreciate the input.
That most def. does not look like a 2.5" piece of pipe. The car is on stands right now, so I took the floor jack and put it under the passenge side wheel and lifted it up. This way I can see where things sit when the car is on the road. It seems like there is enough room for a 2.5" pipe there but it has to be positioned just right. I will probably weld a bracket on some tubing and have it bolt up so it can't move, or I will just use a 1' piece of silicone hose. That way even if it does touch something once in a while nothing will happen, the hose will just compress.
Old Jan 3, 2009 | 07:33 PM
  #62
Jay'Z's Avatar
Jay'Z
Nice.. Id be worried about the piping through that small space though..
Old Jan 4, 2009 | 12:12 AM
  #63
Sylvan Lake V35's Avatar
Sylvan Lake V35
Wow this is moving alot quicker than I thought it will be done in plenty of time for spring.
Old Jan 4, 2009 | 04:36 AM
  #64
MI 35th's Avatar
MI 35th
OGPremierMafia
This is coming along very nicely. As posted above i believe the scavenge pump should take care of the oil return issues.
Old Jan 4, 2009 | 06:37 AM
  #65
XKR's Avatar
XKR
Originally Posted by BoostedProbe
Well, at this point UTEC. I have a brand new one here with map sensor as well as a UTEC tuner with wideband.
If I could get $800 for the UTEC tuner and the UTEC itself with all the accesories I would sell it and get a Haltech. But for now I'll stick with the UTEC stuff.
Why dont you try and sell the Utec while you are doing this project and buy the Haltech....it may sell before you are finished
Old Jan 4, 2009 | 08:00 AM
  #66
BoostedProbe
I will post it in the FS section right away.
Old Jan 4, 2009 | 09:06 AM
  #67
chopperman's Avatar
chopperman
He is working to fast, it will only be up for a day or two
Old Jan 4, 2009 | 09:35 AM
  #68
BoostedProbe
https://my350z.com/forum/turbos-nitr...-complete.html
Old Jan 4, 2009 | 10:26 AM
  #69
XKR's Avatar
XKR
Post it in "Market Place" both on My35z and also G35driver
I tend to agree...he is the fastest I have seen to date
Old Jan 4, 2009 | 11:14 AM
  #70
BoostedProbe
My wife tells me the same thing,
Not a member at G35driver, I guess I will have to register.
I am kind of stuck right now, I need a few 45 deg silicone couplers and maybe a couple of 90's as well.
Old Jan 4, 2009 | 11:40 AM
  #71
JonnyC's Avatar
JonnyC
If you need a good place to order from - http://www.intakehoses.com/
Old Jan 4, 2009 | 04:40 PM
  #72
XKR's Avatar
XKR
Call GTM or Forged...they keep that stuff in stock ...if not JonnyC link is good.
Old Jan 4, 2009 | 04:45 PM
  #73
BoostedProbe
^^thanks for the suggestions on silicone couplers guys, but I found that ebay has the best deals on those. For me it's all about finding someone that can ship for cheap as I am up in Canada. For some reason I get the shaft every time something gets shipped up here.
Old Jan 4, 2009 | 05:43 PM
  #74
Klei14's Avatar
Klei14
I'm sure you already know this, but spend the extra $ and get boost clamps, dont use the regular hardware store clamps. It will save you alot of headaches and keep silicone hoses from popping off the pipes.
Old Jan 4, 2009 | 07:07 PM
  #75
BoostedProbe
These are all I ever use for clamps:
http://www.siliconeintakes.com/image...lt_picture.jpg
You are refering to worm gear clamps and yes they are not made to hold under pressure.
Old Jan 5, 2009 | 07:03 AM
  #76
350 Rookie's Avatar
350 Rookie
Damn nice welds you got. How long you been welding?
I used to weld, then stopped for a few months and now bought a mig welder again but i need to buy the argon gas for it. Welding is like a sport, if you stop doing it, you lose the hang of it.
Old Jan 5, 2009 | 08:11 AM
  #77
BoostedProbe
Funny you say that becaust I was thinking that my welding has deterioreted. It is true, if you don't weld for a while it takes a bit of time to get the touch back.
I am not a welder, it's just something I picked up while working during summer months, about 10 years ago now. I am an Electronics Engineering Tech., but really enjoy fabricating so I guess it's a hobby. It is all tig welded though, not mig. I have never tried mig welding but from what understand it's the easiest out of the 3 basic welding techniques. I am not sure which one is more difficult, tig or arc/stick. I guess it all depends on how much time you spend on each.
Old Jan 5, 2009 | 08:43 AM
  #78
escobar929's Avatar
escobar929
thats sick, great job. cant wait to see it done
Old Jan 5, 2009 | 01:56 PM
  #79
tylerxfire's Avatar
tylerxfire
good job man...i am in it to see the finished results
Old Jan 7, 2009 | 04:59 PM
  #80
Jay'Z's Avatar
Jay'Z
Any updates?
