My winter project...turbo fabrication
Old Jan 11, 2009 | 11:32 AM
  #101
bbs350z's Avatar
bbs350z
in for the final product! get that thing rollling, i wnna see a dyno graph and some numbers!
Old Jan 11, 2009 | 02:59 PM
  #102
Nate76s's Avatar
Nate76s
Man I wish you had a G35 ... I love the concept of this kit and it looks really well designed and built. Great job. I would buy one if I had a Z.
Old Jan 11, 2009 | 03:40 PM
  #103
BoostedProbe's Avatar
BoostedProbe
Thank you for the kind comments guys. It will be a few months before dyno time, do to long winters here. Hopefully April. I am now stuck wating for more parts to come in, I don't want to start with the injectors and fuel stuff untill all the piping is complete.
I still need to get an LSD, don't know if I should get the 1.5 or 2.0. I will have to do some research to see what will be better for my application. I guss I would ultimetly like to buy the entire differential, I keep looking at what's in the for sale sections every day.
I took the oil pressure sensor out today and tried to T off for turbo oil supply. That didn't go so well, it seems like the pressure sensor is not a 1/8 NPT (national pipe thread). I took the callipers out and measured the stock sensor thread, it was 9.7mm. The 1/8 NPT is 10.0mm, not sure what that is all about.
Input regarding this is welcome.
Old Jan 11, 2009 | 03:52 PM
  #104
FredB's Avatar
FredB
I took the oil pressure sensor out today and tried to T off for turbo oil supply. That didn't go so well, it seems like the pressure sensor is not a 1/4 NPT (national pipe thread). I took the callipers out and measured the stock sensor thread, it was 9.7mm. The 1/4 NPT is 10.0mm, not sure what that is all about.
The problem you are running into w/ the oil pressure sensor is because it is not NPT its BSPT. As far as the kit goes, good job i would have done things a bit differently but it should work for your needs just fine
p.s. it's not 1/4 npt its 1/8 bspt
Old Jan 11, 2009 | 04:02 PM
  #105
BoostedProbe
Yes I went back and changed the 1/4" to 1/8", and I see that you beat me to it. The only difference between the BSPT and NTP is that the Brittish (and European in general) threads are "square" and the NPT is "tapered". They are however compatible.
Fell free to comment on "doing things a bit differently".
EDIT:
Straight out of the Turbonetics install manual:
A. Remove the electrical connector and the oil pressure sensor from the engine block (circled in FIGURE 63)
B. Install the 1/8” NPT “Tee” fitting (P/N 30562) into the block in the vacated hole (pointed out in FIGURE
64)
C. Re-install the pressure sensor into the opposite end of the “Tee” fitting
D. Install the 1/8” NPT x –3 straight oil fitting (P/N 30544) into the “Tee” fitting
E. Install the braided oil supply line into the oil fitting from the previous step (SEE FIGURE 64).
Well, so much for that. I guess I need to put some more force behind it.
Old Jan 11, 2009 | 04:31 PM
  #106
FredB's Avatar
FredB
EDIT:
64)
You can thread an NPT into a bspt just fine just not vice versa if you dont believe me ruin the threads i dont really care just trying to give you some advice.
Old Jan 11, 2009 | 04:36 PM
  #107
FredB's Avatar
FredB
no thanks you aren't looking for an efficient 1000hp, so i wont comment on the work thats been done so far.
Old Jan 11, 2009 | 04:43 PM
  #108
tylerxfire's Avatar
tylerxfire
and whats that supposed to mean, with you having 3 posts and all two of them not contributing to anything...this guys doing a great job!! don't see your write up on here of your do it yourself job...maybe i read wrong if so i appologize, but to me seems like you are putting his work down...hmm
Old Jan 11, 2009 | 04:46 PM
  #109
FredB's Avatar
FredB
i said it will suit his needs just fine, calm down amigo he probably sat there trying to thread the npt in a block for an hour and I assisted go back to sitting on the bench
Old Jan 11, 2009 | 04:50 PM
  #110
tylerxfire's Avatar
tylerxfire
oh no another internet tough guy with 4 posts now...holy **** big surprise....you will learn fast to keep ur damn mouth shut with stupid remarks or u will be put in your place...like i said maybe i read wrong....now i will let this go and not be a dick where as i should but ill give a little more time to adjust and im sure somebody will show you where to take your little comments..
sorry to garbage up the thread with a stupid noob guys, proceed with the good work bro.
Old Jan 11, 2009 | 04:52 PM
  #111
FredB's Avatar
FredB
i bet you cant even change your own spark plugs
the DIY is cool im just trying to give an opinion and since i choose to keep my mouth shut about things i would change i'm a noob?
Old Jan 11, 2009 | 04:59 PM
  #112
BoostedProbe
You got it backwards there, and it only applies to threads smaller than 1/2".
Old Jan 11, 2009 | 05:00 PM
  #113
FredB's Avatar
FredB
good luck man congrats on the project
Old Jan 11, 2009 | 05:03 PM
  #114
BoostedProbe
But you did, you said that you would do things differently. If I (or any other person on this forum) was shooting for 1000hp this is not what they or I would do.
Old Jan 11, 2009 | 05:06 PM
  #115
FredB's Avatar
FredB
IMO you should have placed the turbo a little bit higher, when you merge two banks you should never merge to the same size you went 2 2'' pipes merged into a single 2''. scavenge pumps are worthless and if this is a daily driver im sure you'll find this out sooner then later. There's a buch of unnecessary and cheated bends in this system.
but hey you asked ?
IMO it seemed like you wanted to save some money from buying a single kit and that they were inferior for whatever reason. I would defer from using mild steel for charge and turbo piping. If you have the capability to make your own kit why not use the best materials and save on labor?
Old Jan 11, 2009 | 05:22 PM
  #116
Allshow's Avatar
Allshow
great project going on. not a lot of people would attempt this caliber of a project big props to you. just cause he fabbed up the system himself and didnt buy a single setup premade doesnt mean he was trying to save money. i dont see any really cheap ways hes going about this build. all the bends hes making are for his kit that are needed.
Old Jan 11, 2009 | 05:23 PM
  #117
FredB's Avatar
FredB
just trying to give some advice but if its unappreciated i can post elsewhere.
what this thread tells me is why manufacturers can justify charging x amount for labor and materials and you have a guy here thats trying to do it himself and the thing is regardless its not cheap and if he made the end all kit in order to duplicate it im sure this guy would charge 7k+
Old Jan 11, 2009 | 05:27 PM
  #118
tylerxfire's Avatar
tylerxfire
i def. think you should go somewhere else...or maybe you can come over and show me how to change my plugs next since i don't know how, and i can show you a thing or two also...
your advice sucks, your advice is wrong and yeah move on to another thread, like i said you will be put in your place soon enough...this guy is doing a great job like i said, your comments are def. not needed..
Old Jan 11, 2009 | 05:28 PM
  #119
tylerxfire's Avatar
tylerxfire
you better go get at ur 1000hp build buddy
Old Jan 11, 2009 | 05:35 PM
  #120
FredB's Avatar
FredB
i never said anything negative............... you can not thread an NPT fitting into a BSPT block have you tried it first hand? if you did and had success let me know cuz i'd like to know what you did. just because you are upset you cant help him out and have nothing useful to add to this thread dont **** on my back bro
if my advice seems harsh unreasonable or brash let me know i wont hurt your feelings anymore
