Coolant Bypass Line
Old Jan 24, 2009 | 09:31 PM
JETPILOT's Avatar
JETPILOT
Default Coolant Bypass Line
I was thinking of removing the coolant bypass hose on the front of my motor. This is the hose that crosses the front of the motor and allows coolant to bypass the radiator and thermostat and re-enter the block.
I wanted to know what the purpose of this line was? Was it to provide coolant to the water pump when the thermostat was closed to prevent the pump from cavitating without a supply of coolant?
Quadcam removed it and said he has no ill effects, but I am thinking that driving around town at low RPM is one thing and that track use is another.
Anyone know the purpose of this line?
Old Jan 25, 2009 | 05:38 AM
QuadCam's Avatar
QuadCam
You make it sound like I drive like a little old blue-haired granny. WTF???
Old Jan 25, 2009 | 06:19 AM
captj3's Avatar
captj3
You do live in florida...lol
Old Jan 25, 2009 | 11:22 AM
JETPILOT's Avatar
JETPILOT
You drive like a little biatch with your 400whp! Don't pretend like your a big dawg... becasue I'm about to ball this!
Old Jan 25, 2009 | 11:26 AM
Quamen's Avatar
Quamen
I think coolant can bypass through the port on the side of the block next to the thermostat if needed. I don't have the bypass but I also am not running a thermostat right now. I am putting one back in though.
Old Jan 25, 2009 | 11:57 AM
JETPILOT's Avatar
JETPILOT
That's where the coolant bypass line goes. To the side of the block. So if you remove it what happens?
Old Jan 25, 2009 | 12:07 PM
Quamen's Avatar
Quamen
The hard pipe is still connected to the rear coolant pipe.
Old Jan 25, 2009 | 01:34 PM
JETPILOT's Avatar
JETPILOT
There is a reason they made the bypass hose. It's not there to be ornamental.
Old Jan 25, 2009 | 02:55 PM
350 Rookie's Avatar
350 Rookie
Remove it and let us all know the results.
Old Jan 25, 2009 | 02:57 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Take it off. It serves no purpose on a track car, and very small purpose on a street car.
All you need is an upper and lower rad hose for a track car. And man, the engine bay will look so uncluttered without it. Also remove your oil filter heater/warmer hoses as well. One less hose to leak or blow out on you.
Old Jan 25, 2009 | 03:01 PM
350 Rookie's Avatar
350 Rookie
How do we block off the hard line.
Old Jan 25, 2009 | 03:07 PM
Blackbird CPV35's Avatar
Blackbird CPV35
cut and weld, or you can drill and tap if you so chose
Old Jan 25, 2009 | 03:08 PM
350 Rookie's Avatar
350 Rookie
well i can weld but i was tryin to avoid that just in case i want that hose back on someday. LOL
Old Jan 25, 2009 | 03:51 PM
jtgli's Avatar
jtgli
So what purpose does it serve for on a street car? And to be clear we are talking about that soft line that goes across the motor right?
Old Jan 25, 2009 | 04:04 PM
JETPILOT's Avatar
JETPILOT
Yes.... it's the soft line that goes in front of the motor. I'm still interested to know the purpose too.
Old Jan 25, 2009 | 05:14 PM
QuadCam's Avatar
QuadCam
I already threw his **** in the trash, last week.
Old Jan 25, 2009 | 05:18 PM
QuadCam's Avatar
QuadCam
to speed up the engine getting up to operating temperature so that the engine will produce the lowest amount of emission possible. as you know, during warm-up, the ecus are programmed to run rich which is bad for emissions. so, the faster that they can get the engine to operating temperature, the lower the emissions rating that nissan can get for the engine.
Old Jan 25, 2009 | 06:09 PM
chopperman's Avatar
chopperman
What kind of differnece in times are we talking about here? Seconds, Minutes?
Old Jan 25, 2009 | 06:19 PM
JETPILOT's Avatar
JETPILOT
I don't believe that. You don't need a bypass line to do that. Just let the coolant sit in the block it will get hot just as quick. If the pump is turning 3000rpm with insufficient amount of coolant flow it will probably cavitate. The bypass feeds the pump while the thermostat is closed. I believe that's the reason it's there.
Old Jan 25, 2009 | 06:24 PM
westpak's Avatar
westpak
SFZCC
That is what I was thinking, the only other source of coolant would seem to be the heater hose, this probably would not matter if you run without a thermostat
