My Engine and procharger issues
Old Sep 5, 2003 | 12:39 PM
  #81
ravaz's Avatar
ravaz
Did you speak to your installer about this? What did they do for you? Or, did you have to pay the whole bill for this?
Old Sep 5, 2003 | 02:44 PM
  #82
Cintel7's Avatar
Cintel7
Sorry to hear about your car...
Where was your EGT installed?
the EGT should be installed as close as posible to the engine, better yet, install it close to the cynlinder that is running the leanest if you can. I remember several trips going to San Jose from Orange County and my car was running up to 850 degree uphill ( had upgraded injectors too) . I had to turn the AFC up to give it more gas to bring the temperature down.
Anyway.. I hope your installer can help you out.
Old Sep 5, 2003 | 03:21 PM
  #83
ravaz's Avatar
ravaz
I just spoke to my installer, so far I'm very happy with the way they are handling this. I will explain more later, I'm going out to drink. I really need to tonight
Old Sep 5, 2003 | 03:31 PM
  #84
Eric1h's Avatar
Eric1h
850 isnt bad especially under load or WOT, i used to run 900-950 all day long when spraying N02
Old Sep 5, 2003 | 03:52 PM
  #85
N4Spd's Avatar
N4Spd
Default fmu settings
hi ravaz,
can you please post a picture of your FMU slider settings?
did AA tune your car or were those settings stock?
Old Sep 5, 2003 | 03:53 PM
  #86
elektrik_juggernaut's Avatar
elektrik_juggernaut
ravaz......if you get a chance to post the pic of your FMU, can you please also post a pic of your fuel pump, with the hose elbows visible?.......thanks
Old Sep 5, 2003 | 10:15 PM
  #87
ravaz's Avatar
ravaz
I will get the pics of the FMU on Monday, the car is locked up in the ghetto right now, and can't get to it till then. EJ, I will send you a PM with some pics.
Bill
I think the EGT was installed on the exhaust manifolds. When I ran the car, even 300 miles home, my temp never got above 650, it usually was at about 550 or so. Only once did it get to 675, not sure what it was at when it died on the road, wasn't looking.
Old Sep 6, 2003 | 12:34 AM
  #88
elektrik_juggernaut
Thanks Bill..........i'm glad your installer is acting in a professional manner about this.........I hope this matter can be resolved soon, and the actual cause is determined
Old Sep 6, 2003 | 12:54 AM
  #89
little_rod's Avatar
little_rod
ravaz, I don't know if you have answered this or not, but do you have any mods besides the procharger???
Old Sep 6, 2003 | 05:38 AM
  #90
ravaz's Avatar
ravaz
Yes. I have Borla headers, Injen exhaust, and cat pipes, or straight pipes or test pipes whatever you want to call them.
Bill
Old Sep 6, 2003 | 05:54 AM
  #91
jesseenglish's Avatar
jesseenglish
What side of the engine is your EGT monitoring and since you've got headers... Where is it, before or after the header collector. If it's before then you're only monitoring the one cylinder, if it's after the collector you're monitoring a composite of all three cylinders.
Old Sep 6, 2003 | 05:57 AM
  #92
ravaz's Avatar
ravaz
I'm not sure, the installer installed it, so I'll have to get with them about that.
Old Sep 6, 2003 | 06:07 AM
  #93
jesseenglish
I'm going to be installing 2 eventually. One after the collector on each manifold. I don't have headers though so the gasses will still be very hot. I realize it's kinda late for you now, but it's an interesting question, that could be the explanation as to why your EGT's looked normal.
Old Sep 6, 2003 | 07:45 AM
  #94
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I don't have headers. Just the Borla exhaust. My EGT has gone as high as 800 but that was only once. It usually runs 600-700 after a lot of driving and even lower just around town and not pushing it. I have no idea where AAM put it though.
My boost gauge has never gone over .5 cm/kg sq (7 psi)
Old Sep 6, 2003 | 07:48 AM
  #95
GaryK's Avatar
GaryK
I'm running an EGT in the right side header collector, before the flange that bolts to the cat. I'm getting peaks of a little under 800 C at WOT. It sometimes hits mid 700's under light throttle with a heavy load, such as going up a hill in fifth or sixth gear. After the motor is fully warmed up, any throttle at all even staying out of boost will bring the temps up to 650 or even 700.
Old Sep 6, 2003 | 07:50 AM
  #96
ravaz's Avatar
ravaz
OK, so who has the best price on rods and pistons? We are going to be looking at 8.5:1. Hopefully I'll be back on the road within the month
Old Sep 6, 2003 | 08:26 AM
  #97
FairladyZ's Avatar
FairladyZ
Good chioce. Do they make pistons for our cars?
Old Sep 6, 2003 | 08:29 AM
  #98
ravaz's Avatar
ravaz
sgpracing has them on their site, 1320.00 for the 8.5:1 pistons, and 1275.00 for the rods. I want them cheaper. I think they had them custom made. I'm sure the pistons are Je, not sure about the rods. Just don't feel like paying that much
Old Sep 6, 2003 | 08:32 AM
  #99
FairladyZ's Avatar
FairladyZ
JE is very good, thats what most of the LS1 guys use when going FI. I had a heads/cam/ls1 edit/etc 2002 WS6. I got tired of the speed if you can believe it and sold it for the Z.
Old Sep 6, 2003 | 11:36 PM
  #100
G3po's Avatar
G3po
Default rods
The rods (forged I-beams) offered by sgp are made by "Pauter" and are good for >700 hp apps. Eventually "Eagle" may offer a set and they will probably be cheaper. But it doesn't sound like waiting is an option for you.
For peace of mind you may want to consider a piggyback "knock-alert" system. I beleive MSD sells one. It can warn of detonation , even if a fuel delivery componet fails quickley. An EGT and your ears can't detect that. It only takes a few seconds to destroy a piston, ring or head gasket under boost + detonation.
Another addiotional idea is a cockpit mounted fuel pressure gauge.
