XKR Super G... Going for Mach 1
Old Jun 8, 2009 | 09:31 AM
  #501
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by XKR
Savini SV-10......This company will custom make it anyway you want it. GreenGoblin with the wide body green Z was who gave me the info on them.
I am MAXXXXED out on how wide the rims can be......but Savini was the only company willing to make them the way i wanted with a 5"+ lip.
As you can see in the pic above.....even with 305's the tire is somewhat stretched.
Are you using these wheels on the track, or do have another set?
Old Jun 8, 2009 | 09:35 AM
  #502
XKR's Avatar
XKR
I have another set......the same size and offset. Remember...I can only run 20"....but I received a set of shaved Yokahama's that I use to test.
Old Jun 8, 2009 | 09:38 AM
  #503
GreenGoblin's Avatar
GreenGoblin
  #504
str8dum1's Avatar
str8dum1
of course a 295 will fit on a 11.5" rim. not what i was concered with its the +30 offset that might not be deep enough to allow the tire clearance from the suspension. i'll prolly just play it safe and go with the 11" +24 (which will give me 1/2" more inner clearance) as the 11.5" with my current 275's (until i wore them out) would be pretty stretched.
Originally Posted by Driven1
It will fit. I run 295/30 (PS2's) on my 20x11 rears.
XKR...Are those Savinis?...the SV-10 perhaps?
Old Jun 8, 2009 | 09:40 AM
  #505
GreenGoblin
I have a Black G
Old Jun 8, 2009 | 09:48 AM
  #506
Sylvan Lake V35's Avatar
Sylvan Lake V35
Originally Posted by str8dum1
how far from your suspension is that 305 tire with the +35 offset? what's your camber?
an 11" with a +35 would only be 1mm further from the suspension than a 11.5" +30 which is what I wanted to try.
That 11.5" should fit with a 295 tire then.
11.5" will start getting close to the coilovers. I run a 19x12" (20x12" would be worse) with Bilstien coilovers and there are holes rubbed in the dust boots from when the suspention would compress when I had -2.5deg camber now I am at -1.5 with no issues. But its very close clearence both to the fenders and coilovers. If I did it again I would probobly stick with an 11" but 11.5 with the right offset should work. I think 1"= aprox 25mm so 11.5" with a +30 would be 10mm closer to the suspention than 11" +35. Hope that helps.
Sorry for the OT Mike.
  #507
XKR's Avatar
XKR
[QUOTE=GreenGoblin;7417473][QUOTE=XKR;7417308]GreenGoblin with the wide body green Z was who gave me the info on them.
I have a Black G
MY bad.....So who is the guy with that bad azz green wide body with the Savini's
Old Jun 8, 2009 | 10:06 AM
  #508
Driven1's Avatar
Driven1
Professional
HAHAHA. I've had my Savini SV-10's for like 3 yrs now. I have the Anodized chrome lips not the polished chrome that they went to after they made their first sets.
Old Jun 8, 2009 | 11:26 AM
  #509
ttg35fort's Avatar
ttg35fort
Professional
On my setup, the issue is the tire, not the wheel. I have 305s on 10.5" wheels. The tires are wider than the rim by about 1.5", so they extend about 19 mm on each side. I have probably about 1/4" clearence between the tire and the coilovers using camber, but more than that between the inner edge of the rim and the coilovers.
Using a 295 on an 11" wheel will means that the tire will not extend as much beyond the wheel, maybe about 8 mm on each side. So I think a 30 offset should work fine, especially if you are setting up for street use, in which case you will want to run less camber than I am.
If I were going to run a 295 on an 11" wheel, I would go with an offset in the range of 35 mm - 37mm.
Old Jun 8, 2009 | 11:32 AM
  #510
ttg35fort's Avatar
ttg35fort
Professional
Remember, the offset is measured from the center of the wheel, which only changes by one-half of the width change. In other words, going from an 11" wheel to an 11.5" wheel only moves the centerline 1/4", or a little over 6 mm. 11.5" with 30 offset would be somewhere around 1 mm less inner clearence than a 11.0" with 35 mm offset.
Old Jun 8, 2009 | 11:38 AM
  #511
rcdash's Avatar
rcdash
rogue350z I believe.
Old Jun 8, 2009 | 12:20 PM
  #512
str8dum1's Avatar
str8dum1
yes you basically repeated exactly what i said in my original question. Thanks
thats why i was figuring a 11.5" +30 would fit if the 11" +35 was fine. Thats why I was asking how much clearance from the suspension that the 11" +35 had.
  #513
XKR's Avatar
XKR
OOOOooops My bad
Old Jun 8, 2009 | 01:28 PM
  #514
ttg35fort's Avatar
ttg35fort
Professional
Yes, your original post was correct.
I was responding to Sylvan Lake V35's Post where he said "11.5" with a +30 would be 10mm closer to the suspention than 11" +35", which is incorrect.
Old Jun 8, 2009 | 02:09 PM
  #515
XKR's Avatar
XKR
Its Kool.....There is really no OT in this thread.....This thread will cover Rims to motor..
I also agree with the width x offset numbers. My rim in the rear has zero room for error. BTW...Savini says that my rear rim is a "Center +30" Hope that helps.
Old Jun 8, 2009 | 03:31 PM
  #516
Aced16's Avatar
Aced16
yea sorry for the OT mike, but i do appreciate the insight! its def helping me with my HW
Old Jun 8, 2009 | 03:34 PM
  #517
Sylvan Lake V35
I was just logging on to change it, I was sitting thinking about wheel fitment and it hit me.... i am an idiot....1/4" on each side, someone at work was bothering me when i was doing my math(thats my story anyway). thanks for the correction
  #518
XKR's Avatar
XKR
kool....no OT problems here......this thread is wide open for all topics dealing with all things G/Z.....
Old Jun 8, 2009 | 05:19 PM
  #519
str8dum1's Avatar
str8dum1
i guess you car is being stripped anyday now in prep for the new setup?
Old Jun 8, 2009 | 05:23 PM
  #520
XKR's Avatar
XKR
They already started......The turbo's are out..because Sharif told me what he found when he inspected the turbo's...so my guess is the motor is our also.......He will also inspect that also
