XKR Super G... Going for Mach 1
Old Sep 11, 2009 | 05:20 PM
  #1101
XKR's Avatar
XKR
Originally Posted by mysterymann
I see a relentless sticker on your fire extinguisher lol
Its called a bbq Protector
  #1102
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
swap your system out for this turbo
http://www.youtube.com/watch?v=ag4nL...eature=related
Originally Posted by XKR
No thanks ...... ...Too wild for me
C'mon Mike. Be honest. You told me that if your new setup doesn't make 1,000+whp... ^ you'll try one of those in an STS style rear mount location.
Old Sep 11, 2009 | 05:24 PM
  #1103
XKR's Avatar
XKR
And then install a rear IC like Doug has on his Maita....
Old Sep 12, 2009 | 01:51 PM
  #1104
superchargedg's Avatar
superchargedg
Damn Noobs
Holy mother of god!!!!
Old Sep 12, 2009 | 01:53 PM
  #1105
superchargedg
Damn Noobs
OK guys....Sharif installed this for me today All that is left to do is install the Super Foam
Thanks Eric
[/QUOTE]
Mike that is just fuking awesome.....i love it and its fitting....if you know what i mean.
Old Sep 12, 2009 | 02:02 PM
  #1106
Russ@Z1's Avatar
Russ@Z1
lmao at the RA inspired fire extinguisher setup!
Old Sep 12, 2009 | 04:32 PM
  #1107
ttg35fort's Avatar
ttg35fort
Professional
I went and measured my turbo housings today. They are 3071R turbos with a 0.64 A/R.
Long story short, as we suspected, the A in Garrett's A/R formula does NOT stand for the area of the turbine inlet.
Using Garrett's drawing and my actual turbo housing, R measures to be about 50 mm. (Raj, you were right, the wall was 4 mm). Thus, A should be 50 * 0.64 = 32 mm^2.
I measured the diameter of the inlet area where indicated in Garret's drawing. The diameter measured approximately 34 mm. I was using a paper ruler which was bending a bit, so this value is probably a bit smaller, and may actually have been closer to 32 mm.
The opening is not perfectly circular, but we'll use this measurement just to get an approximation of the inlet area, which turns out to be approximately 804 mm^2. In actuality, the inlet area is probably a good 10%-20% larger than this due to the inlet shape.
Now, using Garrett's definition of A/R, my A/R = 16.1. The housings are specified as 0.64. So we can safely assume that their formula is way, way off. In other words, A is NOT the area of the inlet as they state on their website. Instead, A is the diameter of the turbine inlet.
I have not yet heard back from Garrett, but I believe that when I do, they will confirm this. Hopefully they will correct the tutorial on their website.
I will now compute the Approximate turbine areas for various turbochargers for comparison to the flange area, which is how this all started. I'll post the results.
Old Sep 12, 2009 | 05:33 PM
  #1108
ttg35fort's Avatar
ttg35fort
Professional
EDIT EDIT EDIT: Garrett finally got back to me, which changes the entire analysis...
Essentially A is the inlet area, but the formula only works in INCHES, while all of their dimensions are specified in mm.
OK, using A as the area of the inlet (in inches), I have computed the following turbine inlet areas:
GT3071R 0.64 A/R: 800 mm^2
GT3071R 0.86 A/R: 1143 mm^2
GT3076R 0.64 A/R: 834 mm^2
GT3076R 0.84 A/R: 1156 mm^2
GT3582R 0.76 A/R: 1117 mm^2
I computed using the same formula previously posted, but converted everything to inches to perform the calculations to make it work with Garret's inch-based A/R values, then back to mm.
The flange areas are as follows:
T25: 1735 mm^2
T3: 2412 mm^2
T4: 3623 mm^2
EDIT EDIT EDIT EDIT: The T25 flanges will work perfectly fine.
Old Sep 13, 2009 | 04:20 AM
  #1109
str8dum1's Avatar
str8dum1
interesting.
29psi? that about what GTM said that the 3076's needed to run to see about 900, so that falls within reason. THats alot of boost and I dont think Sharif has even tuned passed the internal MAP sensor of a Haltech at 22 psi.
Could you post the actual dimensions of the various flanges. I couldnt find that data. I am also interested in seeing how you came up with the measurements for the other turbos if you didnt actually measure them.
Interesting data, now we just need real world #s . 30 psi here we come!
Old Sep 13, 2009 | 06:12 AM
  #1110
Cass007's Avatar
Cass007
Anyone know what flange size the APS turbos have?
Sorry for the hijack Mike
Old Sep 13, 2009 | 06:18 AM
  #1111
thom000001's Avatar
thom000001
Like I tell anyone thats been in my car, and is amazed by pump gas powe.....
"LIFE BEGINS AT 30PSI"
At least on mine the power difference once you get up above 22-25psi is BRUTAL.
The car is almost violent at 25-30psi......**** be happenin FAST!!!!!!!
Tom
Originally Posted by str8dum1
interesting.
Old Sep 13, 2009 | 07:37 AM
  #1112
rcdash's Avatar
rcdash
Nice analysis Terry, as usual. Look forward to what Garrett has to say. In calculating what PSI required for whp, did you figure it for a 4.1L or 3.5L engine?
Tom, up to what PSI can you run with pump (93 octane) gas?
Old Sep 13, 2009 | 09:06 AM
  #1113
XKR's Avatar
XKR
Thanks for the info Terry....
Making the power was not a worry for us....the Carbonetic clutch is the only worries FP,GTM and I have. It's rated at 900+whp.... That's why I don't want Sharif to push it on his dyno....850+ on FP dyno and the rest on a DJ...
I am not willing to give up the Carbonetics for a race only setup....remember this car is setup for multi use.
Old Sep 13, 2009 | 09:10 AM
  #1114
XKR's Avatar
XKR
They are now on sale at Forged Performance
Old Sep 13, 2009 | 09:29 AM
  #1115
ttg35fort's Avatar
ttg35fort
Professional
T25: 49.3 mm x 38 mm, 12.7 mm R
T3: 57.2 mm x 44.7 mm, 13.0 mm R
T4: 74.7 mm x 50.3 mm, 12.5 mm R
R is the radious in each of the 4 corners. My computations take into consideration the corners.
Old Sep 13, 2009 | 09:30 AM
  #1116
ttg35fort's Avatar
ttg35fort
Professional
4.0L
Old Sep 13, 2009 | 09:42 AM
  #1117
ttg35fort's Avatar
ttg35fort
Professional
You might think about trying the 0.63 A/R housings for faster spoolup. If you have good Wastegates/dumps, it should keep the back pressure from becoming a problem.
Old Sep 13, 2009 | 09:47 AM
  #1118
ttg35fort's Avatar
ttg35fort
Professional
There is a Japtrix build/tuned RB26 (2.6L) motor pushing over 30 psi and getting over 600 whp on 93 octane. That's over 230 hp/L on pump gas.
I beleive that the compression on that motor is 8:1, and it is all cast iron. Both of those things help alot.
Old Sep 13, 2009 | 09:53 AM
  #1119
thom000001's Avatar
thom000001
I dd it at 14psi, when out with "friends" on pump I'll go to 17psi....have seen 18psi, but the last plug change showed some speckles....so keeping it below that for safety. If we touched the tune could go higher....
But 14psi is 530rwhp (SP's mustang dyno), so figure 18-20hp per lb of boost, so somewhere right at 590-600rwhp at 17psi (have to dyno it at 17psi on pump one day to see)
basically pump gas is more than enough for 99.99% of the stuff out there......but Vlad's crazy G35 sedan just made 597rwhp at 12psi through a TH400.......I'll need a whole lot more for that lol.
tom
Old Sep 13, 2009 | 09:54 AM
  #1120
XKR's Avatar
XKR
Everything is in and ready to start up this week...
