XKR Super G... Going for Mach 1
Old Oct 18, 2009 | 06:39 AM
  #1601
rcdash's Avatar
rcdash
Originally Posted by XKR
I will be camped out in front of Raj's house a few days before ZDayZ. Plus I know that Raj is looking for a shorter runway for the next event
Short and sweet, sounds good to me!
That dyno looks good and the tune looks well dialed in already but the motor isn't being pushed (as noted, not at redline). It looks like a healthy 4L motor with nice cool air being generated by the turbos, which at 11 psi, is not even at peak efficiency yet. And at 7500 rpm that's easily 550 whp or 600 whp DJ. It's as good as any other setup you'll see at 11 psi, given that that pressure ratio is suboptimal for many turbos.
I am very impressed with the spool though. (unfortunately!)
Congrats Mike, Sharif.
EDIT: str8dum, where is your overlay between Jayz 20G tune and this one?
Old Oct 18, 2009 | 07:07 AM
  #1602
eltness350's Avatar
eltness350
The Untouchable
Yeah....He had no intension of posting until he had it fully tuned.....he was just doing this to get me off his back
Dont forget that redline is 7500 or 7600 rpms......I am thinking with a proper tune and him running it to redline we will get much more at 11 psi....Sharifs numbers were correct from what I see so far by going with the C8/Gt35r.......Do you think the heads are helping anything at this low level boost?? I was using the 18G comparison also....and what PSI it would take for an 18g to reach 530whp coming out of FP...
for reference i did 500rwhp on sharifs dyno at 13psi.... ported heads and bc stage 2 cams....18g kit.... so i think 14psi would get it with my setup...full 3inch exhaust also.... imo
Old Oct 18, 2009 | 07:32 AM
  #1603
ttg35fort's Avatar
ttg35fort
Professional
Yes. I beleive those heads were designed for an N/A motor, so you should be seeing benefit from them in the upper rpm range, regardless of the boost level. You may lose a little bit of mid rpm torque, but if Cosworth did their homework, the gains up top should more than offset any losses in the middle.
Old Oct 18, 2009 | 07:36 AM
  #1604
XKR's Avatar
XKR
The tune is far from being finished....This was a get XKR off my back run I will be in ATL for the big run when I get the heads up.
Originally Posted by Sharif@Forged
Here is some fresh meat for the dogs. 11psi just roughing in the tune. So far the power looks outstanding, and still havent added much in the way of timing or RPM's yet.
530 @ 14psi on FP dyno with 18g
I see.....
Old Oct 18, 2009 | 12:54 PM
  #1605
str8dum1's Avatar
str8dum1
So here is Mike's rough in tune vs Jay's 20g at 15psi. You can tell Mike's tune is really rough as there are like 3 flat spots in the trq where it could be alot more linear.
This is XKR's same dyno vs Cass's APS kit with 3071's on pump. Cant remember the psi, btu I think like 17-19 though.
1 more thing to note. The purple intersection is the where XKR's turbos are fully spooled so as he increases the boost, area under that wont change much. Its pretty beefy compared to the smaller turbos.
Everyone says smaller turbos are faster down low. Well, I think most people just repeat what they hear....
Old Oct 18, 2009 | 01:33 PM
  #1606
rcdash's Avatar
rcdash
Thanks for the overlay. Very impressive low end, but that's as much due to the well matched motor build as the turbos - your comment about us smaller turbo folks really isn't fair
Old Oct 18, 2009 | 01:35 PM
  #1607
03threefiftyz's Avatar
03threefiftyz
Chris (cass) never posted tq results on this motor build. It was a psi overlay. Good comparison though.
Old Oct 18, 2009 | 01:37 PM
  #1608
XKR's Avatar
XKR
Yeah....the tune was really a throw together tune....I am happy so far with what I see from the turbos...
Old Oct 18, 2009 | 01:43 PM
  #1609
ttg35fort's Avatar
ttg35fort
Professional
Nice comparison. Keep in mind Mikes' motor is 4.0L vs 3.5L for the others. Nonetheless, I'm still amazed by Mike's low end torque.
My new 4.0L motor is very similar to Mikes, even the same cams. I have the GT3071/0.64 A/R turbos. We'll compare them once mine is up and running.
Old Oct 18, 2009 | 02:20 PM
  #1610
str8dum1's Avatar
str8dum1
hp = trq*rpm/5252
therefore trq = hp*5252/rpm
  #1611
03threefiftyz
hp = trq*5252/rpm
therefore trq = hp*rpm/5252
True.
Old Oct 18, 2009 | 02:58 PM
  #1612
T_K's Avatar
T_K
3 Different kits. 3 Different turbos. Different displacement engines. 3 Different builds, i.e. combination of parts. Not apples. For any situation such as this, imagine the most extreme ends of the spectrum, and watch the behavior patterns of the parts. If your conclusion was correct, why would we need ANY small turbos...
Old Oct 18, 2009 | 03:54 PM
  #1613
str8dum1's Avatar
str8dum1
ya and.. thats what a boost controller is for and the smaller turbos were running 4-5 more psi which brings the displacement difference down.
Old Oct 18, 2009 | 04:38 PM
  #1614
Cass007's Avatar
Cass007
Checked my graph vs the graph posted and the results are very similar.
For large turbos, XKR's spool is sick. Keep in mind, my tune is far from complete, although I don't expect the area under 4K to change much. Mike's car is in a whole other league now, but I should be able to give Raj all he can handle
Old Oct 19, 2009 | 01:17 PM
  #1615
XKR's Avatar
XKR
^^^^ I agree..Raj must pay...
Old Oct 19, 2009 | 05:21 PM
  #1616
rcdash's Avatar
rcdash
Well that's a circular argument since the turbo hasn't built boost due to the smaller displacement. LOL.
Hey, what's with the pick on Raj posts? Besides I've got all winter to figure something out...
Old Oct 19, 2009 | 05:42 PM
  #1617
Motormouth's Avatar
Motormouth
I love when a graph pulls to redline like that. the 4 liter is supposed to generate more low end tq and spool faster, no?
all this 3.5 vs 4 talk :P
Old Oct 19, 2009 | 05:54 PM
  #1618
str8dum1's Avatar
str8dum1
that graph is still 1000 rpms or more from redline, so we dont know what its goin to look like at redline
we havent seen a straight 3.5 vs 4.0l comparison either. we just know based on the 1st curve, he'll walk a 3.5 with much smaller turbos from a dig.
doesnt anyone have like a JWT 530bb dyno. that would a nice curve comparison bc thats the smallest turbos people have and they should be fully spooled on a 3.5L way low, and have more area under teh curve.
Old Oct 19, 2009 | 06:40 PM
  #1619
Motormouth's Avatar
Motormouth
The smaller turbos spool by around 3500 at low boost, right? 500 rpms is no big deal to me, especially considering I can't remember ever driving my car at 3500rpms :P
Old Oct 19, 2009 | 08:45 PM
  #1620
phunk's Avatar
phunk
CJ Motorsports
ohhhh its running! VERY curious to see what this build puts down.
