Vortech v3
Old Mar 8, 2009 | 04:11 PM
Everybodywildou's Avatar
Everybodywildou
Originally Posted by UMW350Z
nice, it would be interesting to see our cars pull side by side...PL vs Vortech with even output
I only had 330lbs of torque. lol yeah it would be interesting.
Old Mar 8, 2009 | 04:19 PM
UMW350Z's Avatar
UMW350Z
still pretty on target with me...this ST isn't very torquey at all, but it doesn't let up until 62-6300 rpms
Old Mar 8, 2009 | 04:26 PM
nd2spd's Avatar
nd2spd
Originally Posted by Everybodywildou
Oh I always thought it didn't have one since the V3 is a self lubricating unit like the procharger
Hmmm...well I know where the dipstick goes and how to fill the unit up, just don't know how to drain the old oil. The v3 comes pre-filled with 4.oz of oil from Vortech. After the first 2500 miles you have to drain and refill with 4.oz of "Vortech's special oil" hahaha. They include 3 bottles with the kit and you can purchase more from their website:
http://www.vortechsuperchargers.com/product.php?p=162
After the initial 2500 miles you replace the oil every 7500 miles which isn't all that bad IMO.
According to Vortech, changing the oil isn't difficult. They designed it so that you can drian and re-fill without removing the unit. The only problem is that they don't include that procedure in the manual. I will give them a call tomorrow and find out.
Old Mar 8, 2009 | 04:32 PM
nd2spd's Avatar
nd2spd
Originally Posted by Nexx
lol, thats pretty close to what i dyno'd with a 2.87 at 12psi.
I'm still relatively new to FI, but I thought you would be up in the 410-420 whp range with 2.87 @ 12psi.....
Old Mar 8, 2009 | 05:18 PM
350Z400rwhp's Avatar
350Z400rwhp
It all depends on the type of dyno, the correcting and conditions during the dyno process. I only hit 330 on a DD and I know my car is faster than 330whp on a DJ. My friend hit 383 on a DJ with his mustang (weighs about 3100lbs) and we are neck and neck when we race. Sure its not an apples to apples comparison but that's really my point. Great numbers none the less on the stock pulley though!
Old Mar 8, 2009 | 06:52 PM
Everybodywildou
Of course your 330hp DD car is going to be faster than a 330hp DJ car. DD puts out lower numbers. You probably make around the same numbers on a DJ as your friends mustang.
Old Mar 8, 2009 | 07:45 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Good question, I was wondering that myself. I have to call him on Monday to find out.
Thanks.
Old Mar 8, 2009 | 08:53 PM
nd2spd's Avatar
nd2spd
So which of the two are more accurate...DD or the DJ? I always thought that the DJ was the most accurate. Well whatever the case I am happy with the results nonetheless.
CHEF-J , do you also have the V3?
Old Mar 8, 2009 | 08:57 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ yes. Click my sig
Old Mar 8, 2009 | 09:59 PM
HammZ's Avatar
HammZ
just out of curiosity, about how much would you say you spent?
Old Mar 8, 2009 | 10:10 PM
nd2spd's Avatar
nd2spd
Originally Posted by Chef-J
^ yes. Click my sig
Sweet! Read through the entire thread. Awesome man and congrats on your install.
Old Mar 8, 2009 | 10:17 PM
nd2spd's Avatar
nd2spd
$7700, came a bit over my budget but that is always the case when it comes to FI.
Old Mar 9, 2009 | 06:40 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Thank you, and any news?
Old Mar 9, 2009 | 07:27 PM
nd2spd's Avatar
nd2spd
Sorry, really busy at work today.
Old Mar 9, 2009 | 08:12 PM
350Z400rwhp
I think the rule of thumb on a DJ you add 15-18% and on a DD you add like 22-25% So for you I would add 50hp to your wheel hp and that should be your aprox. crank horsepower. You are well over 400
Old Mar 9, 2009 | 09:36 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
No problem
Old Mar 10, 2009 | 03:57 PM
nd2spd's Avatar
nd2spd
Congrat, Btw, where did they put the blower oil drain line?
Ok, the oil drain line is the steel braided line that is attached to the bottom of the blower. Route the line so it descends down toward the ground vertically from the blower and use a zip-tie to secure it. You can access the blower oil drain line which will be above your under panel near the drivers side front wheel. Sounds like a pain in the a$$ but it really isn't. You will have to remove that panel anyways when you change your engine oil. Just remember to change the blower oil after the first 2500 miles. After that, it is every 7500 miles.
Another important item is the brass flat head shipping plug that has to be replaced with the vented round head brass plug. I attached a picture to help show what I mean.
I have to admit though, once the blower is installed, removing the dipstick is a major pain. It's a tight fit but I was able to remove and replace it with some manipulation. Not a big deal.
Old Mar 10, 2009 | 04:11 PM
  #38
Chef-J's Avatar
Chef-J
Booooosstt!!
^ Thanks alot, always wonder how other V3 owner leave their drain line...
Yea, that's how i leave my drain line..And oh i didn't replace that...humm i guess i gotta do it.
Edit: btw, just notice that you have a plenty of room between pipe/AC line compare to mine.
Old Mar 10, 2009 | 04:19 PM
  #39
nd2spd's Avatar
nd2spd
I guess Vortech ships it that way to prevent oil leaking during shipping.
350Z_Al
Oct 29, 2020 07:44 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
