Recharging the Vortech Filter
Old Mar 13, 2009 | 10:34 AM
Netacoma2003's Avatar
Netacoma2003
Default Recharging the Vortech Filter
Does anyone have a filter recharging secret they're willing to share?
I searched a couple different ways but could'nt find exactly what I'm looking for. It is time for me to do the first recharge of my filter but the thing is really wedged in there!!!! Managed to get it unclamped from the charger but can't even reach behind it to disconnect the tube (crankcase ventilation?).
From looking at the setup, I figure a couple different ways to recharge it but all involve varying levels of disassembly
Any constructive suggestions would be greatly appreciated!!
Also found some oil residue on the filter side of the impeller. Contacted Vortech but have not yet heard back from them....any ideas / solutions?
Old Mar 13, 2009 | 10:40 AM
Jeremy@Altered's Avatar
Jeremy@Altered
You really just have to squish it and pull it out, then do the opposite to put it back in.
Old Mar 13, 2009 | 11:30 AM
str8dum1's Avatar
str8dum1
its much easier if you pull off the fender well liner and go at it from below.
Old Mar 13, 2009 | 11:57 AM
cwylie's Avatar
cwylie
Yeah I get my out through the fender
Old Mar 14, 2009 | 10:21 AM
jpc350's Avatar
jpc350
Do these filters need to be recharged?
Old Mar 14, 2009 | 10:47 AM
05Z33's Avatar
05Z33
yes. They tend to get dirty from oil blow by from the driver side crank case hose.
Old Mar 14, 2009 | 11:38 AM
MikeFunction2nd's Avatar
MikeFunction2nd
Vendor - Former Vendor
How long have been running this filter?
Old Mar 15, 2009 | 08:14 AM
Netacoma2003
After jacking the Z up to investigate the fender method, I decided to go with the squish method.
Now my filter looks like ***
There were a few serious obstructions to the fender method..... a fender / headlight support on the side of the filter that bolts to the radiator as well as a frame rail and two metal lines (AC?) below the filter. Couldn't see a way to get the filter out without tearing it all apart.
Thanks for the tips though; I managed to refresh the oil/filter and air cleaner which makes for a happy Z.
Attached Thumbnails Recharging the Vortech Filter-dsci0263.jpg   Recharging the Vortech Filter-dsci0262.jpg
Old Mar 17, 2009 | 01:19 PM
str8dum1's Avatar
str8dum1
ya looks arent that important. but mine slides right out between the frame rail and the tire well.
Old Mar 17, 2009 | 01:31 PM
05Z33's Avatar
05Z33
I wasn't so lucky. I had to use the squish technique also.
Old Mar 17, 2009 | 01:35 PM
iStan's Avatar
iStan
ZR
Str8dum, are you a G?
Stan- Also goes squish
Old Mar 17, 2009 | 01:48 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
I guess im the only one who does it the HARD way. Id rather not squish it. Pulling it through the fender never looked like a good option.
My method is a PITA so i decided to relocate my filter to near the hood release latch.
I normally take off the main drive belt, remove all the bolts from the bracket, lift up bracket and blower and then remove the filter. This can take a bit of time since the bolts on the bracket near the blower are a bit of a pita to undo. Once youre done cleaning it put it all back together...its a bit time consuming.
Old Mar 17, 2009 | 01:50 PM
iStan's Avatar
iStan
ZR
Come- squish. All the cool kids do it.
Yeah, I need to relocate/CAI.
Old Mar 17, 2009 | 02:49 PM
05Z33's Avatar
05Z33
I've been thinking about the CAI myself. I wonder if anyone here is still making those kits? I'll probably end up making my own.
Old Mar 17, 2009 | 03:00 PM
iStan's Avatar
iStan
ZR
I've been debating between using a silicon 90* bend and a tube, or just a bent tube. I'm not sure which way I'm going to go yet.
Old Mar 17, 2009 | 03:11 PM
Barzten1's Avatar
Barzten1
I hated that little filter. I trimmed out the plastic in front of it and used the K&N rx4140. Its more than twice the size. I used to clean my Vortech filters every 3 weeks. Gotta let that blower breathe. It was definately a difference I could feel. I still have one in the box if someone wants it. The one on the right was a used one to show what it looked like.
Old Mar 17, 2009 | 03:16 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
^nice, op should hop on that. That filter would probably work on my CAI setup. If no one takes it i will.
Old Mar 17, 2009 | 03:23 PM
Barzten1's Avatar
Barzten1
There was a writeupon here a while back about it. Thats where I got the idea. Vortech kits should come with this filter. Either was guys with blowers should clean them once a month and you will fee lthe difference of free fowing air
terps's Avatar
terps
ehhh i havnt cleaned my filter in over a year, it looks clean but im sure its filthy, i need to yank the front bumper off to do mine though, consider yourself lucky
Old Mar 17, 2009 | 05:03 PM
TinmansZ's Avatar
TinmansZ
The best solution is to move the filter to a new location, I used an old Injen CAI and modified it, now the filter is located above the inner cooler.
