gauges
Old Mar 15, 2009 | 12:45 PM
blueVQ's Avatar
blueVQ
Default gauges
hey guys i was just wondering what guages everyone normally runs for FI.. i have the three guage pod and obviously boost and air fuel/wideband are the two but what do most people run for a third? i ordered a fuel pressure guage. that ill use.
Old Mar 15, 2009 | 12:56 PM
midz350's Avatar
midz350
boost
oil press
oil temp
water temp
fuel press
a/f
EGT
your choice.
Old Mar 15, 2009 | 12:57 PM
Cass007's Avatar
Cass007
Fuel pressure gauge is usually in-line under the hood, at least mine is. Most common answer will be either exhaust gas temp or possibly dual wide bands. It pretty much whatever your tuner prefers. If you are just trying to fill a hole in the pod you can always get another engine temp gauge, one that is more accurate than the stock unit.
Old Mar 15, 2009 | 01:01 PM
blueVQ's Avatar
blueVQ
sorry for being a noob but what is EGT?
Old Mar 15, 2009 | 01:24 PM
Cass007's Avatar
Cass007
Exhaust Gas Temp
Old Mar 15, 2009 | 02:13 PM
thom000001's Avatar
thom000001
I have wideband and boost (aem tru boost so its a gauge and controller).
Swapping out the AEM tru boost for the Pro-EFI CAN gauge which is a super-duper multi-function gizmo.
Old Mar 15, 2009 | 03:20 PM
UMW350Z's Avatar
UMW350Z
you will want something to monitor boost for sure, preferably warning you if you are overboosting. EGT is good, oil temp is good and so is a digital wideband. You can eliminate a boost gauge by putting in a HKS EVC6 which will give you a digital readout (mount in cubby). A HKS turbo timer will give you voltage (mount in cubby), then you can replace that pod.
Four Defi gauges plus a wideband is about 12-$1500
Three Defi's, EVC6, and a wideband is about $14-1800
turbo timer is about $150
Remember, it isn't really possible to monitor 6 gauges at one time without concentrating on the road. I don't look at my gauges while driving hard unless they flash (luckily they havn't yet)
Old Mar 15, 2009 | 04:12 PM
coachk's Avatar
coachk
EGT is the bottom one
Old Mar 15, 2009 | 04:41 PM
thom000001's Avatar
thom000001
Yup,
Only gauge I have time to watch while racing is the Tach.
Old Mar 16, 2009 | 01:07 AM
MOTOWIPEOUT Z's Avatar
MOTOWIPEOUT Z
HKS Camp2 monitors everything but you would also need to have an HKS Fcon iS or Vpro.
Old Mar 16, 2009 | 04:43 AM
Netacoma2003's Avatar
Netacoma2003
IMO.....minimum gauges should be air fuel and boost.
Old Mar 16, 2009 | 06:08 AM
fstrnldr's Avatar
fstrnldr
Ummmm no you don't.... The CAMP2 on its own will monitor and display (w/ warning option) all of the common parameters through the OBD2 port. W/ some added parts, you can monitor other things like boost, and EGT. A/F i don't believe is quite that easy. For that you will still need a wideband controller, and i'm not sure if the knock monitor will give an output signal to the camp, or if it has to go through an FCON to work.
Old Mar 16, 2009 | 06:58 AM
thom000001's Avatar
thom000001
IMO your best bet is to have an EMS that is monitoring everything (through the help of addition sensors if needed), that automatically adjusts/fixes/retards/cuts/lowers/backs off/etc, if something gets outside of a parameter (i.e. fuel pressure drop, oil pressure jump or drop, a/f too lean/rich, boost spike, etc..). If you are expecting to be able to drive, monitor gauges, adjust driving to what 6 gauges are telling you, it ain't gonna happen...thats when things go boom
tom
Old Mar 16, 2009 | 09:34 AM
Cass007's Avatar
Cass007
tom
+1 - Just watch the tach and peek the rearview every now and then under WOT to see if you are smoking at all, unless your tint is too dark, then just politely ask the guy you just crushed if he saw any white smoke out of the pipes when you blew by him .
Old Mar 16, 2009 | 11:35 AM
MOTOWIPEOUT Z
I stand corrected, just went to the HKS website and looked at it again, I'm not sure how I arrived at that conclusion and thanks for bringing it to my attention.
Old Mar 16, 2009 | 10:11 PM
boostedmaxima's Avatar
boostedmaxima
I got the Zeitronix because it had a bit of info on one read out and didn't have to clutter the cab with gauges. I have a dual gauge pod that reads oil pressure and will have a fuel pressure gauge soon. I can't ever monitor all that stuff at once when driving, I usually just hit the peak button to see what the hi/lo paramters were after a run.
Zeitronix display video
Old Mar 17, 2009 | 07:51 AM
terps's Avatar
terps
egt is important and can tell alot about a way the car is running, some tuner droped some knowledge about why and did alot better job explaining it than i could ever. i would search for it but havnt the faintest clue what thread it was in
i got boost, egt, and a/f
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
