Haltech Auxiliary two-step rev limiter ???
Old Apr 7, 2009 | 01:59 PM
frankie945's Avatar
frankie945
Question Haltech Auxiliary two-step rev limiter ???
Haltech users;
Has anyone got the two step rev limit to work? I can not find any info on it. The Search function is all out of wack. Thanks in advanced..
Old Apr 7, 2009 | 03:49 PM
frankie945's Avatar
frankie945
Where's rcdash, I bet he know the answer to this...
Old Apr 7, 2009 | 04:07 PM
Glex25's Avatar
Glex25
https://my350z.com/forum/forced-indu...h-control.html
There is a DIY I have been following.
I might pull out my clutch pedal assembly tomorrow to drill out for the switch
Old Apr 7, 2009 | 04:27 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
The auxiliary rev limiter is configurable in the ‘Inputs/Outputs’ tab of the ‘Main Setup’ in the ECU Manager. By default, it is disabled.
1. Connect two wires to the supplied 2-pin female connector.
2. Connect the two wires with a switch (or the clutch pedal can be used if you get creative).
3. Attach 2-pin female connector to the 2-pin male breakout harness. (mating wire colors: violet and blue)
When the two wires are connected, the two-step will be inactive.
When the two wires are disconnected, the two-step will be active.
Old Apr 7, 2009 | 04:58 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ If frankie didn't find an answer untill tommorow, i was going to show this to you tommorow.
chefj
Old Apr 7, 2009 | 05:40 PM
frankie945's Avatar
frankie945
Polarity doesn't matter the two wires can go either way? The ones off the clutch. Never mind I see mating colors my bad.
Old Apr 7, 2009 | 05:54 PM
frankie945's Avatar
frankie945
Ok, If I fab a mount for the clutch pedal for a push button switch so it's always making a connection with the violet and blue wires off the haltech. Then Put say a toggle switch in between the path for a on/off. Will that work I guess.
Old Apr 7, 2009 | 07:22 PM
D-tuned's Avatar
D-tuned
can you use the generic output to activate/deactivate the 2-step. if you connect the generic output wire to the AuxRev input wire and configure the generic output settings to activate for your situation. since the 2-step is active the ground(0V) is removed, set the generic output settings to the following: coolant temp >150degrees AND vehicle speed >5MPH OR load >7PSI. With the above settings the 2 step is active when you're below 5MPH. Once you launch, the 2-step will deactivated after the vehicle is above 5MPH.
Old Apr 8, 2009 | 05:42 AM
Dynosty's Avatar
Dynosty
Frankie, polarity does not matter but for reference the blue wire in position 2 is the actual switch that needs to see ground to be inactive.
D-tuned, yes you could use the generic output to switch the aux limiter though you must keep in mind the limiter needs ground to be inactive. I think you will have to reverse your conditions.
Old Apr 8, 2009 | 05:53 AM
frankie945's Avatar
frankie945
Great, Im goning to give it a try this weekend.
Old Apr 8, 2009 | 11:50 AM
rcdash's Avatar
rcdash
on spring break with the kids!
The haltech support page has all the info... www.injectedperformance.com/haltech
Old Oct 29, 2011 | 01:25 PM
rawley_12003's Avatar
rawley_12003
will this work on a 04 base model? yes i have the haltech platinum pro
Old Oct 29, 2011 | 05:43 PM
Resmarted's Avatar
Resmarted
SMH
Yes it will.
