MOTOR BLEW today
Old May 2, 2009 | 12:23 PM
  #61
UMW350Z's Avatar
UMW350Z
So sorry bro....
I doubt it was the UTEC hardware's fault...sounds like tune or motor issues/oil starvation. I'd be interested in what was found in a teardown
dump the TN kit this go-around
ORRR...if you need a new Nissan or Infiniti...you know who I work for and I'll give you my hookup
Old May 2, 2009 | 12:25 PM
  #62
Jay'Z's Avatar
Jay'Z
Pics of crack/leak?
Old May 2, 2009 | 01:02 PM
  #63
04LIQUIDSILVER's Avatar
04LIQUIDSILVER
Well I just got home from work... I'm jacking my car up to see what is goin on... and take pictures...
Do you guys know if I can swap an 06 motor on her? I found one witk ECU... just wonder if trany is the same?
Old May 2, 2009 | 01:10 PM
  #64
diwun67's Avatar
diwun67
Same block, so it should be...
Old May 2, 2009 | 01:13 PM
  #65
Spork's Avatar
Spork
From what I've been reading... Powerlab > Turbonetics?
Old May 2, 2009 | 01:19 PM
  #66
diwun67's Avatar
diwun67
In many ways, definitely
Old May 2, 2009 | 03:50 PM
  #67
UMW350Z's Avatar
UMW350Z
Price is the only 'downside' of the PL kit over the TN kit
Old May 2, 2009 | 04:59 PM
  #68
BaZooKa's Avatar
BaZooKa
Sorry to hear that, but keep your Z !
Old May 2, 2009 | 07:43 PM
  #69
Jay'Z's Avatar
Jay'Z
Pull that motor and drop that new one asap!!
Old May 3, 2009 | 03:57 AM
  #70
zmedic16's Avatar
zmedic16
45mph and not on boost should have nothing to do with the turbonetics kit. as per a faulty utec maybe. but if i dont recall the utec comes on when boost starts on the motor. maybe u had a recent oil change where your filter became exessively loose on the highway or after a bump on the road or like others have mentioned your motor might of been on its last leg. if i remember correctly i saw ur car at a c.t show and u had the WOT box as well. i wish you best of luck and if u going to continue boosting do a basic setup rods pistons and arp l19s.
Old May 3, 2009 | 05:57 AM
  #71
350 Rookie's Avatar
350 Rookie
he wont even need L19s cuz hes not gonna be boosting enough for head lift.
And willie, i got a email from the guy, he said the 350z tranny will bolt right up and hell send me pics on monday. Cross your fingers. You might be going home with a 800 dollar motor.
  #72
doug's Avatar
doug
i thought you had quoted me or something.. but didn't see any quotes
Originally Posted by doug
Since the UTEC only drives the car when its in boost... if you can't blame the TN.. how can you blame the UTEC/Tune? from the sounds of it.. it sounds like either oil starvation or the motor was on its last leg.. more than likely its oil starvation.. did the filter fall off? or did something hit the oil pan? oil lines wern't tight and the line came off? oil pump fail? you wern't putting any load in the motor so sounds like the oil came out the motor and the motor seized.. thus the clank clank noise.. sound of the pistons hitting the cylinder walls with no lubrication.. the only way to know would be to tear the whole motor apart
Old May 3, 2009 | 06:15 AM
  #73
streetzlegend's Avatar
streetzlegend
This really sucks, similar thing happened to my 3.5. I kept hearing this tapping (sounded like spun bearing), but didnt think at the time it was big deal, just normal engine noise. while on the highway, i stepped on it a bit, when i let off i heard the tapping noise come back very loud this time, drove at about 20mph after that, before getting to my destination, BAM!, engine turned off, and also heard a piece of oil pan bouncing on the floor.
In my case, it seems that the junk yard 73k vq35 I put in was probably hydro locked and had a bent rod, the noise was the rod hitting the inside of the piston (moving to the side along the wrist pin and touching the piston), the rod snapped right in half, everything else was perfect. Also my tune was perfect as well, just wasnt lucky with a junk yard motor.
Old May 3, 2009 | 07:20 AM
  #74
04LIQUIDSILVER
Thanks Ed, I also found an other one (rev-up) in LI for like around $2500
Old May 3, 2009 | 07:37 AM
  #75
go-fast's Avatar
go-fast
did you check your utec for poo?
Old May 3, 2009 | 07:50 AM
  #76
coachk's Avatar
coachk
^hey its poo fingers^
Old May 3, 2009 | 07:56 AM
  #77
drewk's Avatar
drewk
I have a question, so lets say you do swap your engine with another stock one. And you try to sell the car, will the dealership know that you swapped out the engine for another?
Old May 3, 2009 | 08:10 AM
  #78
go-fast's Avatar
go-fast
i have no poo on my fingers....i wash before working on cars.i'm betting that utec has fecal matter all over it though......op,i hope you didn't touch it!
(you know,he did confess about his sanitary practices)
Old May 3, 2009 | 08:11 AM
  #79
coachk's Avatar
coachk
^^ PMed you back^^
Old May 3, 2009 | 08:56 AM
  #80
350 Rookie's Avatar
350 Rookie
no they wont unless they read the vin on the engine but honestly, nobody does that.
and willie, idk about you but 2500 is alot of money for stock motor. Remember, you can only use the shortblock on the revup so theres gonna be labor for disassembling and reassembling the motor.
