New built engine starts. but wont stay on!!
Old May 10, 2009 | 05:51 PM
boostintt's Avatar
boostintt
Default New built engine starts. but wont stay on!!
car starts.. but wont stay on. no throttle response.. starts just fine, makes effort to stay on but it wont, runs for 3 seconds, then revs up and down a bit and shuts off.. oil pressure is good, no leaks, sounds healthy. but just wont stay on.. i give it throttle but no response, just goes up and down and finally shuts off after 5-8 seconds
any suggestions?
i have the utec plugged up with a base map/parameters.. map sensor is hooked up to the plenum.
FIXED: MAF was facing the wrong way.
Old May 10, 2009 | 06:01 PM
westpak's Avatar
westpak
SFZCC
what about with stock ECU?
have you checked all connectors?
Old May 10, 2009 | 06:02 PM
boostintt's Avatar
boostintt
same. all connections are good.
Old May 10, 2009 | 06:11 PM
westpak's Avatar
westpak
SFZCC
hmm double check the coils connectors are in the correct coil, easy to swap in wrong order
Old May 10, 2009 | 06:14 PM
boostintt's Avatar
boostintt
no throttle at all. i press gas and its like im not pressing at all
coils are good.
Old May 10, 2009 | 06:22 PM
350z 6spd's Avatar
350z 6spd
Double check throttle body connector? I'm sure you did, but the same thing happened to my friends car when we put it back together and that's what it was.
Old May 10, 2009 | 07:16 PM
str8dum1's Avatar
str8dum1
sell and buy a new car
+1 on the MAF
Old May 10, 2009 | 07:19 PM
psychoballistic's Avatar
psychoballistic
+1, happened to me also, worked fine and then like a week later took it all apart, forgot the throttle body connector which I fixed and then did the throttle body relearn and wala it worked.
Spork's Avatar
Spork
Go over everything and make sure every single wire/plug is connected.
Old May 10, 2009 | 07:40 PM
maximariceboi's Avatar
maximariceboi
sux that the 350z tb's arent cable driven =] but it def sounds like your TB isn't hooked up right. Where is the IACV (idle air control valve) on the Z anyway? Maybe want to check that as well if its plugged in...if there is any..
Old May 10, 2009 | 07:46 PM
maximariceboi
also..even though i never seen the software for utec, but this came in mind....
i have a emanage ultimate that i installed on my maxima 4yrs ago, drove it around the 1st month with no problem and later the car cuts off when i tried starting it up. later it wouldn't start at all. got the car towed back after HIN NY back in 2005, checked all the connections....found out that i never set the throttle settings on my laptop....maybe you want to check that if there is any such settings for utec...
Old May 10, 2009 | 08:04 PM
ACI318's Avatar
ACI318
Mass air flow might be installed with the flow going the wrong way. Or you dont have the flywheel on right and the crank sensor is reading wrong.
Old May 10, 2009 | 08:40 PM
maximariceboi
ahh yes check the cps! probably inconsistant spark....yea..the flywheel does have a timing ring on it..
like aci318 says...maf might be installed the wrong way...
Old May 10, 2009 | 08:42 PM
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
The TB is the idle control. It opens and closes to adjust the idle speed.If the TB is plugged in it is most likely something else unless you TB took a crap. We unplug the TB's all the time and dont have to do the relearn procedure.
Old May 10, 2009 | 08:44 PM
TurboTim's Avatar
TurboTim
You issue sounded familiar and this came to me.I am assuming you replaced your injectors recently.What injectors are you running?Are they high or low imdeance?We had a problem like this and it was because we had low impedance(order high got shipped low) injectors in there.
Old May 10, 2009 | 08:45 PM
TurboTim's Avatar
TurboTim
The car wil run with the crank sensor unplugged but it takes awhile to actually start it.And once it does start you can rev it.
Old May 10, 2009 | 09:59 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Check the little ground wire that comes out of the engine harness right on top of the motor in the front. It's has a circular connector and bolts to the top front of the timing cover.
Old May 10, 2009 | 10:03 PM
boostintt's Avatar
boostintt
well.. flywheel is fine. but i think my problem is the MAF... the guy who had this kit before had an FCON. which doesnt used the stock MAF.. i had to cut the pipe and add the stock MAF. it might be facing the wrong way!!! i'll check tomorrow. thanks guys!!
also i have no exhaust/test pipes!!! i was gonna drive the car with stock exhaust to exhaust depot and have them fabricate me one. so this thing is loud!!!
boostintt's Avatar
boostintt
yep. thats plugged..
Old May 10, 2009 | 10:05 PM
boostintt's Avatar
boostintt
beleive me i triple checked all the wires.. i pulled the motor out and did the install at my house, car has being down for 2 weeks, so i took my time on everything.. the only thing i can think of would be the MAF facing the wrong way!!!
