Best way to connect oil catch can??
Old May 16, 2009 | 05:44 PM
SIR_pierre's Avatar
SIR_pierre
Default Best way to connect oil catch can??
if i only have one.. where should i connect it? pass side? middle? drivers side? pass side and a T from the middle?
Old May 16, 2009 | 06:30 PM
Glex25's Avatar
Glex25
I always seen catch can's connected from PCV to catch can and from catch can to Plenum.
That is how I connected my catch can.
Old May 16, 2009 | 06:36 PM
meatbag's Avatar
meatbag
I would connect it to the passenger side vent and then to the plenum.
Old May 16, 2009 | 06:40 PM
doug's Avatar
doug
are you serious? please tell me you're not serious?
no one is this fcking lazy
https://my350z.com/forum/forced-indu...ighlight=catch
https://my350z.com/forum/engine-driv...catch-can.html
Old May 16, 2009 | 06:55 PM
03aeroZ's Avatar
03aeroZ
I wish there was a way to disable the post function until you searched first.
Old May 16, 2009 | 07:00 PM
Mr_pharmD's Avatar
Mr_pharmD
was there any benefits drilling out the PCV and installing larger AN fittings and hoses to the catch can?
Old May 16, 2009 | 07:03 PM
meatbag's Avatar
meatbag
Just better flow. You will need to install a check valve if you do that though inline with the catch can otherwise you will pressurize the PCV system.
Old May 16, 2009 | 08:49 PM
iamdigital's Avatar
iamdigital
I'm going to oil/air filters like those in a compressor setup. catch can FTL!!!!!!!!!!!
Old May 16, 2009 | 10:17 PM
Mr_pharmD's Avatar
Mr_pharmD
If I use a catch can that has an air filter to the atm will I still need a check valve?
Old May 17, 2009 | 02:27 AM
SIR_pierre's Avatar
SIR_pierre
YES i have SEARCHED and SEARCHED and found different answers in every thread..thats why i asked!
so i dont need to drilll anything out och put a backvent somewhere etc etc?
Old May 24, 2009 | 03:29 AM
SIR_pierre's Avatar
SIR_pierre
i have connected it from the pass side to the catch tank and then to the drivers side.. is that ok?
if you can follow it from the front
Old May 24, 2009 | 03:54 AM
Z04's Avatar
Z04
why don't you connect everything back up and find out? there are plenty of diagrams and methods shown already how to properly do this so why woud you not look at those pics?
what you just did was vent your passenger side straight to the driver side. that "T" intersection is not going to do nothing at all. plus your return line needs to go into the plenum.
in reality you only need one for the passenger side anyway since that is the one that produces the most oil blow by. i have just a small filter on my driver side and it is still dry as the day i put it on (4 years ago).
Old May 24, 2009 | 04:33 AM
SIR_pierre's Avatar
SIR_pierre
yes. but this was the worksshops solution.. they say i would be better.. and i know nothing
Old May 24, 2009 | 04:41 AM
Z04's Avatar
Z04
obviously they know nothing as well
Old May 24, 2009 | 06:06 AM
SIR_pierre's Avatar
SIR_pierre
no.sorry to say but they dont.. not about tuning anyway
Old May 24, 2009 | 09:55 AM
doug's Avatar
doug
there are multiple ways to run the catch can.. everybody has their own idea of what works.. this thread is the most popular route of running it
Passenger Side: PCV -> Catch Can -> Manifold
Driver Side: Breather Filter
if you're still having excessive blow by.. then you can try the other methods
P.S. read that thread from end to end till you understand that method
Old May 24, 2009 | 10:03 AM
SIR_pierre's Avatar
SIR_pierre
thanks doug
apex locator
Jul 23, 2021 02:27 AM
