No Boost...White smoke pouring out of exhaust
Old May 31, 2009 | 08:14 PM
willyd6869's Avatar
willyd6869
Default No Boost...White smoke pouring out of exhaust
I was driving the other day, and lost boost completely...after driving around and tinkering with the couplers, checking for boost leaks, white smoke is pouring out of my exhaust...Any ideas?
SparksNotes: No boost, white smoke pouring from exhaust
Old May 31, 2009 | 09:28 PM
Joe's08350Z's Avatar
Joe's08350Z
Sorry to hear that. My former '90 300ZX TT had a similar issue on its 1st motor. You are burning oil more than likely. Could be a combination of headgasket & piston rings. Sorry. This is an internal issue for sure.
Old May 31, 2009 | 09:36 PM
Mr_pharmD's Avatar
Mr_pharmD
check your spark plug to see if there's any detonation but it seems like it's a head gasket.
Old Jun 1, 2009 | 03:36 AM
Zivman's Avatar
Zivman
if I were a bet'n man, I would bet your motor is toast.
Anthing from a head gasket to broken piston
Old Jun 1, 2009 | 04:33 AM
nismozracer's Avatar
nismozracer
That sucks man definitely sounds like a head gasket just hope you didnt warp the heads.
Old Jun 1, 2009 | 05:46 AM
doug's Avatar
doug
sounds like your turbo's are toast
Old Jun 1, 2009 | 06:09 AM
escobar929's Avatar
escobar929
your burning oil. could be the seals on the turbo, hopefully nothing on the motor
Old Jun 1, 2009 | 06:19 AM
doug's Avatar
doug
if its the motor it would still be building boost.. and if it was his headgasket not only would he be building boost he it would be over heating..
Old Jun 1, 2009 | 06:33 AM
rcdash's Avatar
rcdash
Check your crankcase ventilation hoses. If they collapsed under heat (i.e. cheap rubber, use only SAE30R6 fuel injection hose and above) then oil will go everywhere - into the intercoolers and up the intake tract. If this happened you will need to clean out your IC and piping. If you take off your plenum, it will be obvious if you have pooled oil there.
Old Jun 1, 2009 | 03:17 PM
willyd6869's Avatar
willyd6869
Thanks for the replies...After a little more investigation, The driver's side down-pipe has a good amount of oil in it..Would one blown turbo cause Zero Boost?
Old Jun 7, 2009 | 06:36 AM
ings350z's Avatar
ings350z
yes it would. sounds like my problem need new turbos. sorry to hear about that.
Old Jun 7, 2009 | 07:34 AM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
Turbo failure. I have only seen this oh about 10,000 times in the past 20 years!
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
Li1ag
Sep 28, 2015 02:07 PM
