momentum performance
Old Jun 6, 2009 | 07:24 PM
mw9's Avatar
mw9
Just want to give Momentum a bump on the thread. These guys really stepped up at ZDAYZ. Good group of guys.
Old Jun 6, 2009 | 07:33 PM
UMW350Z's Avatar
UMW350Z
Where is your wastegate located?
Old Jun 6, 2009 | 07:40 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Originally Posted by Scott@Momentum
I have never seen a power lab kit in person but...
Their wastegate placement is a HUGE issue and I would highly recommend anyone with that kit change that on their own.
I have a HUGE problem with a competitor declaring a HUGE issue with another product without explaining what the supposed issue is.
Especially since this is the first time I have heard or seen a negative comment about the wastegate placement on the PowerLab kit. Nor am I aware of any performance issues/shortcomings on the PowerLab kit.
Old Jun 6, 2009 | 07:45 PM
UMW350Z's Avatar
UMW350Z
^ I noticed this with the PL kit and no one has ever answered my question....maybe Intense could chime in to confirm/deny this?
Old Jun 6, 2009 | 08:18 PM
Kwame's Avatar
Kwame
Nice youtube channel, that Nova was nasty!
Old Jun 6, 2009 | 08:51 PM
IIQuickSilverII's Avatar
IIQuickSilverII
On the uppipe well after the two banks have merged. I will take a installed picture next time the car is on the lift.
Normally I would never say something negative about a competitor but that wastegate is located almost 2ft before the two banks up pipes merge. That will certainly cause a huge discrepancy in back pressure between the two banks that the ecu with or without the turbo xs is not capable of compensating for.
what back pressure are you talking about genious, that same kit same piping flowed to >900whp, same kit has ran for over a year on hot az , trips to higher elevation etc...
That compressor cover is not an option on a 35R so I'm not sure what it is or how they got it on there. A 35R has a 4" inlet and 2.5" outlet that compressor looks like the non R housing with a 3" inlet and 2" outlet and a 60AR instead of 70.
check your glasses too while you are at it, its an off the shelf garret turbo by one of garretts biggest dealers
whats normal to you? ...this is your first thread here and you are already talking shlt...quite a different picture from what i though i heard at zday... were you busy talking shlt there too?
Old Jun 6, 2009 | 09:21 PM
SlideFox's Avatar
SlideFox
Wow.... I have to agree with Quick!!
7 posts and your already talking ****. Hmmm.... I wonder when this kit went into development??? Odd, that there are SOOOOO man "similarities", yet every one on the momentum setup is light years ahead of Powerlab.
O, and Powerlab comes standard with a turbo XS UTEC, or they can opt for a ProEFI, or any EMS for that matter. I have seen them sold with Haltech as well...
Old Jun 6, 2009 | 09:23 PM
SlideFox's Avatar
SlideFox
O, and if you can't look at the picture YOU posted of the Powerlab kit, and can't tell which pipes are the charge piping, and which are the hot side... I wouldn't let you near my car with a 10' pole!!!
Old Jun 6, 2009 | 11:53 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Jesus! Calm down people. He's giving his opinion. Can't you just give your opinion back without ripping him a new a-hole?
What sort of numbers are you guys shooting for out of the box?
Old Jun 7, 2009 | 12:56 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Any company that would publicly criticize and make incorrect assertions about a competitor's product when they "have never seen a PowerLab kit in person" deserves to get ripped a new A-hole and is setting themselves up to lose a lawsuit.
When PowerLab developed their kit with Intense, they looked to improve upon the known shortcomings and problems/issues with the Turbonetics kit that were well known and well documented within the VQ community. They dissected the Turbonetics kit as part of their R&D of the PowerLab kit. Intense had sold and installed numerous Turbonetics kits. In fact, Darren had the Turbonetics kit on his Z. Intense and PowerLab were speaking from extensive experience when they claimed improvements over the Turbonetics design. Nothing that Intense stated on the forums in comparisons between the PowerLab and Turbonetics kit was untrue.
However, by the statements of Scott@Momentum, it is quite obvious that Momentum Performance did not do the same with the PowerLab kit when they developed their own copy. Hence the ignorant comments made by Momentum in this thread based off of a picture. Until they...
  1. see a PowerLab kit in person
  2. ride in a PowerLab equipped Z or G
  3. install a PowerLab kit
  4. test a PowerLab kit
  5. disassemble a PowerLab kit
...representatives from Momentum Performance should refrain from publicly "giving their opinion" about a competitor's product when they have zero knowledge or experience with it.
It is laughable for Scott (who hasn't seen, installed, or tested a PowerLab kit) to claim a problem with the wastegate location on the PowerLab kit when not a single end user has reported problems that could be associated with it since the PowerLab kit was introduced over a year ago.
Old Jun 7, 2009 | 06:53 AM
str8dum1's Avatar
str8dum1
regardless of the bickering, how much will this single kit run? cheaper than the PL? what kinda fab costs woud one be looking at to fit a 40 or 42?
Old Jun 7, 2009 | 07:32 AM
G3po's Avatar
G3po
Default accurate info
Scott , since I started this thread , I guess I owe you some advice. "Don't cast FUD on this forum" , you'll get your head chewn off (and rightfully so). Two items in you list above are inaccurate and somewhat inflamatory.
a) "Their wastegate placement is a HUGE issue.."
Given the pretty extensive PL field experience, this has not been provent o be the case.
b) "That compressor cover is not an option on .."
It is a standard option ,.86 AR cover
Goodluck , even with this bumpy forum initiation.
Old Jun 7, 2009 | 07:43 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Well. I'm all for more and newer FI options out there. Probably not the best introduction to the forum, but i still wish all the best to the makers and hope it performs well. Make sure you keep it reasonably priced to.
Old Jun 7, 2009 | 07:55 AM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
I saw the story in the latest Z mag. Looks like it has great potential. I would definitely let them experiment with my Z if I lived closer. Good luck with it!
Old Jun 7, 2009 | 08:41 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Originally Posted by G3po
This is a desirable change over the PL kit IMO , though the small IC is not
"GT35R with TiAL .83A/R V-Band stainless housing"
This hot side housing should make it ,much easier to get the whole Turbo on and off as a single unit. Can't do this on the PL.
core efficiency is just as important, if not moreso, than core size. It's a case where size doesn't always matter
Old Jun 7, 2009 | 09:21 AM
IIQuickSilverII
well id like to see that core get pushed to 1000hp....and you are also assuming that the core really is that much more efficient when you havent seen the on the PL kit too.
The green widebody G never changed to a bigger core, it used the standard ont he kit THe did use a baller 5" core onte the TT Gt37r turbo build.
Old Jun 7, 2009 | 09:24 AM
Z1 Performance
Former Sponsor
I am not assuming anything because I don't know, nor do I care, about either kit quite honestly. I am just stating what I know to be fact.
Old Jun 7, 2009 | 09:56 AM
  #38
nomyth46's Avatar
nomyth46
my goodness.........scott, which Z did yall install the greddy kit on?......is it still in wilmington?
Old Jun 7, 2009 | 12:50 PM
  #39
G3po's Avatar
G3po
the .86A/R is the turbine housing not the compressor housing .........
I don't know what FUD is.
Fear, Uncertainty, and Doubt (FUD) is a tactic of rhetoric and fallacy used in sales, marketing, public relations,[
I looked at the dyno graphs on your site, and the 3.8L dyno doesn't represent the bulk of potential consumers here. Could we see a dyno graph , stock DE block , rwhp,rwtq , psi , ~91 oct?
Thanx.
Old Jun 7, 2009 | 02:24 PM
  #40
Quamen's Avatar
Quamen
We actually don't have a current graph with 91 octane as its not readily available in our area. We generally tune on 93 octane I will make a point of finding a pump with 91 octane and seeing how much of a difference there is. I'll have someone post a dyno graph on monday with 93 octane, I am actually on the dyno now with my car unfortunately I do not have a picture hosting account. The car makes 391whp on 8psi on 93 octane.
Can't you use the photo album in your USER CP on this site?
