Single Turbo. Advice needed.
Old Jun 18, 2009 | 07:37 AM
bnr34's Avatar
bnr34
Default Single Turbo. Advice needed.
Hello everyone.
I have a BNR34 GTR with 550ps (HKS GT-SSx2, Sard 550cc, Mine's 550cc ECU, etc.). So it goes slightly over 500ps now for 3 years already.
It is used for daily driving mainly on the street with rare drag strip visits. What I lack is a low-end power and I feel its performance is insufficient.
I just bought a VQ35DE engine from JDM 2001 Nissan Skyline, oil sump with holes for front axle from Skyline's VQ25DE 4wd vehicle and new sump suits just fine.
I need advice on what turbo to chose for 700 crank power (approximate 580-590 awhp)?
I tried to measure stuff and it seems like twin turbo (preferrable) is hard to put under the bonnet (front axle, shafts, etc), so the only choice is single. There will be a lot of space in front of VQ35 before the radiator, so Y-type exhaust manifold would be easy to fit and make.
I am considering Garrett GT4088R and Garrett GT4094R turbos. As car is used on the street, I need best spool possible.
On RB26 and GT-SSes it gets 14 psi at approximately 4000 rpm. It's not that good. Stock A/R 0.53 turbos spooled completely before 3500 rpms. That was awesome but is not enough power.
I'm looking for the spool before 4000 rpms and 700 crank ps. Is it possible with 3.5l VQ?
Both exhaust and intake tubes will be 3.5".
Thanks for any advises you may have.
Old Jun 18, 2009 | 08:10 AM
IIQuickSilverII's Avatar
IIQuickSilverII
GT37r http://www.full-race.com/catalog/pro...oducts_id=1682
spools pretty close to GT35r and is been maxed to 706whp. There are quite a few other options from other brands, precision has some nices ones in billet but depends on what you wanna pay that actually do spool like gt35r...
And actually the gt35r ~650whp... ..yeah 700hp...great spool...beats an apsTT by ~3300-3400 rpms
Old Jun 18, 2009 | 08:28 AM
bnr34's Avatar
bnr34
Thanks. Looks like a great turbo and pretty inexpensive. My friend has a GT35R in his Supra and turbo spools early in the 3000 range. It's on a 3.0l engine. On 3.5l it will spool even earlier.
However I think about one more reason. The smaller turbocharger you have, the more boost (more heat) you must apply to get certain power.
I will have a 0.5l more in displacement. Maybe it would be wiser to use a slightly bigger turbo and less boost to gain that power level?
Old Jun 18, 2009 | 08:36 AM
terps's Avatar
terps
borg warner or fp turbos apparently have better spool characteristics. Do i have any experience with them....no
Old Jun 18, 2009 | 08:49 AM
bnr34's Avatar
bnr34
I read about it some time ago. Borg Warner GT35R analog seems to have same spool but is cooled by oil . I guess BB and water cool is better. I'm not a pro in this, just a guess.
By the way, is oil pump on VQ35 good or must be changed to something else like on RB26s? I use Jun's oil pump, it's $1000... expensive :-( The standard one could break with this power level.
I'm also thinking about Turbonetics GT-K 650 turbo but can't find any feedback about its spool on VQ35 or any other 3.5l.
Old Jun 18, 2009 | 12:11 PM
str8dum1's Avatar
str8dum1
i'd go with a precision 6262 or a HTAGT35r
Old Jun 18, 2009 | 12:51 PM
Quamen's Avatar
Quamen
Precision 6765 w/.81 A/R.
I am putting my turbo in between the front timing cover and the radiator and it fits perfect on my car still allowing me to have a 4" dp. Sounds like what your going to do also.
Old Jun 18, 2009 | 12:56 PM
03threefiftyz's Avatar
03threefiftyz
I have been wondering how this turbo will do on our cars......are you using built 3.5l?
Old Jun 18, 2009 | 01:42 PM
da mayor's Avatar
da mayor
how is the tuning on your set up right now? any way to tweak it with the turbo you're currently using?
Old Jun 18, 2009 | 08:14 PM
bnr34's Avatar
bnr34
I have twins HKS GT-SS on RB26 now. I took everything from this setup, so it's in the past. 560 ps at flywheel max. Not enough.
Old Jun 18, 2009 | 08:30 PM
bnr34's Avatar
bnr34
Never heard about this turbo. Will read about it.
When does it spool on VQ?
Old Jun 19, 2009 | 12:52 AM
Quamen's Avatar
Quamen
Yes.
Old Jun 19, 2009 | 12:53 AM
Quamen's Avatar
Quamen
I will let you know in a couple weeks when I am done putting it together.
Old Jun 19, 2009 | 06:10 AM
str8dum1's Avatar
str8dum1
thats enough turbo to run 9's on a grand national with a 3600 rpm stall.
liqalu04
Jan 2, 2022 12:58 PM
lolwatbro
Oct 9, 2021 04:58 AM
FromGtoZ
Sep 20, 2015 03:41 PM
