A little help...
Old Jul 6, 2009 | 06:27 AM
  #41
str8dum1's Avatar
str8dum1
so you put in a new walbro and no dice? hopefully GRD gets you running. I guess they'll probably check you FPR as well, as if the valve went in that you wouldn't get any fuel pressure.
Originally Posted by jonnylaw
I added a few more gallons with a portable gas can, but still wouldn't start with very low fuel pressure. Fuel pump fuse checked out ok. The Walbro fuel pump was then swapped out in my driveway, but it did not work. After the swap, the CAMP2 shows fuel pressure of "0" when engine was primed and when cranking, the fuel guage was dropping to empty and back up again to 1/2 tank.
The car will be towed to the shop tomorrow morning.
Old Jul 6, 2009 | 06:59 PM
  #42
jonnylaw's Avatar
jonnylaw
yea, swapping out fuel pumps didn't change anything.
I just got word today that the problem is not fuel related at all. Apparently the fcon got really wet and lost all of its memory and settings. There was water on the baseboard and top. The car is running but dunno where the water is coming from yet, my guess is through the main harness behind the battery, beneath the cowl, after room was made for fcon wiring, but no silicone?
Old Jul 6, 2009 | 07:05 PM
  #43
Chef-J's Avatar
Chef-J
Booooosstt!!
^that is prob how water got in. Now I see...your prob sounds very similar with one of hal@Ip customer. His haltech soak in water.
Old Jul 7, 2009 | 04:55 AM
  #44
rcdash's Avatar
rcdash
With all the crap that goes through that grommet, it really needs to be well protected as it is no longer waterproof, at all. I use cling wrap (like saran wrap but thicker) over all the wiring, harnesses, and hoses and tuck it under the grommet. A little preventative care goes a long way for reliability with FI/mods in general...
Old Jul 7, 2009 | 04:00 PM
  #45
superchargedg's Avatar
superchargedg
Damn Noobs
Damn if that was it... you or the tuner should have at least put some silicone or something to cover that extra large hole we have to put thru that grommet.With all the years with my pos stillen kit i never had that problem but once i did the Greddy twins i noticed a wet floor mat on the pass side and traced it to the grommet near the battery and sealed it with silicone.
The car stunk with the silicone smell for awhile but it finally went away.
StateNuke08
Oct 31, 2015 05:01 AM
rmesola
Feb 6, 2006 08:54 PM
roberto350z
Oct 5, 2005 08:02 PM
spdu4ia
Nitrous Oxide
Feb 24, 2005 02:37 PM
