My Vortech 2.87 setup & dyno numbers =)
Old Jul 8, 2009 | 01:50 PM
  #41
Z_HighSpeed's Avatar
Z_HighSpeed
very nice!
Old Jul 8, 2009 | 02:08 PM
  #42
frankie945's Avatar
frankie945
Originally Posted by bd0g36
Yes, I have a similar set up and your TQ pwns my TQ please give me ur secret
With a SC timing is the key to TQ. That's why most SC guys run water/meth.
Old Jul 8, 2009 | 03:46 PM
  #43
chaparro78's Avatar
chaparro78
I have pretty much the same numbers as you with the same basic set up. Congrats, looks good
Old Jul 8, 2009 | 04:51 PM
  #44
binder's Avatar
binder
any tips on what timing to run? i'm pulling 9 degrees up top at 11psi and it runs great, but who doesn't need extra torque??
Old Jul 9, 2009 | 05:59 AM
  #45
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
I will be posting up my Log very soon guys. Im just waiting to put the blower back in!! ughhh. 1 week with no car.. this is killing me
Old Jul 9, 2009 | 08:17 AM
  #46
Chef-J's Avatar
Chef-J
Booooosstt!!
^y you putting back on?
Old Jul 9, 2009 | 08:51 AM
  #47
cc1012's Avatar
cc1012
^^ replaced seals. It was spraying oil out the back of the blower and we think it was causing belt slip
Old Jul 9, 2009 | 09:05 AM
  #48
Vas@Extended
yep what chris said^...
Old Jul 10, 2009 | 10:36 AM
  #49
g35keys's Avatar
g35keys
geez nice guys I'm nervous as I'm about to order test pipes soon as I get a call back...that will lower my pressure so boost will go down but I will go UP in power right? I don't want to loose to much back pressure and then loose power. I'm at 395/359 (I want to go check one of these inflated dyno's and see what I can't pull ) I'm hoping the test pipes will push me to like 410/375
Old Jul 12, 2009 | 08:45 AM
  #50
marra23's Avatar
marra23
Originally Posted by Vas@Extended
Well since one of my bearings was busted ( the lower output shaft bearing ) and also my seals I decided to just upgrade to better seals and bearings.
I got the 65K bearings because well I dont have to worry about it anymore with the 2.87 shifting at redline.. as with the stock bearings I was close to over spinning the blower.
I dont think that the impeller will withstand speeds that high, at least the stock one, but I got it anyways because I plan to upgrade down the line to the 928.
My next step is the 928 and I would like to take it to 7K
oh and I got my bearings from Todd, www.superchargersrebuilds.com
did anyone do the 928 impeller upgrade and what's your experience. doing some searching on google and the first thing i came up with is this....
http://www.superchargersonline.com/f...?TOPIC_ID=5329
Old Jul 12, 2009 | 10:18 AM
  #51
str8dum1's Avatar
str8dum1
buy it and try it. no one has done it. go for it!
Old Jul 12, 2009 | 05:35 PM
  #52
Quamen's Avatar
Quamen
Except for me...
Old Jul 12, 2009 | 06:26 PM
  #53
str8dum1's Avatar
str8dum1
well, but yours doesnt count as you didnt have a normal belt setup
Old Jul 12, 2009 | 06:39 PM
  #54
Quamen's Avatar
Quamen
I don't know. As a universal performance modification I tested and got results that should have been typical for any car. Not to say that a stock vortech 350z would make the same whp at the same impeller rpm I did but the results should be comparable for before and after.
Old Jul 12, 2009 | 07:42 PM
  #55
Vas@Extended
I want the 928!
anyways..
UPDATE: The blower is back in the car and everything is running good, and it sounds like a monster!.. I did the new belt setup and I got the 81" and I think its too big because even though it looks SO tight, it comes out about 1 rib from the pulley ? weird. Im gonna figure it out tomorrow. an im only seeing 5psi??? BLAH.
How do you guys tighten up the cog belt? Do you have somebody else push down on it while you tight it? its like impossible to do it your self lol
Old Jul 12, 2009 | 07:54 PM
  #56
Chef-J's Avatar
Chef-J
Booooosstt!!
I don't know, i didn't even move cog tensioner pulley. It was tight but it did fit.
Old Jul 12, 2009 | 08:11 PM
  #57
Vas@Extended
how did u get the belt in? Any ideas what could cause hitting only 5psi with the 2.87? It was fine before.. now this. probably something with the belts.. my boost gauge just stays rock solid at 5 psi at 6600rpm. should be 10-12
Old Jul 12, 2009 | 11:22 PM
  #58
marra23's Avatar
marra23
OK, so how long have you been running this impeller. Reliability was in question in that link i posted. if you do have comparisons before/after.....would be great.
Old Jul 13, 2009 | 03:15 AM
  #59
Chef-J's Avatar
Chef-J
Booooosstt!!
Was it full throttle from low rpms?
Belt tight enough? Any boost leaking?
You should see atleast 10psi+ at redline.
About belt. Well... at first, I thought it aint going in, but it did go in.
Old Jul 13, 2009 | 05:13 AM
  #60
Quamen's Avatar
Quamen
That dude is a piece a ****. He stated that his impeller cracked because of craftsmanship and forgot to mention that he doesn't run a bypass valve on his supercharger. In fact, he didn't even know what one was! Cracked impellers and bad bearings is what happens when you have compressor surge. I'm sorry but he is one of those guys that should not have wrenchs to work on his own car.
Reliability is not an issue at all. The impeller was designed by one of the best impeller designing companies in the United States and machined by one of the best impeller manufacturers in the United States. Not only that but it was overspun tested to well over 60,000 rpm's. The same impeller that was overspun was the one I had in my car.
The other thing is that the impeller blade is bent inward on that guys impeller. That means he hit it or he sucked something into the supercharger. The impeller is designed so that the normal stresses that an impeller sees are channeled through strong areas. This engineering allows for thinner blades and more aggressive design which make more power. However, go figure that some sort of impact that is not normal may damage it.
The 928M impeller is a high quality performance impeller that was designed to the limit of what you can do reliably and without modifying the volute. I would vouch for it any day because I was part of the whole development process and I am well aware of the stupid amount of time, money and testing that went into it. I know the companies that made it and there is a number of other types of vehicles that are running them without problems at all.
Unfortunately, this persistant POS has made it his goal to do everything he can to not take the blame and has in doing so hurt 928M's reputation.
