My Vortech 2.87 setup & dyno numbers =)
Old Jul 15, 2009 | 07:25 AM
  #101
frankie945's Avatar
frankie945
Uti is jeffsofware. There is also MPS witch is another logging program. There is info on both in the utec upgrade forum. I have used both and like UTI the best.
https://my350z.com/forum/tuning/1893...c-upgrade.html
UTI is talked about towards the end of the thread.
Old Jul 15, 2009 | 07:44 AM
  #102
cc1012's Avatar
cc1012
the BPV went bad..... thats my guess. Vas lemme know if you need help trouble shooting or logging. Im pretty good with the UTEC.
Old Jul 15, 2009 | 07:56 AM
  #103
tylerxfire's Avatar
tylerxfire
its not the bpv, its gotta be belt slip or a leak, do the leak test and no the blower doesnt need to come out to do that...just unhook the coupler and leave the blower in place..
on a side note alot of vortech guys here...so any of u guys take the filter out to clean? any tips on removing it without taking anything else out and not banging it all up
Old Jul 15, 2009 | 08:04 AM
  #104
cc1012's Avatar
cc1012
The kit was used and had some miles on it..... It could very well be the BPV. I wouldnt rule it out.
Old Jul 15, 2009 | 08:48 AM
  #105
tylerxfire's Avatar
tylerxfire
^^^ the kit was on the car though and boosting fine from what im aware of before the blower was removed
Old Jul 15, 2009 | 11:56 AM
  #106
binder's Avatar
binder
let me know if you find this out. There is no room on my g35 to remove that air filter without taking the blower out. total suck. I didn't realize this putting it together and had to remove the blower to get the filter in.
there are only 2 things that can leak on the bypass valve: the oring on the inside and the gasket. If it hasn't been touched then i doubt the gasket is bad. If the oring is bad on the inside then it proably wouldn't boost to 5psi either. It also just made it up to 8psi. Intermittant oring failure doesn't exsist. It is either a broken oring meaning no boost, or the oring works fine. It doesn't do 5psi one day, then the next do 8psi so i'm going to say that probably isn't the cause.
Old Jul 15, 2009 | 12:30 PM
  #107
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
Up loading a the video now... **** i suck at this utec! its so complicated. im sure its easy once u know what to look for.
I just did some more checking of the couplers , so im gonna do a run one more time and post it up.
im gonna do a 2nd and 3rd gear pul from 3000
Old Jul 15, 2009 | 12:32 PM
  #108
Vas@Extended
I can take the filter out with out moving anything.. its a little hard but it comes off!
Old Jul 15, 2009 | 12:36 PM
  #109
Vas@Extended
im definitely going to do a boost leak test. I just gotta look at the DIY and buy the materials..
I dont think 98% that is the belt. I have tighten the belt so much.. it is rock solid! I even went for a run, came back and tighten it more. I pretty sure its not the belt.
Old Jul 15, 2009 | 12:55 PM
  #110
binder's Avatar
binder
hmm....that's weird.
ya, do a 3k-6500 rpm log.
Old Jul 15, 2009 | 01:04 PM
  #111
Chef-J's Avatar
Chef-J
Booooosstt!!
Good luck vas!
And filter. There is only two option, CAI or longer filter, which needs trim out some area but Its easier than stock filter.(check out WTB section, I posted a pictures and part numbers.)
Old Jul 15, 2009 | 02:03 PM
  #112
tylerxfire's Avatar
tylerxfire
yeah i think i can too, just havent tried it yet, i dont wanna bang the filter all up...didnt know if there was a precise way to get it out without it being a pain...
Old Jul 15, 2009 | 02:04 PM
  #113
tylerxfire's Avatar
tylerxfire
there are only 2 things that can leak on the bypass valve: the oring on the inside and the gasket. If it hasn't been touched then i doubt the gasket is bad. If the oring is bad on the inside then it proably wouldn't boost to 5psi either. It also just made it up to 8psi. Intermittant oring failure doesn't exsist. It is either a broken oring meaning no boost, or the oring works fine. It doesn't do 5psi one day, then the next do 8psi so i'm going to say that probably isn't the cause.[/QUOTE]
exactly
Old Jul 15, 2009 | 02:35 PM
  #114
frankie945's Avatar
frankie945
To log with the UTEC open hyperterminal on your laptop plug in serial or usb. Turn key to the on position. Then The utec home screen will pop up in the hyperterminal. Go to logger by pressing 1. It will start to log hit space bar to start and stop it. At the top of the hyperterminal you will see transfer, Click it and choose capture text. It will ask you what folder you want it to go. I named a new folder on my desktop to send files too so they will not get lost in your computer. So after you chose what folder you want the file to go hit start and it will start saving your logs. Once you are done logging go back to transfer and click stop file transfer. And all your logs will be in the folder you have chosen. Remember the space bar starts and stops the log.
You will get the hang of it. It takes trial and error.
I could never get the usb cable to work so. I used a Berklin Usb to serial cable adapter and it worked great.
Old Jul 15, 2009 | 02:42 PM
  #115
frankie945's Avatar
frankie945
Here is a leak tester I made if you do find in your logs that it's a leak. And DO NOT pressurize to 20psi like was mentioned it will blow your seals inside your motor. 10 psi is plenty to check for a leak. If you can't hear it, use soapy water and you will find every leak.
https://my350z.com/forum/forced-indu...-test-vid.html
Old Jul 15, 2009 | 04:08 PM
  #116
tylerxfire's Avatar
tylerxfire
400whp350z or somethin along those lines on here has a simple and effective boost leak tester that is very newb friendly..
anyone on here have a dyno graph or something that shows what belt slip would look like on a graph?
also op my car runs like crap when its hott, it gets to 6k and falls on its face and wont make more than 8psi, when its cool out and not humid i will see 9-10 psi and it runs like a raped ape...i was tuned when it was 69 degrees and not humid at all...but im going in pretty soon here for a retune with the 2.87 pulley so all will be good...take the weather into consideration but either way u should see more than what u are seeing
Old Jul 15, 2009 | 04:50 PM
  #117
binder's Avatar
binder
you need new seals then. 75k miles and 20psi didn't hurt a single thing. I haven't even had a drop of oil consumption on my car. If 20psi blows seals on an engine that isn't running then something is wrong with it.
Old Jul 15, 2009 | 05:49 PM
  #118
str8dum1's Avatar
str8dum1
this is belt slip. Only making 5psi is most likely NOT slip. That means he'd be slipping completely at like 4000 rpms. His entire motor would be COVERED in belt dust if that was the case. He didnt put something back together properly, pushed on the valve on his bypass valve, or something else. Need to do a leak test.
Old Jul 15, 2009 | 06:19 PM
  #119
Vas@Extended
Well guys I took another video and i played it when I got home... I saw 9psi . Both 2nd and 3rd gear.... Even more of a bad news is that I have to take the unit out again. There was oil in the bpv... Ughhhhhhh fak my life. Gotta do that all over again. When I take it out Iam going to do the logg, it's not worth it to go any further on this boost leak test without getting this this.
Iam going to diagnose what's causing the oil leak and go from there. When the blower is out I will do a boost leak test as well
blahhh ='(
Old Jul 15, 2009 | 06:21 PM
  #120
Vas@Extended
Sorry for the miss spelling Iam
on my phone and I can't type for **** lol
